OKType3Tim  Samba Member
Joined: April 30, 2011 Posts: 301 Location: Northeast Oklahoma
Posted: Wed Feb 01, 2023 4:24 pm Post subject: Eval the two new Brazilian Steering Box Manufacturers-MFG B |
Following up on the evaluation of the two Brazilian manufacturers of steering boxes. My post regarding Mfg A is here:
https://www.thesamba.com/vw/forum/viewtopic.php?t=772496&highlight=
This post discusses the experiences with Mfg B.
To repeat from the earlier post:
Disclaimer/background: I don’t have a financial investment or ownership in either of the two products. My interest is in having a quality steering box for myself and fellow VW enthusiasts to use in keeping our vehicles safely on the road. It started because I had a problem with my own endeavors:
https://www.thesamba.com/vw/forum/viewtopic.php?t=659460&highlight=
Which lead to me having to figure out bearings, seals, gaskets, shims, replacement worm shafts, replacement roller shafts, top cover bushing replacement, and assembly techniques:
https://www.thesamba.com/vw/forum/viewtopic.php?t=660446&highlight=
To solve my own needs for a handful of working steering boxes, I put together 100 refurbishment kits. I had 100 sets of shims manufactured; 100 gaskets made. I had the kits ready in January 2017. Purchasing 100 units of anything can get you a little bit of a discount; but not a lot. I wasn’t, and I’m not, interested in creating a VW steering box parts business. I marked the kits up enough to reassure my soul that I wasn’t being completely stupid to take some retirement funds and purchase a pile of parts. The kits were consumed 3 years later.
[<grin> So much for reassuring my soul that I was making a wise investment.]
Along the way, it turned out that not everyone was as enthusiastic about rebuilding their own steering box. So, on a very limited basis I would rebuild a steering box for someone. And then later I rebuilt brand new TRW boxes to my working standard for those individuals that ask. This was all word of mouth; I didn’t advertise, I’m also not trying to create a VW steering box rebuilding company. [I’m retired and I have so much stuff going that I don’t know how I ever had time to go to work.]
With the kits gone, Marcel at VWNOS stepped in to fill the gap. He asked, and I provided, what I knew about bearings, seals, gaskets, and shims. He sourced more bearings and seals.
Then TRW really did stop producing steering boxes.
With the disappointing results from Mfg A, Marcel kept searching and found that there is a second Brazilian vendor. The second vendor/manufacturer turns out to be the actual purchaser of the full TRW VW Steering Box business. (Most Importantly, Including equipment, drawings, knowledge, etc.) They were just slower to the market than Mfg A.
Marcel, obtained a unit from Mfg B for me to dissect. I could reproduce the full writeup that I prepared, but the summary is that the initial unit pretty well matched the quality that TRW was producing. To their credit they were filling the unit completely with a better grease. And they had produced new main housing castings. In other words, it was as good as TRW, but still had the same drawbacks that had caused me to rebuild brand new TRW units. Marcel sent the writeup to them, and then it got interesting in a positive direction. Their response was, “Tell us more, how can we make the unit address your concerns.” WOW!
Thus, began some communications and changes to produce a better unit. I created a document that outlined my concerns and what I felt should be done to produce a better unit. And they changed their manufacturing and created a revised product. I then evaluated the revised product.
Improved, but not quite there. Additional information was provided to them, which also included some discussion regarding manufacturing tolerances and assembly adjustments. They again changed/improved their process and provided a revised product.
And now we have a unit that I feel comfortable recommending.
So here is a picture of labeled steering boxes.
They were also willing to sell the individual components, so as shown by the unit in the far right of the picture; it is now possible to completely rebuild an original VW unit retaining only the original housing. I.E. all of the other parts are brand new. So if you have an original VW housing with a good lower bushing; then you can accomplish this. However, if you are considering the economics, then I would just purchase the complete unit.
So here is a look at the unit.
Opening up the top cover, you see a full set of grease:
Initial disassembly
Notice the attention to detail. They are putting thread sealant on the two bolts that go through the top cover into the interior of the housing. There is also thread sealant on the big adjuster nut. The top cover gasket was attached with gasket sealant. These are assembly items that work to keep the grease inside where it belongs.
After cleaning up:
The bearings are of the style that uses a plastic cage. I can understand. That is just the way the bearing world has gone. Nothing to be done about it. From our discussions with the manufacturer, I am assured that the bearings are a quality item. The seals are still single lip, but the sealing surface is improved by being slightly softer (less hard) than the original TRW ones. The hardness level is similar to the double lip seals that I use in my rebuilds.
Looking at the top cover, I am really pleased to see that they have pressed in a brass bushing.
All of the machining is clean and precise. Note, don’t be fooled by the interior logo, this logo goes back to the TRW castings. The important improvement is the use of a brass bushing.
Looking at the lower housing, Again a pressed in brass bushing.
The machined surface of the top of the housing appears to be flat
And a couple passes on the surface plate proved that it really was flat. No high or low spots.
The non-flatness of the housing to has been a problem all the way back to the first VW units: The top of the original housing was never machined perfectly flat. Thus, there had always been a leak point at the top side of the housing.
The worm shaft has undergone final machining so the bearings fit in the races as they should
The fit and finish of the roller shaft is proper, including a better finish on the pocket where the top (small) adjusting screw rides
AND, the surface of the adjuster screw has been properly machined.
One of my pet peeves. This surface has continual pressure and wear on it. Every time you turn the steering wheel, the surface of the adjuster screw rides against the surface of the pocket with pressure. This pressure is what adjusts the no-play zone. So a rough fit and finish here leads to early wear and a narrowing of the no-play zone. I.E. making the steering play at the steering wheel grow sooner. They accepted my recommendation and improved this manufacturing step.
To summarize, the unit has very good “fit and finish”.
The adjustment of the unit is in line with the original VW documents.
And with the full grease load the units should have good life.
An additional comment: As noted at the top of this post, The shafts and top cover from this manufacturer are available. Using those items, along with original FAG bearings, new gasket, double lip seals, and corn head grease; I assembled the unit in the far right of the picture. I was very pleased with the outcome.
As always with my posts, reasonable comments and observations are welcome. _________________ '69 Squareback restoration
'69 Fastback restoration
'66 Type34 |
RedSquare Samba Member
Joined: August 28, 2017 Posts: 249 Location: Kansas City
Posted: Thu Feb 02, 2023 7:36 am Post subject: Re: Eval the two new Brazilian Steering Box Manufacturers-MFG B |
This is excellent news, and thank you very much for sharing. More importantly, thank you for putting in the time to do the assessment and provide the feedback to the manufacturer. That is something that very few (if any) of us could have done and results in better parts being available to keep these wonderful old machines in proper working order.
Again - thank you. |
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 6041 Location: Brooklyn
Posted: Thu Feb 02, 2023 9:34 am Post subject: Re: Eval the two new Brazilian Steering Box Manufacturers-MFG B |
Very cool, Tim!
So do we get to know who Mfg B is so people can know what to look for?  _________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
heimlich  VWNOS.com
Joined: November 20, 2016 Posts: 7585 Location: Houston, Texas
Posted: Thu Feb 02, 2023 9:38 am Post subject: Re: Eval the two new Brazilian Steering Box Manufacturers-MFG B |
| sjbartnik wrote: |
Very cool, Tim!
So do we get to know who Mfg B is so people can know what to look for?  |
This is it here: https://www.thesamba.com/vw/classifieds/detail.php?id=2554601
I think Tim alluded to this in his posting that different productions of the box resulted in different qualities. I did one large run based on everything that was discussed with the manufacturer. They made all of the pieces based on those specifications. _________________ www.vwnos.com [email protected]
Erik G Samba Member
Joined: October 16, 2002 Posts: 13592 Location: Tejas!
Posted: Thu Feb 02, 2023 10:59 am Post subject: Re: Eval the two new Brazilian Steering Box Manufacturers-MFG B |
thanks for stepping up and doing this. I don't even have a VW right now but I'll likely buy one and stash it (like all proper type 3 hoarders ̶s̶h̶o̶u̶l̶d̶ do) |
heimlich  VWNOS.com
Posted: Thu Feb 02, 2023 11:07 am Post subject: Re: Eval the two new Brazilian Steering Box Manufacturers-MFG B |
| Erik G wrote: |
Tim was/is instrumental in making this happen. We both spent a lot of time/money on it. _________________ www.vwnos.com [email protected]
Erik G Samba Member
Posted: Thu Feb 02, 2023 11:36 am Post subject: Re: Eval the two new Brazilian Steering Box Manufacturers-MFG B |
| heimlich wrote: |
| Erik G wrote: |
Tim was/is instrumental in making this happen. We both spent a lot of time/money on it. |
Thanks Tim as well! I missed one of his rebuilds and won't do that again _________________ Stop dead photo links! Post your photos to The Samba Gallery! |
Posted: Thu Feb 02, 2023 11:45 am Post subject: Re: Eval the two new Brazilian Steering Box Manufacturers-MFG B |
Nice work guys!
For $159 that's a no-brainer. _________________ 1965 Volkswagen 1500 Variant S
heimlich  VWNOS.com
Posted: Thu Feb 02, 2023 12:07 pm Post subject: Re: Eval the two new Brazilian Steering Box Manufacturers-MFG B |
| sjbartnik wrote: |
Nice work guys!
For $159 that's a no-brainer. |
People have come to me that have bought a $200+ box. I told them I paid $70 for their box in Brazil. This one: https://www.thesamba.com/vw/forum/viewtopic.php?t=772496
I have learned that retail price tells you nothing about quality. You have to see what is inside.
Thankfully we have Tim to see what is inside. _________________ www.vwnos.com [email protected]
Jason37 Samba Member
Posted: Thu Feb 02, 2023 2:23 pm Post subject: Re: Eval the two new Brazilian Steering Box Manufacturers-MFG B |
This is absolutely fantastic - ordered.
mdege Samba Member
Joined: January 16, 2018 Posts: 1112 Location: Niederkruechten, Germany
Posted: Fri Feb 03, 2023 5:47 am Post subject: Re: Eval the two new Brazilian Steering Box Manufacturers-MFG B |
| sjbartnik wrote: |
Nice work guys!
Agree, but it would be nice if the source could be shared with at least one of the distributors on the European side of the pond.
Because ordering the box from the US would be prohibitively expensive when you add shipping and on top of that duties and taxes, which you have to. _________________ - Michael
1963 Typ3 Notchback project
1988 Multivan Magnum 112i
1984 Standard: My son wanted a bug for his first car |
Erik G Samba Member
Posted: Fri Feb 03, 2023 8:48 am Post subject: Re: Eval the two new Brazilian Steering Box Manufacturers-MFG B |
| mdege wrote: |
| sjbartnik wrote: |
Nice work guys!
Because ordering the box from the US would be prohibitively expensive when you add shipping and on top of that duties and taxes, which you have to. |
make friends with an american soldier stationed over there. any miltary branch will do. we can post to them cheap and easy  _________________ Stop dead photo links! Post your photos to The Samba Gallery! |
heimlich  VWNOS.com
Posted: Fri Feb 03, 2023 9:00 am Post subject: Re: Eval the two new Brazilian Steering Box Manufacturers-MFG B |
| mdege wrote: |
It'd still be cheaper for you to buy through me. I have very little markup on my box.
You pay 20% tax no matter if you buy it from USA or Germany. I ship to Germany and the EU regularly.
I wholesale these as well. I can load a box, truck, container for shipment anywhere in the world for your distribution partner.
Do you think your distribution partner will send the boxes to Tim for inspection as I have done?
Shipping to Germany is $57.87 by UPS Worldwide Expedited - 5 day delivery. That brings the total to $216.87 (not including payment fees) _________________ www.vwnos.com [email protected]
Chloepetra Samba Member
Joined: August 20, 2024 Posts: 6 Location: Western Australia
Posted: Tue Aug 20, 2024 10:56 am Post subject: Re: Eval the two new Brazilian Steering Box Manufacturers-MFG B |
| heimlich wrote: |
| mdege wrote: |
Shipping to Germany is $57.87 by UPS Worldwide Expedited - 5 day delivery. That brings the total to $216.87 (not including payment fees) |
Just read all 24 pages of that thread and have about 20 samba pages open...
with the legendary corn grease it looks like this superbox comes to about $300, is that right? Needs to be shipped downunder as well  |
heimlich  VWNOS.com
Posted: Tue Aug 20, 2024 1:09 pm Post subject: Re: Eval the two new Brazilian Steering Box Manufacturers-MFG B |
| Chloepetra wrote: |
That's about right. I ship everywhere. _________________ www.vwnos.com [email protected]
Posted: Wed Aug 21, 2024 4:05 am Post subject: Re: Eval the two new Brazilian Steering Box Manufacturers-MFG B |
Soooo...
not trying to be cheeky, but has the price basically doubled because of inflation or is there a bit more custom work or rebuilding going on with these Mfg B/TRW boxes? If there's some kind of limited super-spec rebuild QC batch thing I'd love to hear about it, and I'm sure other ppl would be interested!
Thanks Marcel and/or Tim for clarifying, $400usd +tax is a lot for me to take on faith when it's not OEM/NOS and it's not like I'm able to drop by and have a chat if there are any issues once it's here and installed
(I mean...it's still better than Mfr roulette obv.)
EDIT:
PS I'm confused in part bc the samba classified ad says there are two types of boxes, and the website blurb says this:
On BACK ORDER. Estimated delivery is September 15th. This steering gearbox is made from TRW template. These boxes contain NOS steel caged FAG bearings and upgraded seals. These are an upgrade to the standard type of bearings and seals that TRW was using. The NOS FAG bearings are steel caged and have more ball bearings. An option below allows you to pick the grease for your box. I use John Deere Corn Head grease. For the grease option, it comes empty by default but you may ask for it to be filled before it ships or you may fill it yourself. Does not fit Super Beetle.
...and at the cart it says more than 10 are available?!??  |
heimlich  VWNOS.com
Posted: Wed Aug 21, 2024 7:22 am Post subject: Re: Eval the two new Brazilian Steering Box Manufacturers-MFG B |
I am currently waiting on a shipment which is why you see the backorder note.
What you are seeing is the box with all of the upgrades for $295. That is the only one available at this time. I fixed the descriptions on TheSamba add. I appreciate you bringing this to my attention.
If you have a friend or acquaintance flying from Houston I can meet them at the airport and deliver the box. That should save you a few dollars.
Where ever you buy your box I hope you get to enjoy it. _________________ www.vwnos.com [email protected]
Posted: Wed Aug 21, 2024 8:40 am Post subject: Re: Eval the two new Brazilian Steering Box Manufacturers-MFG B |
| heimlich wrote: |
Where ever you buy your box I hope you get to enjoy it. |
Jesus that sounds ominous 😄
Thanks for the offer to drop it at the airport tho 😘 |
rdetrick Samba Member
Joined: February 17, 2025 Posts: 1 Location: New York State
Posted: Mon Feb 17, 2025 9:05 am Post subject: How to identify |
Marcel, Thanks for working on this for years and ensuring a good box is available.
I have three boxes, I did not purchase any of them.
One is a NOS TRW from 10 years ago.
Second one, I believe is an original VW box, very worn..
The third, which is in my vehicle, was purchase by previous owner and was stated to be a "new brazil steering box".
How can someone identify the boxes without disassembly?
Can the loose VW and TRW still be rebuilt?
Regards,
Bob |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 23574 Location: Oklahoma City
Posted: Mon Feb 17, 2025 9:13 am Post subject: Re: Eval the two new Brazilian Steering Box Manufacturers-MFG B |
Great work from both of you guys!
Ray |
