SGKent  Samba Member
Joined: October 30, 2007 Posts: 42986 Location: at the beach in Northern Wokistan
Posted: Sat Feb 18, 2023 11:26 am Post subject: Reading / Calibrating late Bay fuel gauge |
Does anyone have a late bay (1976 or later) with the 211-957-063B 0003 gauge still intact with ALL original factory installed parts - sender, vibrator and gauge like the one below?
If so do you know how many gallons each line represents?
The owner's manual says that the tank holds 14.6 gallons, with the reserve being 1 gallon, but the way the lines are, it appears that reserve is about 2 gallons.
Using the bottom line as empty, then the marks would be:
1/1 = 14.6 gallons
1/2 = 7.30 gallons
1/4 = 3.65 gallons
Reserve ?
0/0 = 0 gallons
Red (Reserve) should be a little more than 1/8 (= 1.83) gallons. Book says 1 gallon but the gauge appears to be about 2 gallons so best guess is the E line leaves 2 gallons and the book is wrong.
However if one approaches the gauge as the tank has a total of 12.6 gallons plus 2 gallons reserve = 14.6 total, then the math changes for each line.
If someone has a totally original stock tank, sender, gauge and vibrator, then we could compare against their numbers.
Canned Water - the new California approved parts cleaner (except in a drought in which case rub it with sand).
George Carlin:
Skills@EuroCarsPlus:
"never time to do it right but always time to do it twice"
1971 deluxe (sold)
1977 deluxe |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 53244 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sat Feb 18, 2023 11:55 am Post subject: Re: Reading / Calibrating late Bay fuel gauge |
Do consider the guys who designed that were thinking in metric, I'll bet the divisions make more sense when not converted to gallons.
When I have doubts I drain all the gas and measure it as I put it back in noting what the gauge says every couple gallons. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
SGKent  Samba Member
Posted: Sat Feb 18, 2023 12:06 pm Post subject: Re: Reading / Calibrating late Bay fuel gauge |
| busdaddy wrote: |
When I have doubts I drain all the gas and measure it as I put it back in noting what the gauge says every couple gallons. |
That is what I was going to do but I'd like a standard to compare it to. The tank is empty right now. Also the engine has to be running a while to get an accurate reading because late gauges are driven by a bi-metallic strip. As the gauge heats up it reads a little higher than when cold. _________________
George Carlin:
1971 deluxe (sold)
1977 deluxe |
Buenos Diaz Samba Member
Posted: Sat Feb 18, 2023 12:17 pm Post subject: Re: Reading / Calibrating late Bay fuel gauge |
| SGKent wrote: |
| busdaddy wrote: |
That is what I was going to do but I'd like a standard to compare it to. The tank is empty right now. Also the engine has to be running a while to get an accurate reading because late gauges are driven by a bi-metallic strip. As the gauge heats up it reads a little higher than when cold. |
SGKent,
Does the engine have to be running or just have the key to the on position?
Thanks,
Deez _________________ 1967 21 Window Bus
1965 Beetle
2019 Atlas |
buckswilde Samba Member
Joined: June 26, 2010 Posts: 151 Location: Lexington, KY
Posted: Sat Feb 18, 2023 12:22 pm Post subject: Re: Reading / Calibrating late Bay fuel gauge |
| I thought late bays are 15.9 gallons. Pretty sure that's true of 78 and 79 at least. |
Posted: Sat Feb 18, 2023 12:35 pm Post subject: Re: Reading / Calibrating late Bay fuel gauge |
| I just looked at all of the manuals posted in the technical section for late bays and it says 14.6, but I swear my manual for my 79 says 15.9 gallons. I'll double-check once I can find it. Now I think my brain is getting old. |
Posted: Sat Feb 18, 2023 12:42 pm Post subject: Re: Reading / Calibrating late Bay fuel gauge |
| Okay, I'm getting this from the Bently Offical Service Manual - All years are 15.8 gallons total, including reserve. |
bsairhead Samba Member
Joined: October 08, 2008 Posts: 4577 Location: viroqua wi.
Posted: Sat Feb 18, 2023 1:21 pm Post subject: Re: Reading / Calibrating late Bay fuel gauge |
| buckswilde wrote: |
60 liters 77 reserve says 4 78 says 5 79 says 4 WTF |
SGKent  Samba Member
Posted: Sat Feb 18, 2023 2:14 pm Post subject: Re: Reading / Calibrating late Bay fuel gauge |
I actually looked in the 77 manual that I have here at the desk. Below is also a jpg from the manual online here. It reads 14.6 US Gal with Reserve being 1 gallon of the total capacity. Since we can't buy senders that actually read right we have to calibrate them ourselves. Worst case I can put in 2 gallons and see where it reads, then add 4 more and see if it is about 1/2.
George Carlin:
1971 deluxe (sold)
1977 deluxe |
richparker Samba Member
Joined: November 24, 2011 Posts: 7817 Location: Durango, CO
my59 Samba Member
Joined: August 13, 2003 Posts: 4017 Location: connecting the dots
Posted: Sat Feb 18, 2023 3:41 pm Post subject: Re: Reading / Calibrating late Bay fuel gauge |
Wow, I have to admire the desire for accuracy and the time expended.
Given the 59 beetle came with a decades old notebook with mileage and gallons added, when I got the bus I simply instituted the same process. This was before I knew that the bus gauge reads empty after the first 60 miles or so.
SGkent, rock on! _________________ my59: Well son, my grandfather died before I got to drive it, so does that answer your question?
Other:'12 Jetta, '77 Benz 300D, and a 74 MG Midget. |
SGKent  Samba Member
Posted: Sat Feb 18, 2023 4:26 pm Post subject: Re: Reading / Calibrating late Bay fuel gauge |
| my59 wrote: |
SGkent, rock on! |
I do it two ways, there is the glance to see how much gas I have, and the mileage ticker in my head that says 200 miles, need to find a gas station soon. I'd like both to function  _________________
George Carlin:
1971 deluxe (sold)
1977 deluxe |
telford dorr Samba Member
Joined: March 11, 2009 Posts: 3631 Location: San Diego (Encinitas)
Posted: Sat Feb 18, 2023 10:12 pm Post subject: Re: Reading / Calibrating late Bay fuel gauge |
If you really really really really want an accurate fuel gauge, there's a way to do it (but it's not trivial...)
Use a microcontroller (like an AtTiny85).
This requires that the fuel sender and gas gauge indicator are repeatable (always giving the same resistance reading for a given fuel level, and indicating the same fuel level for a given amount of gauge current). These values must be mathematically "well-defined".
You create a circuit to pass a fixed current through the fuel sender, and measure the resulting voltage with the microcontroller A/D converter. You power the gas gauge with a fixed voltage and drive it with the Pulse Width Modulated output of the microcontroller. You select the sender current to use the maximum range of the A/D converter, and the gauge voltage to use the maximum range of the PWM drive.
In software, you use a method known as piece-wise linear approximation to calculate the PWM output for any given reading from the A/D converter. This is done by finding the voltage readings for, say, 9 tank levels (empty, 1/8, 1/4, 3/8, 1/2, 5/8, 3/4, 7/8, and full. You find the pulse width needed to make the gas gauge read these levels, and put them in a look-up table. For any reading other than these fixed points, you assume that the value is linear between the known points, and so is the PWM drive. The error is usually insignificant.
Using this method, you can interface ANY gas gauge to ANY fuel sender. Also works for temperature and pressure gauges. It's how you make retrofit engines work with old gauges in old cars.
Takes a bit of work to do, but it works!
FWIW _________________ '71 panel, now with FI
More VW electrical at http://telforddorr.com/ (available 9am to 9pm PST) |
mikedjames Samba Member
Joined: July 02, 2012 Posts: 3472 Location: Hamble, Hampshire, UK
Posted: Sun Feb 19, 2023 1:16 pm Post subject: Re: Reading / Calibrating late Bay fuel gauge |
Another way to measure is to put a low pressure gauge below the tank and measure the height of fuel by pressure.
Alternatively you can buy an ultrasonic pinger that measures the distance to the top of the fuel.
Both of these work by using a user-provided depth versus surface area model to get the volume of fuel above the pressure sender, or below the ultrasonic sender.
I have used both (made by Maretron) on boats, we rejected the ultrasonic sender because we had an single cylinder diesel engine running at 3000 rpm (generator) for 50Hz AC .. and the ultrasonic sender went wild unless we isolated it from the vibration. _________________ Ancient vehicles and vessels
Posted: Sun Feb 19, 2023 1:44 pm Post subject: Re: Reading / Calibrating late Bay fuel gauge |
I see the brain trust have spoken Fill till pump shuts off, drive till 1/2 tank, fill till pump shuts off. That and 5th grade math should be enough. |
SGKent  Samba Member
Posted: Sun Feb 19, 2023 2:26 pm Post subject: Re: Reading / Calibrating late Bay fuel gauge |
| bsairhead wrote: |
Just as easy to fill going in. That said. I was hoping someone with an original late bay had already crunched the numbers on each line from years of filling 'er up. _________________
George Carlin:
1971 deluxe (sold)
1977 deluxe |
Posted: Sun Feb 19, 2023 3:11 pm Post subject: Re: Reading / Calibrating late Bay fuel gauge |
| As I am not sure about my gauge.This spring when I do my 5 year fuel line change I will note where 4 liters reads. I'am less than a 1/2 mile to my filling station and will take notes. |
metahacker Samba Member
Posted: Mon Feb 20, 2023 10:29 am Post subject: Re: Reading / Calibrating late Bay fuel gauge |
The original late bay senders have a curved former under the resistance wire in the sender. So that each turn is a different length.. that produces best accuracy.
12 years ago I bought an aftermarket sender and it had three blocks of windings with a different pitch so it was close but not so perfect.
Last year I bought an aftermarket sender and it was wound in a linear fashion.. so all of the range of the gauge vanishes in about 100 miles then you are deep in the reserve for the next 100 miles or so on the gauge. _________________ Ancient vehicles and vessels
