Cool Transmission
Page: Previous  1, 2, 3, 4, 5
halbug
halbug is offline
PostPosted: Sat Oct 23, 2021 8:23 am    Post subject: Re: Cool Transmission Reply with quote
modok wrote:
Modok, I liked your concept better and picked mine just up from the welder.
Thank you
halbug
Stealth Ghia Transformation: http://www.thesamba.com/vw/forum/viewtopic.php?p=7226044&highlight=#7226044
My Berg5: https://www.thesamba.com/vw/forum/viewtopic.php?t=730276&start=0
The motor: https://www.thesamba.com/vw/forum/viewtopic.php?p=10343324#10343324
Max Welton
Max Welton is offline
PostPosted: Sat Oct 23, 2021 10:40 am    Post subject: Re: Cool Transmission Reply with quote
Nice welds!
Max
1967 Type-3 Fastback
halbug
halbug is offline
PostPosted: Mon Oct 25, 2021 9:44 pm    Post subject: Re: Cool Transmission Reply with quote
Yep! I have him weld all my structural stuff. Unfortunately I can not weld like this...
slayer61
slayer61 is offline
PostPosted: Tue Oct 26, 2021 7:29 am    Post subject: Re: Cool Transmission Reply with quote
Brother your attention to detail is off the chart. Very cool Cool
Your car is stunning!
Cusser wrote:
... Most folks are idiots when it deals with electrical !!!
67rustavenger wrote:
3/4 race cam? What's missing, one of the lobes? Shocked
Paul
'68 Manx clone... Sears??
RLR/Strange brakes
2276 built on AS21 case
W-125 w/ GB 1.25:1 rockers
Mahle forged pistons
CB 4340 crank
CB H beam rods
deep sump
45 DCOE
Garrett turbo
Tim's stage II turbo heads
MSD Box and distributor
Car Craft turbo header
View user's profile Send private message Send e-mail AIM Address Yahoo Messenger MSN Messenger Facebook Twitter Instagram Gallery Classifieds Feedback
halbug
halbug is offline
PostPosted: Wed Oct 27, 2021 8:32 pm    Post subject: Re: Cool Transmission Reply with quote
Man I don't know what to say.... Embarassed
Thank you!
Halbug
halbug
halbug is offline
PostPosted: Sat Jan 28, 2023 7:11 am    Post subject: Re: Cool Transmission Reply with quote
The built of my chassis has finally progressed to a point where I could assemble all the transmission oiling stuff. I am sure the oil will be terribly confused finding its way back into the case Laughing
Oil pick up and scavange filter with magnet
Electrical oil pump switched on at 113F, into filter from there to thermostat
Oil exceeding 180F will be routed to the oil cooler
Pressure control and distribution to the gear pairs
Excessive oil directly into case
Now I can bench the system. I need to find the sweetspot of spraying a good amount onto the gears and still flow some directly to the R&P. All at as low pressure as needed. Things I can play with is the nozzle size and spring pressure for oil pressure control. More to come.
halbug
halbug is offline
PostPosted: Sat Mar 25, 2023 9:16 am    Post subject: Re: Cool Transmission Reply with quote
Time to fry some transmission oil Laughing
Here are some pics from my bench. I tested the system today.
After several runs with adjustmens of the spring pressure and the jet size of the squirters, I found what I think is a good compromise of oil share between the direct oil return into the case and the squirters. All at about 7-8 psi to hopefully not overload the E-pump.
This concludes the transmission build. I will have clean oil at all gears at all times. Even the Berg 5th will get enough. And when things get touch I can be sure to not overheat the transmission Cool
Cheers halbug
Ian Godfrey
Ian Godfrey is offline
PostPosted: Sat Mar 25, 2023 2:22 pm    Post subject: Re: Cool Transmission Reply with quote
Wow, that is one of the most elaborate test beds I have ever seen. A big tick for ingenuity Shocked Laughing
halbug
halbug is offline
PostPosted: Sat Apr 01, 2023 1:21 am    Post subject: Re: Cool Transmission Reply with quote
Ian, thank you for your nice words, but there is nothing elaborate about this thing Laughing
Anyhow it did it's job...
Cheers
maplesyrup
maplesyrup is offline
PostPosted: Sat Apr 01, 2023 8:32 am    Post subject: Re: Cool Transmission Reply with quote
Awesome!
Bugger
Page 5 of 5
