Holley RetroBright 7” Round LED Headlights
don.ville Premium Member
Samba YardMan
don.ville is offline
PostPosted: Thu Jul 27, 2023 5:36 pm    Post subject: Holley RetroBright 7” Round LED Headlights Reply with quote
Anyone use the Holley LED sealed beam headlight conversions?
Holley RetroBright 7” Round LED Headlights for Classic Cars Classic White 3,000K Color – Made by Morimoto
https://www.amazon.com/dp/B09N7TN1X2?ref_=cm_sw_r_apin_dp_KBAR30HWSN4H5BBXK4RC_3
04 Jetta TDI Page (SOLD)
29 Ford Model A Rat Rod (SOLD)
2015 Audi A8L TDI Quattro
Erik G
Erik G is offline
PostPosted: Thu Jul 27, 2023 10:28 pm    Post subject: Re: Holley RetroBright 7” Round LED Headlights Reply with quote
morimoto is excellent stuff. I've used them in some $1200 lights. Not sure about these, thats a lof of extra on the back. There's a guy here that sells good vintage LED's that look more original and I'd imagine will fit better than those
Samba YardMan
PostPosted: Fri Jul 28, 2023 4:47 am    Post subject: Re: Holley RetroBright 7” Round LED Headlights Reply with quote
This guy?
https://www.thesamba.com/vw/classifieds/search.php?username=vintagecarleds
His premium 3500 model is a better deal since it has Hella German lens and you get 2 bulbs for $289 compared to one for $189
MrPolak
MrPolak is offline
PostPosted: Fri Jul 28, 2023 8:55 am    Post subject: Re: Holley RetroBright 7” Round LED Headlights Reply with quote
I went with LED bulbs because I wanted the option to replace faulty bulbs without replacing the housing, and I can use multi-color bulbs. I have Euro headlights.
H4 Hella housings with good LED bulbs are very satisfactory for a bus. I used this combo in my Vanagon.
BarryL Premium Member
BarryL is offline
PostPosted: Fri Jul 28, 2023 6:26 pm    Post subject: Re: Holley RetroBright 7” Round LED Headlights Reply with quote
There are these for way more money.
https://www.jwspeaker.com/products/applications/automotive/
I don't know what makes them expensive nor how they compare to those you guys already posted.
MrPolak
MrPolak is offline
PostPosted: Sat Jul 29, 2023 6:15 am    Post subject: Re: Holley RetroBright 7” Round LED Headlights Reply with quote
The goodness of a headlight is mostly in the pattern, so check it before buying. A good LED bulb will retain the E-code pattern of a Hella housing.
I also have these and like the pattern and output a lot. Be your own judge when deciding how these will look in a vintage vehicle:
https://www.amazon.com/Xprite-Headlights-Approved-Headlamps-1997-2018/dp/B082SC83Q8/[url]
Samba YardMan
PostPosted: Sun Jul 30, 2023 6:38 am    Post subject: Re: Holley RetroBright 7” Round LED Headlights Reply with quote
I think the vintage led 3500 model with Hella lens seems like the best option for me.
OE lens with the light color not too white like a modern car, but much brighter
cdennisg
cdennisg is offline
PostPosted: Tue Aug 01, 2023 9:48 pm    Post subject: Re: Holley RetroBright 7” Round LED Headlights Reply with quote
Another possibility...
https://cruiserteq.com/oem-toyota-koito-h4-headlight-upgrade-kit-w-harness-elec81110kit/
I bought two sets from a Toyota dealer in Atlanta for $80 shipped.
Eric&Barb
Eric&Barb is offline
PostPosted: Wed Aug 02, 2023 9:53 am    Post subject: Re: Holley RetroBright 7” Round LED Headlights Reply with quote
Those are not LED.
In Stereo, Where Available!
cdennisg
cdennisg is offline
PostPosted: Wed Aug 02, 2023 2:03 pm    Post subject: Re: Holley RetroBright 7” Round LED Headlights Reply with quote
Those are not LED.
Yep, just figured maybe they could be an option. But, if a guy wants LED, these aren't it.
Erik G
Erik G is offline
PostPosted: Wed Aug 02, 2023 4:42 pm    Post subject: Re: Holley RetroBright 7” Round LED Headlights Reply with quote
Those are not LED.
You can put an LED in those
Eric&Barb
PostPosted: Wed Aug 02, 2023 5:02 pm    Post subject: Re: Holley RetroBright 7” Round LED Headlights Reply with quote
Any recommendations or better yet links??
Erik G
Erik G is offline
PostPosted: Wed Aug 02, 2023 9:09 pm    Post subject: Re: Holley RetroBright 7” Round LED Headlights Reply with quote
there are so many available - so, no I won't. They run from very cheap to very expensive. What's good for one lens won't be good for another. Look for a bulb that you can twist and change the pattern as needed, those you can usually make work well. Or buy from the guy that figured it out and sells here in the classifieds. No affiliation
panel
panel is offline
PostPosted: Sat Aug 05, 2023 8:36 am    Post subject: Re: Holley RetroBright 7” Round LED Headlights Reply with quote
MrPolak......any info on your yellow LED bulbs ?
My '65-Subaru EJ20 Turbo conversion
vintagecarleds
vintagecarleds is offline
PostPosted: Tue Sep 05, 2023 11:53 am    Post subject: Re: Holley RetroBright 7” Round LED Headlights Reply with quote
don.ville wrote:
This guy?
Thanks, that's me! Cool
Yes, the Holley lights are GOOD, and work well.
They are double the price of ours, and feature a plastic lens (ours are glass)
www.vintagecarleds.com
[email protected]
713-853-9644
Samba YardMan
PostPosted: Wed Sep 06, 2023 3:39 am    Post subject: Re: Holley RetroBright 7” Round LED Headlights Reply with quote
Going to get down to build up some headlight buckets sometime in the future
Buskraut Premium Member
Buskraut is offline
PostPosted: Sun Jul 20, 2025 10:46 am    Post subject: Re: Holley RetroBright 7” Round LED Headlights Reply with quote
Mini-review: Thanks to a nudge from Amazon Prime, I decided to pull the trigger on a set of the Xprite's recommended by MrPolak.
https://www.amazon.com/Xprite-Headlights-Approved-Headlamps-1997-2018/dp/B082SC83Q8/?th=1
So far, I'm impressed. In spite of the fact that they are marketed to the Jeep/Hummer crowd, they fit perfectly in the stock housings on my 65 bus. Zero tweaking required. They plug straight into the stock wiring connector, but you have to be a bit creative to stuff the connector at the back of the housing since it's on a dongle.
Beam pattern is even, with a sharp cutoff at the top so you don't blind folks. And compared to the bottom of the line Wagner bulbs I had, these things are BRIGHT! I also like that when off, they don't give the bus too much of a sci-fi alien look. Pictures below are off, low beam, high beam. There is also a separate wire for DRLs, which only lights the halo (visible in the low beam pic), but I haven't connected that yet.
Erik S
'65 Type 251 / Deluxe
'03 Eurovan MVWK
70bus Premium Member
70bus is offline
PostPosted: Sun Jul 20, 2025 2:30 pm    Post subject: Re: Holley RetroBright 7” Round LED Headlights Reply with quote
Let us know if they obliterate your radio reception - my LED headlights completely drown out all radio sations with static.
Yes, some of us still listen to a radio. Especially since my bluetooth dongle has worse interference from LED lights!
Craig K
70 Neunsitzer
65 Pritschenwagen
Raul the 65 singlecab
Karl the 70 nine-seater
vwuberalles
vwuberalles is offline
PostPosted: Mon Jul 21, 2025 7:32 am    Post subject: Re: Holley RetroBright 7” Round LED Headlights Reply with quote
This was a thread in the late beetle forum about some Toyota 7" H4 headlights for stupid cheap. I ordered a set for my bus, they're really nice and they even come with a relay kit!
https://www.thesamba.com/vw/forum/viewtopic.php?t=794958
Buskraut is offline
PostPosted: Mon Jul 21, 2025 12:48 pm    Post subject: Re: Holley RetroBright 7” Round LED Headlights Reply with quote
Craig, good question… just checked and no impact on AM or FM reception.
My radio is a Sapphire I with added FM module.
Erik S
'03 Eurovan MVWK
