ricobuggy Samba Member
Joined: September 18, 2002 Posts: 53 Location: St. Charles, IL
Posted: Mon Mar 24, 2003 7:58 am Post subject: Headlight Bucket Color? |
I am restoring my headlight buckets and want to repaint them. Does anyone know what color they are? A color code? These look sort of greyish... Not sure if that is the original color or just an OLD color?
Thanks.
Rich |
Major Woody Samba Enigma
Joined: December 04, 2002 Posts: 9016 Location: Portland, OR
Posted: Mon Mar 24, 2003 9:33 am Post subject: Headlight Bucket Color? |
| Rust-Oleum gloss light gray. At Home Depot. Really. |
Preistrager Samba Member
Posted: Mon Mar 24, 2003 3:03 pm Post subject: Headlight Bucket Color? |
| Would it make a difference to use a bright white to improve visiblity, 6Volt system? |
j.pickens Samba Member
Joined: December 03, 2002 Posts: 9831 Location: Exit 7, New Jersey
Posted: Mon Mar 24, 2003 9:08 pm Post subject: Headlight Bucket Color? |
| I don't think the white will help much, the headlight lenses are responsible for directing the beam. |
bugheadred Samba Member
Posted: Mon Mar 24, 2003 9:37 pm Post subject: Headlight Bucket Color? |
| i did mine in crome powder coat i think thay look great |
bmx2c4me Samba Member
Joined: February 09, 2003 Posts: 644 Location: Maryland
Posted: Tue Mar 25, 2003 6:27 am Post subject: Headlight Bucket Color? |
| Krylon Stone grey (Satin finish) because rust o leum sucks. I think the semi gloss finish looks most factory. |
staceyz Samba Member
Joined: December 05, 2002 Posts: 497 Location: Vancouver, BC
Posted: Tue Mar 25, 2003 11:38 pm Post subject: Headlight Bucket Color? |
| Tremclad Aluminum |
justindn Samba Member
Posted: Sun Mar 30, 2003 3:42 pm Post subject: Headlight Bucket Color? |
| Check the Wolfsburg West website for paint codes for your year. It has everything from the black colour of brake pedals etc. to the body colour. It should have the headlight bucket grey. Justin in Victoria. |
Snoop Bob Samba Member
Posted: Mon Jan 17, 2011 8:00 pm Post subject: |
Bringing it back for a variation on the question. My buckets appear different colors inside the lense area and on the back side where they look like the beige/grey. Before I get the paint matched tomorrow I just want to clarify it should be the beige/grey color all over. I am assuming the inside looking almost white is due to sun bleaching of the paint. Can anyone confirm. Thanks. _________________
| BarryL wrote: |
| Put your lips onto the little tit with the hole in it inside and make a good seal. You can suck and blow but with a little resistance. It gets better after it's wet. |
| EverettB wrote: |
| I would be interested in knowing the sizes of the various shafts. |
npbusguy Samba Member
Joined: February 08, 2006 Posts: 1661 Location: Budapest, Hungary
Posted: Mon Jan 17, 2011 8:21 pm Post subject: |
Rally wheel silver on the inside.
The outside of the buckets are different colors depending on the year (the left bucket from my 58 is pictured)
Posted: Mon Jan 17, 2011 8:29 pm Post subject: |
Thanks for the clarification Neil. I was obviously referring to my late model buckets ....Sheesh you early split guys.  _________________
| BarryL wrote: |
| EverettB wrote: |
Posted: Sat Jan 22, 2011 9:14 am Post subject: |
1 - Reference the outside of the bucket. I have a couple pairs I wanted to get color matched. The later push terminal set I have are a darker different grey/beige than the earlier screw terminal set. Has anyone had either of these color matched to provide a code. My local Sherwinn Williams on carries a metal enamel in gloss or satin and doesn't have the satin in stock (I really need a flat), and my local auto paint store (Finish Master) can't color match because the bucket isn't flat enough for their camera, and I don't have a spare to hack up and press flat for the process. Any help would be appreciated.
2 - In regards to the blue paint/ink stamp that references the part number,etc. of the outside of the bucket. Has anyone reproduced these, and if not can someone with the knowledge/resources assist with some information on how it should be done. I noticed this also varies from early to late. Thanks again. _________________
| BarryL wrote: |
| EverettB wrote: |
KevinAlbrecht Samba Member
Joined: March 07, 2002 Posts: 996 Location: Ocean City > Boca > Pompano > Kirkland > Eugene > Sarasota > Babcock Ranch
Posted: Wed Jan 02, 2013 10:39 am Post subject: Re: Headlight Bucket Color? |
| Major Woody wrote: |
| bmx2c4me wrote: |
Of course my local Home Depot does not carry either of these. I know this is an old thread, but wanted to know if anyone had a (current) source for either of these paints? _________________ Kevin Albrecht
1963 Panel
Don't forget those seat-belts!
Click to view image
Last edited by KevinAlbrecht on Wed Jan 02, 2013 3:35 pm; edited 1 time in total |
cru62 Samba Member
Joined: December 31, 2002 Posts: 4121 Location: Margaritaville.....24/7
Posted: Wed Jan 02, 2013 2:23 pm Post subject: |
| Snoop Bob wrote: |
| 2 - In regards to the blue paint/ink stamp that references the part number,etc. of the outside of the bucket. Has anyone reproduced these, and if not can someone with the knowledge/resources assist with some information on how it should be done. I noticed this also varies from early to late. Thanks again. |
If you can get a rubbing from it on tracing paper it would be possible to darken the printed area by hand and have a rubber stamp made. I did this for a stamp to reproduce the SIGLA mark on glass. It worked OK. If you blow it up, do the filling in and then reduce it back down it looks better than doing all the work at the original size. Good Luck and let us see what you come up with! _________________ "My biggest worry is that when I die, my wife will sell all my parts for what I told her I paid for them"-Jon
Jokes about German sausage are the wurst.
67 Florida Deluxe Samba Purist
Joined: June 21, 2005 Posts: 7990 Location: Gainesville and Tampa, Florida
Posted: Sat Jan 05, 2013 5:45 pm Post subject: |
On my '59, the passenger side was original and near perfect, so I left it alone. I used Wolfsburg West "Chrome" L-91 on the driver's side, which had leaked and rusted a little. Side-by-side, the WW "Chrome" was 99% identical to the original passenger side. Installed, they looked exactly alike.
Of course, if you are painting both, you can be a little more varied in the "exactness," relative to original. _________________ -Kent (BaT "daleallen")
OG member of the '67 Posse
A few of my toys, past and present
'56 Oval, '66 KG Conv't, '67 21-Window, '67 Bug, '79 SuperVert, '55 Pre-A Continental |
localboy Samba Longboarder
Joined: December 06, 2003 Posts: 5153 Location: "Mainland", PNW
Posted: Wed Dec 06, 2023 11:27 am Post subject: Re: Headlight Bucket Color? |
Stone Geay in satin is not even remotely close:
_________________ One man's "patina" is another man's cancer...
Black '65 Resto-Custom S Notch 2110 cc powered
original paint Pearl White '66 Westy SO-42
Allstate single-wheel trailer project |
Stocknazi Samba Member
Posted: Wed Dec 06, 2023 12:43 pm Post subject: Re: Headlight Bucket Color? |
I found the Krylon Smoke Gloss Grey to be a decent match to original primer. It's a bit glossy, but the color is close.
It could probably be baked at 300' for an hour to reduce the gloss, but I never bothered. _________________ WANTED:
Thomas Jefferson |
Posted: Wed Dec 06, 2023 2:10 pm Post subject: Re: Headlight Bucket Color? |
| Stocknazi wrote: |
| I found the Krylon Smoke Gloss Grey to be a decent match to original primer. It's a bit glossy, but the color is close. |
That’s WAAAAY better.  _________________ One man's "patina" is another man's cancer...
hitest Samba Member
Joined: September 30, 2008 Posts: 10327 Location: Prime Meridian, ID
Posted: Thu Dec 07, 2023 9:53 am Post subject: Re: Headlight Bucket Color? |
https://www.thesamba.com/vw/forum/viewtopic.php?t=119187
-before going too nuts reinventing a subject...
PS- the discussion here is about headlight assemblies. Your headlight bucket is always lower body color. _________________
| EverettB wrote: |
FU#5 |
don.ville  Samba YardMan
Joined: February 07, 2008 Posts: 2954 Location: West Palm Beach, FL
Posted: Mon Apr 15, 2024 5:44 pm Post subject: Re: Headlight Bucket Color? |
| localboy wrote: |
looks like its different paint
04 Jetta TDI Page (SOLD)
29 Ford Model A Rat Rod (SOLD)
2015 Audi A8L TDI Quattro
