Large tire/big meats - Stock suspension Bus thread
Page: Previous  1, 2, 3 ... , 103, 104, 105  Next
Terry Gaudet
Terry Gaudet is offline
PostPosted: Sun Jun 23, 2024 4:08 am    Post subject: Re: Large tire/big meats - Stock suspension Bus thread Reply with quote
Hi Jake,
Can you let us know if there was any installation or rubbing issues with the Crosswind tires.
Terry Gaudet
1950 Beetle Standard
1955 Canadian Custom
1956 Kombi w/SO23 kit
1965 Kombi walkthrough
1965 Double Cab
Stocknazi
Stocknazi is offline
PostPosted: Sun Jun 23, 2024 2:38 pm    Post subject: Re: Large tire/big meats - Stock suspension Bus thread Reply with quote
Anyone know what the largest size tire (stock 15 inch bus wheel) that can be used on a flat lip wheel well bus?
I have some 225/70 15 tires that I'd like to use, but suspect they may be a little wide.
WANTED:
Thomas Jefferson
cdennisg
cdennisg is offline
PostPosted: Sun Jun 23, 2024 9:35 pm    Post subject: Re: Large tire/big meats - Stock suspension Bus thread Reply with quote
You have the tires, you have some wheels, and you have a bus? Throw a couple on there and report back to us.
Stocknazi
PostPosted: Mon Jun 24, 2024 6:51 am    Post subject: Re: Large tire/big meats - Stock suspension Bus thread Reply with quote
I may have to do just that. I know a 215/75-15 will fit (barely), but the 225/75-15 is 0.4 inches wider, so it's gonna be close.
WANTED:
Thomas Jefferson
BarryL Premium Member
BarryL is offline
PostPosted: Mon Jun 24, 2024 6:26 pm    Post subject: Re: Large tire/big meats - Stock suspension Bus thread Reply with quote
Stocknazi wrote:
...but the 225/75-15 is 0.4 inches wider, so it's gonna be close.
Stocknazi wrote:
I have some 225/70 15 tires...
Is the "70" a misprint or is the "75"?
LostnaWesty
LostnaWesty is offline
PostPosted: Fri Jun 28, 2024 4:51 am    Post subject: Re: Large tire/big meats - Stock suspension Bus thread Reply with quote
stock suspension
grabbers 27x8.5x14
EJZero1
EJZero1 is offline
PostPosted: Sun Sep 22, 2024 3:52 pm    Post subject: Re: Large tire/big meats - Stock suspension Bus thread Reply with quote
Been waiting for my Grabber ATX 205 75 15’s for 2 months. Apparently a nationwide back order situation with no ship date in sight. Looking at other options now.
Primary contender is the BFG AT KO2, but closest size is a 215 75 15. Bus is currently running some very old Kumhos in that 215 75 15 size and they fit well with no rubbing or fitment issues. Should be safe to assume the BFG in the same size should fit the same, yes?
Bus is a stock height 1960 Kombi running stock 15” wheels with a small nut trans/RGB’s.
Anyone out there running these BFGs on an early Bus/small nut?
Thanks!
‘60 Kombi, The “Bob Dowell Van”
EJZero1
EJZero1 is offline
PostPosted: Wed Oct 09, 2024 7:00 pm    Post subject: Re: Large tire/big meats - Stock suspension Bus thread Reply with quote
Closing the loop for archival purposes.
The BF Goodrich T/A KO2’s in 215 75 15 wii indeed fit on a 1960 Kombi with a stock small nut tranny/RGB’s.
Excellent ride with remarkable improvement over the old Kum Ho’s (same size) that I replaced.
cdennisg
cdennisg is offline
PostPosted: Wed Oct 09, 2024 7:04 pm    Post subject: Re: Large tire/big meats - Stock suspension Bus thread Reply with quote
Curious, what was improved over the Kum Ho's? Noise, handling, tread wear, traction, all of the above?
EJZero1
EJZero1 is offline
PostPosted: Wed Oct 09, 2024 7:25 pm    Post subject: Re: Large tire/big meats - Stock suspension Bus thread Reply with quote
Kum Ho’s were old and run out, and not LT rated. Only driven these new BFG’s for a short drive, but handling feels much more sure footed. No noticeable increase in noise, but my Kombi is an empty tin can right now, so quite noisy in its own right.
Time will tell ref tread wear and traction. Wanted a tire that I would be confident in taking on dispersed camping trips. Initial impression is that these should fit the bill very nicely.
Saul Koll
Saul Koll is offline
PostPosted: Wed Oct 09, 2024 11:22 pm    Post subject: Re: Large tire/big meats - Stock suspension Bus thread Reply with quote
Those really look great!
mtnbus
mtnbus is offline
PostPosted: Thu Oct 10, 2024 6:15 am    Post subject: Re: Large tire/big meats - Stock suspension Bus thread Reply with quote
Im happy with the bfgs
they look great on your rig!
AKdude
AKdude is offline
PostPosted: Fri Nov 29, 2024 8:37 pm    Post subject: Re: Large tire/big meats - Stock suspension Bus thread Reply with quote
205 75 15 AT2 Grabbers on my '58, good fit, tough enough, on/off road, quiet, nice ride, 4ply on stock rims. Getting hard to find. Next set going to 215 75 15 KO2's ,a bit taller, but a 6ply rating, more meat for overlanding.
Fish
Fish is offline
PostPosted: Fri Nov 29, 2024 9:49 pm    Post subject: Re: Large tire/big meats - Stock suspension Bus thread Reply with quote
Wow, that's a beautiful bus.
Prosit!
# 303 and #156
AKdude
AKdude is offline
PostPosted: Sat Nov 30, 2024 6:45 pm    Post subject: Re: Large tire/big meats - Stock suspension Bus thread Reply with quote
Been running General Grabber's 205 75 15's for years, no complaints. Next tire change will be BFG KO2'S 215 75 15's for a stronger sidewall and 6ply rating. Price difference is closer now when KO2'S are on sale, so stepping up. Thanks, Fish, glad you like the HiBearN8R
Buskraut Premium Member
Buskraut is offline
PostPosted: Sat Nov 30, 2024 7:21 pm    Post subject: Re: Large tire/big meats - Stock suspension Bus thread Reply with quote
Does anyone know the widest 14" tire that will fit in a rear spare tire well on a walk-thru bus? I'm planning on converting to 195/75/14's, but wondering if I need to go to a 185 for the spare.
Erik S
'65 Type 251 / Deluxe
'03 Eurovan MVWK
Malokin Martin
Malokin Martin is offline
PostPosted: Sun Dec 01, 2024 12:03 am    Post subject: Re: Large tire/big meats - Stock suspension Bus thread Reply with quote
Buskraut wrote:
Does anyone know the widest 14" tire that will fit in a rear spare tire well on a walk-thru bus? I'm planning on converting to 195/75/14’s, but wondering if I need to go to a 185 for the spare.
I just use the stock bug size tire on a stock bus rim. It’s definitely not matchy matchy but it fits, it’s a lot cheaper and how often do you use the spare anyway. I believe the 195 size stated above would fit as that’s a stock(ish) bug sized tire.
cdennisg
cdennisg is offline
PostPosted: Sun Dec 01, 2024 10:28 am    Post subject: Re: Large tire/big meats - Stock suspension Bus thread Reply with quote
Also, if the slightly larger than stock size spare just barely down't fit, deflate and carry some kind of small compressor on board.
Buskraut is offline
PostPosted: Mon Dec 02, 2024 11:21 pm    Post subject: Re: Large tire/big meats - Stock suspension Bus thread Reply with quote
Thanks for the feedback. Unless I hear otherwise, I'll get 4 195's mounted once my wheels are painted (Huge PITA... had to strip chrome from chrome-crazy PO, first by dipping which was semi-effective, then sandblasting, hammering on new hubcap clips, spraying with self-etching primer, then semi-gloss black, sealing joints to prevent rust in the cracks, then L82 silver white/clear coat... almost done!).
Based on the amount of spare tire well clearance I'll decide what size tire to use on the 5th wheel. Will report back...
Erik S
'03 Eurovan MVWK
zehbeh
zehbeh is offline
PostPosted: Tue Dec 03, 2024 12:10 am    Post subject: Re: Large tire/big meats - Stock suspension Bus thread Reply with quote
I have 15" wheels, and I have a 195/80/R15 in the rear spare tire well of my 64 walk through bus. Theoretical all 195s should have the same width, so your 195 R14 should fit in too.
Page 104 of 105
