Terry Gaudet Samba Member
Joined: March 11, 2004 Posts: 400 Location: New Brunswick, Canada
Posted: Sun Jun 23, 2024 4:08 am Post subject: Re: Large tire/big meats - Stock suspension Bus thread |
Hi Jake,
Can you let us know if there was any installation or rubbing issues with the Crosswind tires. _________________ Terry Gaudet
1950 Beetle Standard
1955 Canadian Custom
1956 Kombi w/SO23 kit
1965 Kombi walkthrough
1965 Double Cab |
Stocknazi Samba Member
Posted: Sun Jun 23, 2024 2:38 pm Post subject: Re: Large tire/big meats - Stock suspension Bus thread |
Anyone know what the largest size tire (stock 15 inch bus wheel) that can be used on a flat lip wheel well bus?
I have some 225/70 15 tires that I'd like to use, but suspect they may be a little wide. _________________ WANTED:
Thomas Jefferson |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20851 Location: Sandpoint, ID
Posted: Sun Jun 23, 2024 9:35 pm Post subject: Re: Large tire/big meats - Stock suspension Bus thread |
Stocknazi wrote: |
I have some 225/70 15 tires that I'd like to use, but suspect they may be a little wide. |
You have the tires, you have some wheels, and you have a bus? Throw a couple on there and report back to us. _________________ Confusious say it takes it takes two wipes to know you need three, but it takes three wipes to know it only needed two. |
Posted: Mon Jun 24, 2024 6:51 am Post subject: Re: Large tire/big meats - Stock suspension Bus thread |
cdennisg wrote: |
Stocknazi wrote: |
You have the tires, you have some wheels, and you have a bus? Throw a couple on there and report back to us. |
I may have to do just that. I know a 215/75-15 will fit (barely), but the 225/75-15 is 0.4 inches wider, so it's gonna be close. _________________ WANTED:
Thomas Jefferson |
BarryL  Samba Member
Joined: November 01, 2004 Posts: 15274 Location: Casa de Oro, California
Posted: Mon Jun 24, 2024 6:26 pm Post subject: Re: Large tire/big meats - Stock suspension Bus thread |
Stocknazi wrote: |
...but the 225/75-15 is 0.4 inches wider, so it's gonna be close. |
Stocknazi wrote: |
I have some 225/70 15 tires... |
Is the "70" a misprint or is the "75"? |
LostnaWesty Samba Member
Posted: Fri Jun 28, 2024 4:51 am Post subject: Re: Large tire/big meats - Stock suspension Bus thread |
stock suspension
grabbers 27x8.5x14
EJZero1 Samba Member
Joined: June 12, 2004 Posts: 184 Location: Colorado Springs
Posted: Sun Sep 22, 2024 3:52 pm Post subject: Re: Large tire/big meats - Stock suspension Bus thread |
Been waiting for my Grabber ATX 205 75 15’s for 2 months. Apparently a nationwide back order situation with no ship date in sight. Looking at other options now.
Primary contender is the BFG AT KO2, but closest size is a 215 75 15. Bus is currently running some very old Kumhos in that 215 75 15 size and they fit well with no rubbing or fitment issues. Should be safe to assume the BFG in the same size should fit the same, yes?
Bus is a stock height 1960 Kombi running stock 15” wheels with a small nut trans/RGB’s.
Anyone out there running these BFGs on an early Bus/small nut?
Thanks! _________________ ‘60 Kombi, The “Bob Dowell Van” |
Posted: Wed Oct 09, 2024 7:00 pm Post subject: Re: Large tire/big meats - Stock suspension Bus thread |
Closing the loop for archival purposes.
The BF Goodrich T/A KO2’s in 215 75 15 wii indeed fit on a 1960 Kombi with a stock small nut tranny/RGB’s.
Excellent ride with remarkable improvement over the old Kum Ho’s (same size) that I replaced.
Posted: Wed Oct 09, 2024 7:04 pm Post subject: Re: Large tire/big meats - Stock suspension Bus thread |
Curious, what was improved over the Kum Ho's? Noise, handling, tread wear, traction, all of the above? _________________ Confusious say it takes it takes two wipes to know you need three, but it takes three wipes to know it only needed two. |
Posted: Wed Oct 09, 2024 7:25 pm Post subject: Re: Large tire/big meats - Stock suspension Bus thread |
cdennisg wrote: |
Curious, what was improved over the Kum Ho's? Noise, handling, tread wear, traction, all of the above? |
Kum Ho’s were old and run out, and not LT rated. Only driven these new BFG’s for a short drive, but handling feels much more sure footed. No noticeable increase in noise, but my Kombi is an empty tin can right now, so quite noisy in its own right.
Time will tell ref tread wear and traction. Wanted a tire that I would be confident in taking on dispersed camping trips. Initial impression is that these should fit the bill very nicely. _________________ ‘60 Kombi, The “Bob Dowell Van” |
Saul Koll Samba Member
Joined: September 28, 2008 Posts: 196 Location: Portland
Posted: Wed Oct 09, 2024 11:22 pm Post subject: Re: Large tire/big meats - Stock suspension Bus thread |
Those really look great! |
mtnbus Samba Member
Posted: Thu Oct 10, 2024 6:15 am Post subject: Re: Large tire/big meats - Stock suspension Bus thread |
Im happy with the bfgs
they look great on your rig! |
AKdude Samba Member
Joined: May 16, 2016 Posts: 46 Location: The Far North
Posted: Fri Nov 29, 2024 8:37 pm Post subject: Re: Large tire/big meats - Stock suspension Bus thread |
205 75 15 AT2 Grabbers on my '58, good fit, tough enough, on/off road, quiet, nice ride, 4ply on stock rims. Getting hard to find. Next set going to 215 75 15 KO2's ,a bit taller, but a 6ply rating, more meat for overlanding. |
Fish Samba Member
Joined: December 05, 2000 Posts: 5933 Location: OB. It's beside the point.
AKdude Samba Member
Posted: Sat Nov 30, 2024 6:45 pm Post subject: Re: Large tire/big meats - Stock suspension Bus thread |
Been running General Grabber's 205 75 15's for years, no complaints. Next tire change will be BFG KO2'S 215 75 15's for a stronger sidewall and 6ply rating. Price difference is closer now when KO2'S are on sale, so stepping up. Thanks, Fish, glad you like the HiBearN8R |
Buskraut  Samba Member
Joined: March 22, 2011 Posts: 71 Location: San Jose, CA 95125
Posted: Sat Nov 30, 2024 7:21 pm Post subject: Re: Large tire/big meats - Stock suspension Bus thread |
Does anyone know the widest 14" tire that will fit in a rear spare tire well on a walk-thru bus? I'm planning on converting to 195/75/14's, but wondering if I need to go to a 185 for the spare. _________________ Erik S
'65 Type 251 / Deluxe
'03 Eurovan MVWK |
Malokin Martin Samba Member
Posted: Sun Dec 01, 2024 12:03 am Post subject: Re: Large tire/big meats - Stock suspension Bus thread |
Buskraut wrote: |
Does anyone know the widest 14" tire that will fit in a rear spare tire well on a walk-thru bus? I'm planning on converting to 195/75/14’s, but wondering if I need to go to a 185 for the spare. |
I just use the stock bug size tire on a stock bus rim. It’s definitely not matchy matchy but it fits, it’s a lot cheaper and how often do you use the spare anyway. I believe the 195 size stated above would fit as that’s a stock(ish) bug sized tire. |
Posted: Sun Dec 01, 2024 10:28 am Post subject: Re: Large tire/big meats - Stock suspension Bus thread |
Malokin Martin wrote: |
Buskraut wrote: |
Also, if the slightly larger than stock size spare just barely down't fit, deflate and carry some kind of small compressor on board. _________________ Confusious say it takes it takes two wipes to know you need three, but it takes three wipes to know it only needed two. |
Posted: Mon Dec 02, 2024 11:21 pm Post subject: Re: Large tire/big meats - Stock suspension Bus thread |
Thanks for the feedback. Unless I hear otherwise, I'll get 4 195's mounted once my wheels are painted (Huge PITA... had to strip chrome from chrome-crazy PO, first by dipping which was semi-effective, then sandblasting, hammering on new hubcap clips, spraying with self-etching primer, then semi-gloss black, sealing joints to prevent rust in the cracks, then L82 silver white/clear coat... almost done!).
Based on the amount of spare tire well clearance I'll decide what size tire to use on the 5th wheel. Will report back... _________________ Erik S
'03 Eurovan MVWK |
zehbeh Samba Member
Joined: February 16, 2008 Posts: 256 Location: Stuttgart
Posted: Tue Dec 03, 2024 12:10 am Post subject: Re: Large tire/big meats - Stock suspension Bus thread |
I have 15" wheels, and I have a 195/80/R15 in the rear spare tire well of my 64 walk through bus. Theoretical all 195s should have the same width, so your 195 R14 should fit in too. |
