schwim Samba Member
Joined: May 18, 2008 Posts: 310 Location: Coastal VA, 'Murica
Posted: Thu Nov 28, 2024 3:58 pm Post subject: Need help understanding what a hard start relay helps |
Hi there everyone!
I understand what they do but what I don't understand what it helps. Not the cranking power, right? It shortens the length of the relay trigger wire but if the starter turns the engine, is it of no benefit?
Since the power for the starter is a battery less than 2 feet from it, it's not increasing the cranking power, correct?
Would a bug in need of one just not engage the starter?
Thanks for your time! _________________ Zippy the Wonderbug's achingly slow meandering toward roadworthiness |
richparker Samba Member
Joined: November 24, 2011 Posts: 7505 Location: Durango, CO
Posted: Thu Nov 28, 2024 4:12 pm Post subject: Re: need help understanding what a hard start relay helps |
It shortens the distance the power needs to travel to engage the starter. Beneficial in a bus, I one in mine, but not needed in a Bug. _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build |
OldSchoolVW's  Samba Member
Joined: July 03, 2020 Posts: 1425 Location: San Diego
Posted: Thu Nov 28, 2024 5:47 pm Post subject: Re: need help understanding what a hard start relay helps |
Using it helps extend the service life of the ignition switch because only the small amount of current necessary to trigger the relay passes through the ignition switch instead of the current needed to engage the starter. Original switches were better built (more substantial contacts) so could handle this current with no problem. 60 or so years later, those contacts have become worn. Usually still good enough to carry enough current to trigger a relay, but struggle to deliver the necessary current to the starter solenoid. Most new replacement ignition switches just aren't built as well, so a HSR will help keep those working longer. Installing one is easy, inexpensive, and I don't see a downside to doing it. _________________ Tom
"Following distance is proportional to IQ."
"It's okay to think."
"If you don't do it this year, you'll be one year older when you do." Warren Miller
'63 Beetle Sedan
'69 Beetle Sunroof
'70 Beetle Sedan
'73 Type 3 Fastback |
wdfifteen Samba Member
Posted: Fri Nov 29, 2024 9:18 am Post subject: Re: need help understanding what a hard start relay helps |
I've seen a lot of people put in "hard start" relays when what they really needed is a new starter bushing or to clean the battery terminals. As has been stated, the only advantage is to take some of the current load off of the ignition switch. |
ashman40 Samba Member
Joined: February 16, 2007 Posts: 16577 Location: North Florida, USA
Posted: Fri Nov 29, 2024 12:14 pm Post subject: Re: need help understanding what a hard start relay helps |
schwim wrote: |
Since the power for the starter is a battery less than 2 feet from it, it's not increasing the cranking power, correct? |
You are correct. The starter motor is powered directly from the battery cable which is only a few feet long. As long as the connections at the battery and starter solenoid stud are clean you get max current flow thru the starter motor. This is in the range of 100A+ !!
The current flowing to the starter motor is controlled by the starter solenoid mounted to the side of the starter motor pictured below.
The starter solenoid has two functions...
1) close the contacts between the battery cable and the starter motor, allowing current to flow and crank the engine
2) extend the drive pinion gear so it engages the flywheel/flexplate teeth so the starter motor can rotate the crankshaft
To extend the pinion drive and close the contacts the starter solenoid has an internal electromagnetic coil/solenoid that is powered by the #50 wire coming from the ignition switch. Activating/energizing the solenoid it will draw around 35A over the #50 wire.
Consider the path this 30A current must flow over the stock wiring so it can reach the starter solenoid....
Battery terminal
Fuse box (or headlight switch)
Ignition switch
Starter solenoid #50 terminal)
The current leaving the battery travels around 20ft back and forth to the front of the car before reaching the solenoid at the rear of the car. Depending on the age of the wiring this could be adding a measurable amount of resistance to the circuit path. More resistance from old wires/old switch contacts/old connections means less current actually making it to the starter solenoid. For Beetles still running the original wiring, the voltage reading at the end of the #50 wire may drop to as little as 9.0v (my old wiring and OE ignition switch). Cleaning up the connections along the way will greatly improve the current that actually makes it to the end of the circuit to energize the solenoid. But also consider you are pumping 30A+ thru the ignition switch contacts EVERY time you turn the key to START. Over time this will burn the internal contacts of the switch. After a few decades the START circuit of the ignition switch may itself become the cause of high resistance or have spots on the contact surface that are no longer conductive; meaning you must wiggle the key to "find a sweet spot" so the starter cranks.
The starter solenoid itself is a type of relay, allowing a small current (30A+) to switch a larger current (100A+). But the 30A over the #50 circuit will eventually burn the ignition switch contacts, especially. What if you could reduce the current passing thru the ignition switch contacts from 30A down to 0.05A?? THAT is what the Hard Start Relay does when you use the small Bosch/Tycho style SPST/SPDT relay. The 85/86 circuit thru these relays only requires around 50~100mA to activate. This extends the life of the ignition switch contacts for many more years as they no longer carry a large current.
This is also why I am not a proponent of using Ford-style external starter solenoids as HSRs. These larger relays function the same but still draw 10-20A to energize. That may be less than the stock solenoid 30A but still much higher than the 0.05A of the Bosch relays. And these larger relays tend to be more expensive. _________________ AshMan40
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 25952 Location: Olympia Wash Rinse & Repeat
Posted: Fri Nov 29, 2024 12:24 pm Post subject: Re: need help understanding what a hard start relay helps |
schwim wrote: |
Yes and no. The ignition switch does not turn on the starter motor, the starter solenoid does. When you turn the key the electrical flow goes to the starter solenoid. This causes the the electromagnet of the solenoid to pull the starter gear into the flywheel gear. When those gears are fully engaged, deep inside the starter solenoid a pair of contacts are bridged across to send electrical flow directly from the battery to the starter motor. So electrical flow goes via from one to the other of the two big threaded posts on the front of the solenoid without this electrical flow going anywhere near the dashboard. A weak pull of the starter solenoid will cause weak contact of the bridge contact points in the starter solenoid and thusly a voltage drop in those connections going to the starter motor.
A hard start relay does help extend the lifespan of the ignition switch, but might as well install that relay up next to the ignition switch, then out of the weather that water is sprayed up under the VW when driving. Even better ignition switch protection from wear and tear would be to just install a hidden push switch and not have to turn the ignition switch to the "Start" position.
Better results than just blindly installing a hard start relay is to clean, dielectric grease, and tighten down ALL wiring connections and ALL grounds after cleaning those connection surfaces. The dielectric grease seals out both water and oxygen from getting into the connections so corrosion does not cause voltage drops.
Just the starter grounds are many when you really think of it. The starter solenoid grounds to the starter motor housing. The starter motor housing grounds to the transaxle. The transaxle grounds to the body via the ground body strap. Then finally the body needs to ground to the battery via the battery ground strap. ANY of those ground connections if loose or corroded or even painted over will cause starting problems even if all the wiring connections on the positive side are clean & tight to perfection.
If one needs a hard start relay due to slow/hard starting, most likely the other electrics onboard are also being adversely affected. Having bright lights mean you can see better and other drivers around you can see you better, faster wipers means better to see the road ahead of you, louder or any horn that does not work with wipers and all the lights working can mean the difference of being able to give that other driver a heads up you are there to avoid an accident, etc...
If one is running the earlier bell shaped headlight switch, those need to be opened up to solder all of the internal and external riveted together connections to remove voltage drops. Same for most any pre-1968 VW fuse boxes with the loose packed in brass clips that need to be soldered together in each slot. Sometime in later 1967 model year VW did finally spot weld those clips together, and for the 1968 model year was the standard for all VW types.
https://www.thesamba.com/vw/forum/viewtopic.php?t=483901&highlight=fuse+box+soldering
https://www.type2.com/library/electris/vw-hauptlicht-schalter.html _________________ In Stereo, Where Available! |
zerotofifty Samba Member
Posted: Fri Nov 29, 2024 8:25 pm Post subject: Re: need help understanding what a hard start relay helps |
wdfifteen wrote: |
A second advantage is shorter wire path from battery to solenoid, which means less resistance for a given gauge wire.
with less resistance you get more power to the solenoid, which means the solenoid can more easily operate, and make better contact between the starter motor terminals
this can be very important in cold condition when grease and oil is thicker, making the engine and solenoid harder to function, and battery voltage lower. this relay addition, the hard start relay can help cure cold cranking issues. |
EVfun  Samba Member
Posted: Fri Nov 29, 2024 9:31 pm Post subject: Re: need help understanding what a hard start relay helps |
If you attempt to measure the resistance of the starter solenoid (terminal 50 to ground on the starter) you will find it is nearly a dead short to ground. There are 2 windings on the starter solenoid. One is heavy and low resistance and it will draw a huge current surge when you first engage the starter. The other one is more turns of smaller gauge wire, this one hold the starter in. A reason for this is to have lots of kick to engage the starter gear. A stout relay right next to the starter can help provide that current surge.
Below is a picture from SW-EM:
Wildthings wrote: |
Blue Baron VW Aficionado
Joined: June 16, 2006 Posts: 28186 Location: Free State of Florida
Posted: Sat Nov 30, 2024 1:04 am Post subject: Re: need help understanding what a hard start relay helps |
richparker wrote: |
It shortens the distance the power needs to travel to engage the starter. Beneficial in a bus, I one in mine, but not needed in a Bug. |
I install them in everything, including bugs. We had a Mexi Beetle that was just a few years old, and one day, turn the key and nothing happens. The hard start relay cured it. Gene Berg said it was a common problems on VWs he serviced back in the '60s when he worked for VW.
richparker wrote: |
THAT is what the Hard Start Relay does when you use the small Bosch/Tycho style SPST/SPDT relay. |
Can we get more information on this relay, what it looks like, where to buy it, part number and so forth? _________________ We are striving for perfection, to make our cars run forever, if possible.
Heinz Nordhoff |
RWK Samba Member
Posted: Sat Nov 30, 2024 8:44 am Post subject: Re: need help understanding what a hard start relay helps |
A starter button installed to bypass a failing ignition switch helps also, it also adds the ability to crank engine for oil pressure when it's sat for a time, adds a degree of theft protection also. _________________ 73 Type 181
63 Type 113
63 Type 261- 428 071
62 Type 241-378 025 178 530 |
Posted: Sat Nov 30, 2024 9:32 am Post subject: Re: need help understanding what a hard start relay helps |
For 12 volt cars...
https://www.jbugs.com/product/WR-1.html
Or do a google search for VW Hard Start Relay. many sellers
I run a 12 volt 30 amp relay on my 12 volt car
For a 6 volt car, you need a 6 volt relay, 60 amps should do it.
When voltage is half as is 6 volt verses 12 volt, then the amperage (current) should be doubled. This is because Amps x Volts = watts. Watts is power and that is what is doing the "work" in an electric system. Example an 8 amp 6 volt light bulb is 48 watts (6 x 8 = 48 ) the light bulb is as bright as a 48 watt 12 volt light bulb, and that 12 volt 48 watt bulb uses 4 amps (4 Amp x 12 volt = 48 watt)
Also note that the minimum required wire diameter is determined by the amps that pass thru it, NOT the voltage. Since a 6 volt car uses more amps in a circuit than a 12 volt car, the wires used in the 6 volt car MUST be thicker in order to pass that twice higher amps with similar resistive losses as in the 12 volt lower amp circuit. If the wire is too thin then there will be losses in that wire that are unacceptable, this means that the voltage coming out of that wire will be lower. When voltage is lower do to losses, that is known as voltage drop. Too thin a wire means too much voltage drop.
So besure that the wires you use are rated for the amps you intend to pass thru them.
Here is a very handy tutorial and wire size chart for wiring. always select the recommended wire diameter or larger for your intended amps...
https://www.westmarine.com/west-advisor/Marine-Wire-Size-And-Ampacity.html
Have fun, it is electrifying!!!!  |
Helfen Samba Member
Joined: January 19, 2009 Posts: 3481 Location: Vulcania
Posted: Sat Nov 30, 2024 10:39 am Post subject: Re: need help understanding what a hard start relay helps |
wdfifteen wrote: |
Can also be the voltage drop between the key switch and the solenoid.
But the answer to the question what a hard start relay helps is; It helps to mask a problem that should have been done correctly. |
EVfun  Samba Member
Posted: Sat Nov 30, 2024 4:43 pm Post subject: Re: need help understanding what a hard start relay helps |
Helfen wrote: |
wdfifteen wrote: |
You know we are driving old economy cars. Perhaps it was just VWs saving a buck a car by not using large enough wires, or start switch contacts capable of handling the potential inrush current of a starter solenoid. This is the same company that didn't fuse the ignition coil circuit despite the circuit path running from the back of the car to the front of the car, and then back to the back of the car to the coil. They didn't fuse the headlight high beams until 1960 or the front parking lights on US models until at least 1966. They couldn't even be bothered to include a fuseable link.
Let me tell you a little story about another economy car, the Geo Metro (rebadged Suzuki). They ran the headlight wiring up the steering columm and through that switch on the stalk. It didn't drive headlight relays -- the full current of the headlights ran through the approximately 18 gauge wires and the 3mm spade terminals. It worked for them because it lasted longer than 3 years. But at 4 years you notice the headlights are little dim. Not wanting to dig too far I didn't find a problem. At about 6 years and 90k miles the headlights suddenly went out. I opened up the fuse box and steering column to chase the headlight wiring and found the blackened connections. I cleaned them all up the best I could and used them to run headlight relays. The headlights were brighter than when new, and they didn't dim again. _________________
Wildthings wrote: |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 79536 Location: Sneaking up behind you
Posted: Sat Nov 30, 2024 4:45 pm Post subject: Re: need help understanding what a hard start relay helps |
EVfun wrote: |
You know we are driving old economy cars. |
No one expected any of them to be on the road 20 years later, let alone 50+ years.
And with the lack of quality aftermarket parts, you should do what you an to save the original parts. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
Posted: Sat Nov 30, 2024 9:53 pm Post subject: Re: need help understanding what a hard start relay helps |
Blue Baron wrote: |
ashman40 wrote: |
Can we get more information on this relay, what it looks like, where to buy it, part number and so forth? |
You can find these relays at most FLAPS. Links below.
https://www.autozone.com/electrical-and-lighting/relay-and-resistors/b/brand/novita
https://shop.advanceautoparts.com/web/SearchResult...;langId=-1
https://www.oreillyauto.com/detail/c/novita-techno...&pos=7
Look in the electrical connector section for a small black box about 1-inch square. They will be marked "SPST" (4-prong) or "SPDT" (5-prong). You can use either type for a HSR. They are rated by the number of amps they carry (20A/30A/40A). You probably want a 30A or 40A one.
They look like this.
If you have an Amazon account you can buy a set of these relays along with the wired pigtail plug making them easy to remove/replace.
It is very useful to keep a few handy to upgrade old circuits or install new ones to carry a higher load. _________________ AshMan40
pastellgreen Samba Member
Joined: January 06, 2012 Posts: 1133 Location: Germany
Posted: Sun Dec 01, 2024 2:06 am Post subject: Re: need help understanding what a hard start relay helps |
Glenn wrote: |
EVfun wrote: |
And with the lack of quality aftermarket parts, you should do what you an to save the original parts. |
Yes.
But I can vote for WW harnesses, as they are good quality and help improving the light as well the starting issues, together with the whole contact cleaning procedures... |
schwim Samba Member
Posted: Sun Dec 01, 2024 8:06 am Post subject: Re: need help understanding what a hard start relay helps |
pastellgreen wrote: |
Yes.
I ordered the 6v relay kit from WW. What do you mean by "improving the light"? _________________ Zippy the Wonderbug's achingly slow meandering toward roadworthiness |
Glenn  Mr. 010
Posted: Sun Dec 01, 2024 10:34 am Post subject: Re: need help understanding what a hard start relay helps |
I made my own, much like that one. Works fine. But I sleaved the terminals at the relay. The hot ones really should be sleaved such that if in the wire were to be removed from the relay, the sleave on over the connector will prevent the connector from shorting to a ground.
Note them relays can be had at a wrecker for about a buck each, carry some spares! Many cars have this type of relay, so check out your local wrecker for savings. Although finding a 6 volt version at the wrecker might be a very rare event. 12 volt relays are abundant at wreckers.
There is no need for the special relay holding socket, you can run the wire ends direct to the relay as Mr. Glenn has shown. But a color code wire or tags on wires is a good idea in this case so in as the wires can easily be identified for attachment. If the wires are not marked, service replacement of the relay should be done one wire at a time so as they dont get mixed up.
As for the improve of lighting comment, I assume what is meant is that relays such as this can be used to reduce voltage loss to lighting , headlights, specifically but also applicable for other lights I have added relays for headlights on several cars with nice results, both 6 and 12 volt cars can sometimes benefit greatly from this. |
