lost compression
[email protected]
trjschaefer@outlook.com is offline
PostPosted: Sat Feb 22, 2025 9:31 am    Post subject: lost compression Reply with quote
I have a 71bus lost Compression can I just rebuild the top end
67rustavenger
67rustavenger is offline
PostPosted: Sat Feb 22, 2025 10:09 am    Post subject: Re: lost compression Reply with quote
Lost compression? Go find it! Very Happy
You could do a topend refresh but, you'll likely find other issues, depending on the mileage since it was last rebuilt.
Remove the engine, tear the topend down and inspect the pistons and heads carefully.
While the cylinders and pistons are off the engine, look through the case/cylinder registers and have a look at the camshaft and lifter surfaces for damage.
Check your crankshaft end play. If it's more than .007-.008" it is likely time to go through the whole engine and replace the bearings/camshaft/lifters and seals.
You won't know what you have going on until you tear it down and inspect the parts.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
airschooled
Air-Schooled
airschooled is offline
PostPosted: Sat Feb 22, 2025 10:30 am    Post subject: Re: lost compression Reply with quote
Welcome to TheSamba, where we need details, and occasionally punctuation marks. Help us help you!
Perhaps you could just adjust the valves… but it’s kinda hard to help answer your question without having far more information. Did it happen suddenly? All cylinders or just one? What’s your mechanical skill set like?
Robbie
www.airschooled.com
Road trip reports and tech blog:
SGKent Premium Member
SGKent is offline
PostPosted: Sat Feb 22, 2025 2:38 pm    Post subject: Re: lost compression Reply with quote
Welcome to thesamba.
You need to come back and tell us more for anyone here to really help you.
George Carlin:
Skills@EuroCarsPlus:
[email protected]
PostPosted: Sun Feb 23, 2025 9:30 am    Post subject: Re: lost compression Reply with quote
talked to someone that use to work on them he said that the engine was probably over heated and burnt a valve the engine has about 10 to 12 thousand miles on it
Xevin Premium Member
Xevin is offline
PostPosted: Sun Feb 23, 2025 10:09 am    Post subject: Re: lost compression Reply with quote
The people who responded actually work on them currently. You have over 100 combined years of VW knowledge that replied.
How did this “Someone” you talk to determine it overheated? Perhaps you gave that “Someone” more information, pictures, or they had their hands on your engine?
Keep on Busin'
67rustavenger wrote:
Clatter wrote:
skills@eurocarsplus wrote:
SGKent wrote:
airschooled
Air-Schooled
PostPosted: Sun Feb 23, 2025 11:11 am    Post subject: Re: lost compression Reply with quote
Or someone f’d up a valve adjustment. Or didn’t adjust the valves. Or didn’t measure correctly. Or your engine is actually fine and it’s just slow like they all are.
Trust me, rebuilding an engine costs a little more than making sure your basics are covered. Like, four thousand times more.
Robbie
www.airschooled.com
dodger tom Premium Member
dodger tom is offline
PostPosted: Sun Feb 23, 2025 1:31 pm    Post subject: Re: lost compression Reply with quote
you haven’t given any specific information about your situation despite being asked several times.
start with year of bus and engine type.
go back, and read each post, and answer each question.
if you don’t know how to answer, ask for knowledgeable vw mechanics or samba folk in your area.
then ask for a list of questions your could ask them.
the guy saying it might be a burnt valve might not be the best to help you troubleshoot your problem.
[email protected]
PostPosted: Sun Feb 23, 2025 8:48 pm    Post subject: Re: lost compression Reply with quote
I have 1971 bus with a 1600 dual port was driving down the high way at 60 mph when all if the sudden it started losing power was able to get i home and that is where it is now. if anyone knows of someone that works on them in my area I would appreciate the help
SGKent is offline
PostPosted: Mon Feb 24, 2025 2:31 am    Post subject: Re: lost compression Reply with quote
tell us about your mechanical skills. By chance did the generator light come on while this was happening? Were there any noises, smoke, oil pouring out? Could be as simple as a wire or hose came loose. Sometimes it isn't the engine that lost power - meaning that the clutch slipped, or a CV joint started slipping etc..
George Carlin:
lil-jinx
lil-jinx is offline
PostPosted: Mon Feb 24, 2025 8:30 am    Post subject: Re: lost compression Reply with quote
it could be as simple as a clogged fuel filter,dirty fuel,burnt points,
over heat in Mi at this time of year,is that even possible
1968 Dune Buggy sold dec 2024
1974 parts bus
[email protected]
PostPosted: Mon Feb 24, 2025 8:39 am    Post subject: Re: lost compression Reply with quote
no lights on dash but the plug wires on #3 and #4 were melted and they had the lowest compression#3 was 35 and #4 was 0
Abscate
Abscate is offline
PostPosted: Mon Feb 24, 2025 8:56 am    Post subject: Re: lost compression Reply with quote
The engine comes out to be evaluated in that case. I would expect bothe head and piston and cylinder damage.
$1500 for a good used engine installed, 3x that for a rework of current engine, if possible
[email protected]
PostPosted: Mon Feb 24, 2025 9:30 am    Post subject: Re: lost compression Reply with quote
Could I just rebuild the top end or would the bottom end need rebuilding too
Shonandb Premium Member
Shonandb is offline
PostPosted: Mon Feb 24, 2025 11:50 am    Post subject: Re: lost compression Reply with quote
It could be possible but you won't know until you pull the heads and cylinders off to see what you're up against.
Previous 1973 Panel Bus:
Click to view image
SGKent is offline
PostPosted: Mon Feb 24, 2025 2:22 pm    Post subject: Re: lost compression Reply with quote
Turn the key on and see if the alternator/generator warning light comes on. Then check to see if the fan belt came off. If it did, the engine needs to be completely rebuilt. Bearing material can sluff off when an engine gets hot enough to melt wires. If the fan belt is there, with the engine OFF, turn the generator/alternator and see if the belt slips. That will tell you why it melted, unless critters moved into it over the winter and built a nest.
George Carlin:
timvw7476
timvw7476 is offline
PostPosted: Mon Feb 24, 2025 3:09 pm    Post subject: Re: lost compression Reply with quote
There's the thrust clearance, measured by how far the crankshaft shifts forward & backward in the main bearing saddles, that determines how 'tired' or spent the bottom of the engine is. The other ways of checking include the rod side clearance (got to pull heads/pistons for that)
And pulling a rod cap. If the rod bearing cap surface is not worn to the point of showing copper/brass through the soft overlay, you have an idea of how many miles the engine has run. This all takes time. The thrust clearance is the quickest seeing as it can be done with the engine pulled but not disassembled.
The more you want to know, the more you have to unbolt : l
Amskeptic
Amskeptic is offline
PostPosted: Mon Feb 24, 2025 3:21 pm    Post subject: Re: lost compression Reply with quote
I think your best next step is to get an actual air-cooled VW expert to look at the engine.
Speculation is fun and all, but cold hard data, a thorough diagnosis, and a repair plan, is your best path forward to getting it running again.
Along the way, you will learn what warning signs to catch before serious engine damage occurs.
Colin
www.itinerant-air-cooled.com
www.facebook.com/groups/324780910972038/
[email protected]
PostPosted: Mon Feb 24, 2025 4:49 pm    Post subject: Re: lost compression Reply with quote
The problem I have is that I can't find anyone in my area that knows Volkswagen air cooled engines. If anyone knows of someone in west Michigan I would appreciate the help
mikedjames
mikedjames is offline
PostPosted: Tue Feb 25, 2025 10:24 am    Post subject: Re: lost compression Reply with quote
If you are dedicated enough, you will find plenty of basic videos on Youtube showing engine building.
If you were happily hammering a 1600 at 60mph without having given it a basic set of adjustments, it is easy to melt parts of the engine.
Trouble is that if you melt a hole in a piston through the classic "set the timing by ear, it goes like a train" , it sprays melted aluminium dust down into the engine. It then gets circulated round as a powder and gets everywhere. So the engine has to come totally apart for cleaning, to remove all that metal.
But there is nothing stopping anybody from performing a rebuild on a VW engine if you have the space.. or even in the back of the bus..
. That was a rebuild I did a few years back .
Ancient vehicles and vessels
