Hardware for 2.1 Engine + Misc other locations
djkeev
djkeev is offline
PostPosted: Fri Nov 01, 2013 4:25 pm    Post subject: Hardware for 2.1 Engine + Misc other locations Reply with quote
I'm rebuilding my 1986 2.1 WBX, during disassembly galvanic corrosion has claimed a few fasteners. The exhaust studs are much worse for wear as well.
I started pulling out the hardware to determine what sizes and hardness I needed and darn if I didn't end up cleaning and cataloging the whole mess of them!
Thought I'd post what I have here so that others seeking replacement hardware will not need to do the figuring I just completed.
All sizes are metric. The length was at times up for interpretation so what length I chose was very close, a few mm's either way most often will make no difference.
I've stumbled upon this web site which lists every piece of hardware needed. I usually just use Fastenal but may give this outfit a shot.......
https://www.belmetric.com/flange-bolts-jis-109-m8x125-flange-bolts-c-2_68.html
How the sizes are written.....
All bolts are standard Hex Head unless noted other wise, also all are machine threads unless noted otherwise.
Diameter x thread pitch x length ........ (Quantity)..... Brand...... Grade.........belmetric number
Rear Engine Carrier to Engine case
**** 10 x 1.5 x 85 ......... (2) .....KAMAX .... 8.8....BR10X85
**** 10 x 1.5 x 30 ......... (1) ..... 3F ........ 8.8.....BR10X30
**** Washers.... 10mm Wave Lock Washer ...... Quantity (3) ...WW10B
Rear Engine Carrier motor mounts
**** 8 x 1.25 Nuts ........ (4) ....... W ..... 8 ... NR8
Rear motor mounts to steel Cross Member
**** 10 x 1.5 x 50 ......(4) ..........KHS ....... 8.8 .... BR10X50P
**** 10mm x 1.5 Nuts ..... (4) ...... W .................. NR10
**** Washers .... None
Steel Cross Member to Body
**** 8 x 1.25 x 30 ........(4) .....B*T ........10.9 .... ALL THREADED.. BH8X30
**** 8mm Washers........ (4) ......... Extremely Thick .... WC8X20
**** 8 x 1.25 Lock Nuts ..... (4) ..... W ..CLASS 10 LOCK NUT .... NNH8
**** Double Drilled Steel Plate ......(2)
Oil Fill Tube to Case
**** 8 x 1.25 Nuts ....... (2) ....... W .... 8 ... NR8
**** 8mm Wave Washers (2)...................... WW8
**** 8 x 1.25 x 35 Stud .. (2) .................... S8X35F
Power Steering Pump to Bracket
**** 8 x 1.25 x 30 ......(1) .......KAMAX .... 8.8 ..... ALL THREADED .. BR8X30
**** 8mm Wave Washer .... (1) ...... WW8
**** 8mm Fender Washer ...(1) ....... WFE8X24
**** 10 x 1.5 x 70 ...........(1) ..... CARRIAGE BOLT .. NA
**** 10mm Nut ............(1) ........ H ... 8 .... NR10
**** 10mm Wave Washer .... (1) ................ WW10B
Power Steering Bracket to Engine
**** 8 x 1.25 x 30 .......(2) ........ KAMAX ...... 8.8 ... BR8X30
**** 8 x 1.25 x 55 .......(1) ........ KAMAX ...... 8.8 ... BR8X55
**** 8mm Heavy Flat Washer ... (3) ....................... WC8X20
Power Steering Reservoir to Body
**** 8 x 1.25 x 15 .......(2) ....... ESKA ......8.8 ... BR8X16
Power Steering pipe to Flexible hose to Pump Mount
**** 2 Rubber mounts, 6 x 1.0 Studs on each end
**** 6 x 1.0 Nuts........(4) ....... M ....... 8 .......... NR6
**** 6 x 1.0 x 15 ...... (1) ............3F ...... 8.8 ... BR6X16
Coil / Relay Bracket
**** 6 x 1.0 x 10 ...... (2) .......... ?.........8.8 .... BR6X10
**** 6mm Fender Washer ..... (2) .................... WFE6X18
**** size 10 x 1/2" Sheet Metal Screw, Phillips Head ...... (1)
Ground Wires to Body by Coil
**** 6 x 1.0 x 10 ......(2) ........... ? ....... 8.8 ... BR6X10
**** 6mm Flat Washer .... (2) ........................ WF6
While these were not installed, I choose to do so to provide a more secure ground using these external star washers.
*******6mm External Star Washer ..... (4) .....WSE6
Coolant Pressure Tank to Body
**** 5.5 x 10 Sheet Metal Screw ..... (2).......
**** 6mm Flat Washer ....... (2) .................. WF6
Coolant Fill Tank
**** 6 x 1.0 x 12 ....... (2) ......... ? ........ 8.8 .... BR6X12
**** 6mm Flat Washer ....(2) ............................ WF6
I choose to use Stainless Steel here because these bolt heads are outside of the body by the back bumper, mine were badly rusted.....
****** 6 x 1.0 x 12 .....(2) ....... BR6X12SS
****** 6mm Flat Washer .. (2) .. WF6SS
Water Pump
**** 8 x 1.25 x 44 Stud .... (3) ...................... S8X43 or S8X46
Coolant Pipe Right Side of Case to Water Pump
**** 8 x 1.25 Nut.............. (2) ....................... NR8
**** 8mm Flat Washer ....... (2) ...................... WF8
**** 8 x 1.25 x 35 Stud...... (2) ...................... S8X35F
Oil Tower top of Case
**** 6 x 1.0 Nut ...............(4) ...... M .....8 ......... NR6
**** 6mm Fender Washer .. (4) ........................... WFE6X18
**** 6 x 1.0 x 36 Stud.... (4) ............................. S6X35FULL
Mechanical Fuel Pump Block off Plate
**** 8 x 1.25 Nut .......(2) ........ M .......8 ......... NR8
**** 8mm Wave Washer .. (2) .......................... WW8
**** 8 x 1.25 x 48 Stud ... (2) .......................... S8X35F
Ground Screws to Head
**** 6 x 1.0 x 15 ....... (2) ........... ? ....... 8.8 ... BR6X16
**** 6mm Flat Washer .... (2) ........................... WF6
Air Conditioner Mounting to Steel Adjustment Bracket
**** 8 x 1.25 x 30 ...... (1) ........ CARRIAGE BOLT .. NA
**** 8 x 1.25 x 65 .......(1) ........ ALL THREADED ... BR8X60F
**** 8 x 1.25 Nut ........(2) ........MF ....... 8 ....NR8
**** 8mm Thick Flat Washer (2) ....................WC8X20
**** 10 x 1.5 x 45 ........(1) .....PL ...... 8.8 .... ALLEN HEAD .. BSH10X45
**** 10 x 1.5 x 37 ........ (1) ....PL .......8.8 .... ALLEN HEAD .. BSH10X35
**** 10mm Flat Washer ....(2) ...................... WF10
Aluminum Air Conditioner Bracket to Engine
**** 10 x 1.5 x 50 ......(2) .... GRAEKA... 8.8 ... BR10X50P
**** 10 x 1.5 x 145 ....(1) .... ? ........ 8.8 ... ALLEN BOLT ... Grade 10.9 .. BSH10X140
**** 10 x 1.5 x 40 ......(1) ..... ? ....... 8.8 .. ALLEN BOLT ... Grade 10.9 .. BSH19X40
**** 10mm Thick Washer ... (4) ................... WC10X25
Air Conditioner Steel Adjustment Bracket to Aluminum Bracket
**** 8 x 1.25 x 70 ......(1) ......? .......? ....... Carriage Bolt...... NA
**** 8 x 1.25 Nut .......(1) .....MF ...... 8 ........ NR8
Auto Transmission Mounting
**** 10 x 1.5 x 25 .......(2) ....... 3F ....... 8.8 ...... BR10x25
**** 10mm Thick Washer .... (3) ........................ WC10X20
**** 10 x 1.5 Nut .......(2) ................................. NR10
**** 10 x 1.5 x 100 .......(1) .......3F ....... 8.8 ..... BR10X100
**** 8 x 1.25 x 15 ........(3) .......ESKA ...... 8.8 ... BR8X16
Radiator Lower Mount Brackets
**** 8 x 1.25 x 17 ....... (4) ...... ESKA ..... 8.8 ... BR8X16
**** 8mm Thick Washer .... (4) ......................... WC8X20
Engine to Automatic Transmission
**** 10 x 1.5 x 40 ...... (1) ........3F ......... 8.8 .. BR10X40P
**** 10 x 1.5 Nut ........(3) ........M .... 8 ........... NR10
**** 10mm Wave Washer ... (4) ....................... WW10B
Spare Tire Carrier
**** 12 x 1.5 x 35 ...... (1) ........DERA...... 8.8 ... BFT12X1.5X35
**** 12mm heavy Fender Washer ... (1).............. WFE12X36
Exhaust Studs
**** 8 x 1.25 x 40 ..... (8 ) ....... Stud ......... S8X38E or S8X43
**** mine had some bolts..... If you wish....... 8 x 1.25 x 30 .... 8.8..BR8X30
**** 8 x 1.25 BRASS NUTS ..... (8 ) ................... NC8X13 or NC8X12
**** 10mm x 8mm Step Stud ...........................S8X19X35 or S8X10X38
Coolant Pipe to Water Pump
**** 8 x 1.25 x 25 .... (2) .... INDRA ..... 8.8 ..... ALLEN HEAD .. BSH8X25
**** 8mm Heavy Flat Washer ...... (2) ..... WC8X20
Water Pump Pulley
**** 8 x 1.25 x 15 ....... (3) ....... ESKA ...... 8.8 ... BR8X16
Water Pipe to Right Head
**** 8 x 1.25 x 22 ....(2) .........3F ...... 8.8 .... BR8X20
**** 8mm Wave Washer .... (2) ..................... WW8
Intake Manifold to Head
**** 8 x 1.25 x 75 .... (4) ......... KHS ...... 8.8 ... BR8X75
**** 8mm Heavy Flat Washer ....(4) .................. WC8X20
Injector Holder to Intake Manifold
**** 6 x 1.0 x 10 .....(2) ........3F ....... 8.8 ...... BR6X10
**** 6mm external Star Washer ... (2) ............ WSE6
Throttle Posistioner Plug to Intake Manifold
**** 6mm Nut ........(1) ......... M ....... 8 ......... NR6
Torque Convertor to Flex Plate
**** 8 x 1.25 x 10 .....(3) ........ FS .......12.9 ..... Flange Bolt......NA only grade 10.9 is available....... BF8X12 not recommended, source used Bolt or visit local transmission shop.
Alternator Bracket To Engine
**** recommend adding GoWesty's Modification or Similar Fix as you see fit.
**** 8 x 1.25 Nuts ......(3) ......................... NR8
**** 8mm Wave Washer... (3) ..................... WW8
**** 8 x 1.25 x 35 Stud ... (3) ..................... S8X35F
Alternator to Adjustment Bracket
**** 8 x 1.25 x 30 ...... (1) ...... FS ...... 8.8 ....Flange Bolt.... NA only grade 10.9 is available ...... BF8X30F
**** 8 x 1.25 x 75 .......(1) ......P/S ......8.8 ....Carriage Bolt... NA
**** 8 x 1.25 Nut ....... (1) ......MF ... 8 ....... NR8
Exhaust Muffler Heat Shield
Engine Heat Shields
**** 8 x 1.25 x 18 ....(4) ..... ESKA ...... 8.8 ....... BR8X16
**** 8mm Flat Washer .... (2) ........................... WF8
**** 8mm Fender Washer .. (2) ......................... WFE8X20
**** 6 x 1.0 x 15 ............(4) ..... ESKA ... 8.8 ...
**** 6mm Fender Washer .. (4) ......................... WFE6X18
**** 8 x 1.25 Nut ...............(1) ......................... NR8
**** 6.5 x 12 Loose Washer Hex Head Sheet Metal Screw ... (4) .. ST6.5X20
**** 6.5 x 15 Hex Head Sheet Metal Screw ....... (10) ...... NA use ST6.5X20
Exhaust Muffler Mounting
**** 8 x 1.25 x 38 ....... (4) ...... 3F ...... 8.8 ....... BR8X40P
**** 8 x 1.25 Nut .........(4) ....... M .......8 .......... NR8
**** 8mm x 18 Fender Washer .. (8 ).................. WFE8X20
**** 8 x 1.25 x 50 ........ (2) .......? ......8.8 ......... BR8X50
**** 8mm Flat Washer ...(4) ............................... WF8
Exhaust Joint Hardware
Electrical Connector Box Mounting Left Front Engine Compartment
**** 5 x .8 x 15 ........ (3) ....... Thread #2 Phillips Pan Head Screw .... MSP5X16
Idle Speed Control Relay Mounting
Coolant Distribution Connector mounting
**** 6 x 15 Self Tapping Hex Head Screw, double helix for Plastic ....... (2) ....... NA
Fuel Line Fitting Into Engine Compartment
**** 6 x 15 Self Tapping Sheet Metal Screw ..... (2) ...... NA
Intake Distribution Box Mounting to case Studs
**** 8 x 1.25 Nut ........... (1) .......... M ..... 8 ...... NR8
**** 8mm Flat Washer .... (1) ............................. WF8
**** 10 x 1.25 x 90 ........ (1) ............................. NA
**** 10 x 1.25 Nut .......... (1) ........ M ....... 8 ..... NR10X1.25
**** 10mm Flat Washer ... (1) ............................ WF10
Ghia
Vanagon
Beetle
Ahwahnee
Ahwahnee is offline
PostPosted: Fri Nov 01, 2013 5:48 pm    Post subject: Reply with quote
Thanks! That one goes in my VW file for future reference.
djkeev
djkeev is offline
PostPosted: Fri Nov 01, 2013 6:16 pm    Post subject: Reply with quote
Thanks, there are more fasteners to add to the list though. I'll try to finish it up tomorrow.
Dave
Ghia
Vanagon
Beetle
61Scout
61Scout is offline
PostPosted: Fri Nov 01, 2013 6:24 pm    Post subject: Reply with quote
My thoughts exactly. Thanks Dave! Appreciate you taking time to document and share.
Kevin
1986 Westfalia Weekender Wolfsburg, RJE 2.3
1985 Tin Top, Subie 2.2 + 5MT
Floppy Mirrors no more: http://www.thesamba.com/vw/forum/viewtopic.php?t=653018&highlight=
Remove the front spindle nut with ease: https://www.thesamba.com/vw/forum/viewtopic.php?t=679567&highlight=
Remove the rear wheel bearing housing without messing with the big 46mm nut: https://www.thesamba.com/vw/forum/viewtopic.php?t=679507&highlight=
-Nec Spe, Nec Metu
t3 kopf
t3 kopf is offline
PostPosted: Fri Nov 01, 2013 7:26 pm    Post subject: Reply with quote
awesome idea for a post. thank you.
'90 Carat w/ '95 phase 1 EJ22 OBD2 conversion
Alaric.H
Alaric.H is offline
PostPosted: Sat Nov 02, 2013 9:04 am    Post subject: Reply with quote
Or you can down load ETKA
djkeev
djkeev is offline
PostPosted: Sat Nov 02, 2013 9:22 am    Post subject: Reply with quote
Do elaborate..... Share a link, what are we downloading?
EDIT:
Google is your friend!
One small Problem..... $$'s......
Dave
Ghia
Vanagon
Beetle
dhaavers
dhaavers is offline
PostPosted: Sat Nov 02, 2013 10:23 am    Post subject: Reply with quote
Member up & start searching: http://www.vagcat.com/epc/cat/vw/T2/1986/65/49/
MODERATOR EDIT: 12/2020
Vagcat is a dead link!
This one works
https://volkswagen.7zap.com/en/usa/vanagon/va/
However, your list is very nice to have all in one place.
"The WonderVan"
djkeev
djkeev is offline
PostPosted: Sat Nov 02, 2013 1:51 pm    Post subject: Reply with quote
A most excellent site! Bookmarked, joined and I will print out everything they have listed for my 86 Vanagon during the next week! (I do NOT trust cyberspace, things seem to simply VANISH!)
Dave
Ghia
Vanagon
Beetle
AlfromNH
AlfromNH is offline
PostPosted: Mon Mar 10, 2025 7:57 am    Post subject: Re: Hardware for 2.1 Engine + Misc other locations Reply with quote
djkeev wrote:
I'm rebuilding my 1986 2.1 WBX, during disassembly...
What a fantastic post, I was looking for motor mount bolt sizes and got that and so much more, thanks djkeev!
‘88 2wd Auto Westy project
AlfromNH
AlfromNH is offline
PostPosted: Mon Mar 10, 2025 7:58 am    Post subject: Reply with quote
Dave
As predicted, it appears the site has vanished. Does anyone know if the info is currently available elsewhere?
dhaavers
dhaavers is offline
PostPosted: Mon Mar 10, 2025 8:46 am    Post subject: Reply with quote
Al, you missed it by one post above…update shown:
This one works:
- Dave
"The WonderVan"
bobbyblack Premium Member
bobbyblack is offline
PostPosted: Mon Mar 10, 2025 9:07 am    Post subject: Re: Hardware for 2.1 Engine + Misc other locations Reply with quote
UpVote this to Sticky, awesome info, might be hard for me to remember the title when I need to search back for it.
Thanks!
kamzcab86
kamzcab86 is offline
PostPosted: Mon Mar 10, 2025 10:19 am    Post subject: Reply with quote
Thanks!
Added to the FAQ: https://www.thesamba.com/vw/forum/viewtopic.php?p=6236044#6236044 .
In addition to the 7zap site already posted: https://webautocats.com/etka/volkswagen/t2/
2016 Golf GTI S
