TRS63 Samba Member
Joined: December 17, 2017 Posts: 1134 Location: Stuttgart - Germany
mandraks Samba Member
Joined: November 28, 2004 Posts: 7124 Location: Lawrenceville, Ga
Posted: Tue Apr 08, 2025 6:20 pm Post subject: Re: 52 panel repair from Austria |
i wonder if i have seen the bus this door came from.
_________________ regards
Uli
Huetti_1989 Samba Member
Joined: February 13, 2011 Posts: 1355 Location: Austria
ddutch Samba Member
Posted: Thu Apr 17, 2025 2:54 pm Post subject: Re: 52 panel repair from Austria |
| Huetti_1989 wrote: |
Sadly the weld have another color, can you see it?:
Sure, but your welding is still outstanding. |
djfordmanjack Samba Member
Joined: June 15, 2009 Posts: 2384 Location: Graz, Austria, Europe
Posted: Sat Apr 19, 2025 1:46 am Post subject: Re: 52 panel repair from Austria |
depending on filler rod, and gas, your weld will always have a different texture than the base material. I have also witnessed that the welds may draw metal chips like a magnet, I guess that would be from friction while grinding it down.
Fantastic work.
You were right on time for Hessisch, their site already says that registration is closed. _________________ Hotrods, Fords, Veedubs and Triumph Twins !
54 Oval project
62 Dickholmer, Seeblau L360
67 1500 Käfer, og paint Lotus weiß L282 w/red interior |
ddutch Samba Member
Posted: Mon Apr 21, 2025 1:22 pm Post subject: Re: 52 panel repair from Austria |
| Do you treat the surface rust and add rust protection before welding in the panel strengtheners? |
ddutch Samba Member
Posted: Tue Apr 22, 2025 3:05 pm Post subject: Re: 52 panel repair from Austria |
| ddutch wrote: |
No, like original no paint inside, I brushed out all the surface rust, later i fill that areas with rust protection oil and grease i think.
It should stay a car with traces, no Restauration here if you know what i mean?
Sure, a bus that shows the life it had. Thanks |
scornfern Samba Member
Posted: Fri May 23, 2025 7:03 am Post subject: Re: 52 panel repair from Austria |
| Hello Christian, any up dates? Love this build. |
vw356 Samba Member
Joined: January 09, 2004 Posts: 359 Location: Cullman,Alabama
Posted: Sat May 24, 2025 4:38 pm Post subject: Re: 52 panel repair from Austria |
Me Too! I've been watching this closely. Can't wait to see every step! _________________ Current projects:
1950's Volkswagens!
51,52,54's,55,56's,57,58's,'60's And then a bunch of '60's, but the '50's are my favorites.. |
Alan Brase Samba Member
Joined: March 28, 2004 Posts: 4570 Location: Cedar Falls, Iowa
Posted: Sun May 25, 2025 9:27 am Post subject: Re: 52 panel repair from Austria |
[quote="Huetti_1989"]
| ddutch wrote: |
-Christian
I though phosphoric acid dipping was standard on early bugs from very early. I've seen factory photos of type 1's where they are completely submerged in acid, and the workers in complete rubber suits.
Surely the type 2's as well?
I've used phosphoric acid Metal Prep by DuPont and others since I started metal work. It now seems hard to find in US body supply chains, but one can get concentrated pretty easily. and dilute it.
Is this not normal metal prepping in Europe?
Some may call it pickeling. _________________ Al Brase
Projects: 67 sunroof bug, 67 Porsche 912 Targa, 70 Westy
Dec 1955 Single Cab pickup WANT 15" BUS RIMS dated 8/55, thru 12/55
To New owners: 1969 doublecab, 1971 Dormobile
Vanagons:
80 P27 Westy JUL 1979, 3rd oldest known US
83 1.6TD Vanagon, 87 Wolfie Westy daily driver, swap meet home |
ddutch Samba Member
Posted: Mon May 26, 2025 7:01 pm Post subject: Re: 52 panel repair from Austria |
| Wonderful reproduction of inner-frame parts. Good to see you working on the Barndoor again, I missed it. |
