Marcdeb Samba Member
Posted: Thu Dec 12, 2024 3:19 pm Post subject: Re: 1966 Ghia coupe restoration |
Looks really sharp. I noticed your antenna is on the right side as my 68 has it. My 71 has it on the left and prior to getting my 68, I had only seen antennas on the the left side. Interesting that dealers were not following the same procedures! _________________ Marc
71 Karmann Ghia Cabrio
Previously Owned:
2011 VW EOS Hard Top Conv
2008 Saab 9-3 2.0T Conv
2003 Saab 9-3 SE Conv
2001 Saab 9-3 Conv
1998 BMW 3 Series Conv
1997 Saab 900 Conv
1997 Mazda Miata
71 Ghia Vert Restoration: https://www.thesamba.com/vw/forum/viewtopic.php?t=726710&postorder=asc |
Era Vulgaris Samba Member
Joined: August 22, 2012 Posts: 1889 Location: Raleigh, NC
Posted: Thu Dec 12, 2024 3:36 pm Post subject: Re: 1966 Ghia coupe restoration |
Marcdeb wrote: |
Looks really sharp. I noticed your antenna is on the right side as my 68 has it. My 71 has it on the left and prior to getting my 68, I had only seen antennas on the the left side. Interesting that dealers were not following the same procedures! |
Thanks! Interesting, I hadn't really ever paid attention to which side the antennas were on. I wonder if there was an actual reason for one side or the other, or if it was dealer's choice. _________________ Currently own:
66 Karmann Ghia, L390 Gulf Blue, under construction, here: www.thesamba.com/vw/forum/viewtopic.php?t=760505&highlight=
99 Mazda MX-5 10AE, Sapphire Blue Mica, 6 speed, LSD
Previously owned:
98 Porsche Boxster, silver, 2.5L -- 67 Karmann Ghia, Black, 1500sp -- 98 BMW Z3, Atlanta Blue Metallic, 2.8L I6 -- 75 Porsche 914, Laguna Blue, 2270cc -- 72 Porsche 914, Signal Orange, 1.7 FI -- 74 Karmann Ghia, Black, 1600dp -- 74 Triumph TR6 with O.D., sapphire blue |
Posted: Thu Dec 12, 2024 4:29 pm Post subject: Re: 1966 Ghia coupe restoration |
Era Vulgaris wrote: |
Marcdeb wrote: |
Thanks! Interesting, I hadn't really ever paid attention to which side the antennas were on. I wonder if there was an actual reason for one side or the other, or if it was dealer's choice. |
From what I've read, it was just dealer choice but I see way more Ghia's with antennas on the left. I know there is an antenna installation instruction sheet which I believe was provided to dealerships and that showed where to position the antenna on the left side. I've never seen any documentation for right side?? _________________ Marc
Previously Owned:
2001 Saab 9-3 Conv
1997 Saab 900 Conv
1997 Mazda Miata
Disc Samba Member
Joined: September 24, 2009 Posts: 627 Location: Europe
Posted: Thu Dec 12, 2024 11:48 pm Post subject: Re: 1966 Ghia coupe restoration |
If you have an retracktable antenna (as you do), it's easier to reach from the driver side and not always you have an passenger to do that for you. _________________ The glory never gets old, just need new paint.
Nick |
sputnick60 Samba Moderator
Joined: July 22, 2007 Posts: 4097 Location: In Molinya Orbit
Posted: Fri Dec 13, 2024 4:37 am Post subject: Re: 1966 Ghia coupe restoration |
There is a route from the trunk to the left side inner guard that isn't present on the right side. An extra hole is for the antenna cable and grommet. it's tucked up in the corner. I discovered the hard way after putting a hole in the right fender for the antenna before paint that later I had to add a hole for the antenna after paint.
Nicholas _________________ '66 Karmann Ghia Cabriolet...
'65 Porsche 356C Coupe...
Posted: Fri Dec 13, 2024 6:05 am Post subject: Re: 1966 Ghia coupe restoration |
sputnick60 wrote: |
Nicholas |
I've read about the factory original hole for the antenna wire on the left side, possibly from you in an older post. So why would some dealers go to the trouble of installing an antenna on the right side? _________________ Marc
Previously Owned:
2001 Saab 9-3 Conv
1997 Saab 900 Conv
1997 Mazda Miata
Posted: Fri Dec 13, 2024 6:19 am Post subject: Re: 1966 Ghia coupe restoration |
Marcdeb wrote: |
I've read about the factory original hole for the antenna wire on the left side, possibly from you in an older post. So why would some dealers go to the trouble of installing an antenna on the right side? |
I suppose it's also possible that it wasn't the dealer who cut the hole, but rather a previous owner or a car radio installer. _________________ Currently own:
Previously owned:
Posted: Fri Dec 13, 2024 12:43 pm Post subject: Re: 1966 Ghia coupe restoration |
Marcdeb wrote: |
Imagine you’re doing this for the first time for a customer’s Ghia in your radio shop in the 60s. You mostly do installations on American cars. The customer Came to you saying your prices are better than the local VW dealer and points to the side for the antenna, or maybe you decided which side. Either way, you rip into it without too much investigation because time is money and you’ve got a half dozen other customers to get done before Lunch.
Once you drill a hole in the guard you’re committed to it. Then you mount up the antenna. After that you workout the cable path.
In one parallel universe you discover how easy it is to use the purpose built hole on the left side to thread the cable through and hook it up to the new radio. The job got done in half the time so you can charge the same and make a little extra. You like this clever german car and think maybe the wife would like one too.
In the other parallel universe you discover there’s no hole on the right side to drill the hole. You curse because your black and decker drill is too big to fit in the tiny space in the corner of the trunk. You spend 20 minutes digging out that right angle air drill buried at the back of the workshop and hook up two air hoses because the compressor is too far away and finally you manage to make a hole on the right side inner trunk but not before you scratch the paint
You curse. “stupid german car, no wonder they lost the war” when you realise you’ve wasted twice the allocated time on this one customer as two other customers have just shown up to pick up their American cars that haven’t been started.
Sometimes random choices are at play.
Posted: Tue Feb 04, 2025 3:47 pm Post subject: Re: 1966 Ghia coupe restoration |
I meant to post these pics a while back of the side trim install with the MG Midget clips. They're not actually clips, but stud plates. The side trim I bought was from KGPR, and the plates were not a direct fit into the trim. I had to use a bench grinder and reduce their width slightly and add an angle profile. I'm not sure if other brands of side trim would require that as well. I admit this step was a bit fiddly and annoying having to trim so many of these.
Here you can see a modified one next to an unmodified one
I bought the stud plates from Rimmer Brothers in the UK
https://rimmerbros.com/Item--i-AHA9447?srsltid=Afm...7KSItDCgQ2
They don't actually come with the nut that's pictured, but that doesn't matter because you'll want to buy M5 locknuts anyway so they don't come loose. I also used an M5 rubber washer on the inside of the body panels as a seal.
The studs are smaller than the side trim holes, which means you need to make sure the trim pieces are straight in line with one another before you fully tighten the locknuts down. This took me quite a bit of time making sure that each trim line was straight and that the two were parallel. _________________ Currently own:
Previously owned:
Posted: Fri Apr 25, 2025 2:05 pm Post subject: Re: 1966 Ghia coupe restoration |
Finally got my tires mounted on the factory '66 wheels. So cool seeing the calipers through the slots!
Previously owned:
Posted: Wed May 21, 2025 1:49 pm Post subject: Re: 1966 Ghia coupe restoration |
I was getting ready to install the gas tank, and had the thought I should first check the tunnel fuel line. I hit it with compressed air and to my massive dismay nothing came out the other end. I'm kicking myself for not thinking to check this while I had the body off. I don't know how I completely overlooked this. But I picked up 25' of stainless 1/4" tubing and am going to have to replace the tunnel fuel line with the body on. I've read a bunch of threads on it, and have a good idea how to approach it. Wish me luck, cuz I'm gonna need it. _________________ Currently own:
Previously owned:
Posted: Wed May 21, 2025 4:44 pm Post subject: Re: 1966 Ghia coupe restoration |
I can understand how realizing the situation must have been quite disappointing but we've seen your skills and I suspect you will get though this successfully. Look forward to reading about it.
Your wheels look good and I have to say again that your paint is a near perfect match to one year only L50F Regatta Blue. Looks amazing. _________________ Marc
Previously Owned:
2001 Saab 9-3 Conv
1997 Saab 900 Conv
1997 Mazda Miata
Posted: Thu May 22, 2025 5:00 am Post subject: Re: 1966 Ghia coupe restoration |
Marcdeb wrote: |
Your wheels look good and I have to say again that your paint is a near perfect match to one year only L50F Regatta Blue. Looks amazing. |
Thanks, I appreciate that! Thought I was about to be on the goal line only to get an offsides penalty
I'll be posting pics of the fuel line replacement for sure. _________________ Currently own:
Previously owned:
DaveB9 Samba Member
Posted: Thu May 22, 2025 1:51 pm Post subject: Re: 1966 Ghia coupe restoration |
That is really frustrating! Any use trying to clear it with a piece of welding wire or something similar? If you can dislodge whatever is in there it might then blow out with compressed air and then you could flush it repeatedly.
I have installed a new fuel line through the tunnel on my Beetle years ago with the body on. I gave up when it got to trying to get it down the framehorn and so at the back I started the flexible hose next to the gearshift coupler and out next to the clutch cable conduit. It has been like that for 25 + years, with regular changes of the flexible hose. But I was young and impatient - I suspect if you do install the new one you will manage better! |
Posted: Fri May 23, 2025 4:49 am Post subject: Re: 1966 Ghia coupe restoration |
DaveB9 wrote: |
I had considered trying to unclog it. I was successful in unclogging one of the heater cable tubes that had some solidified gunk in it. But my concern is what if in trying to unclog it, I unwittingly breach it - something I won't know until fuel leaks everywhere. It's 59 year old tubing, may as well replace it.
Here's my plan that I picked up from a post in the Beetle forum. Run the tubing in straight from the front through the inspection port between the front beams until I can see it at the rear inspection hatch where the shift coupler is. Then run weed whacker line in through the frame horn until I see it in the rear inspection hatch. Duct tape the weed whacker line to the tubing and use it to guide/pull the tubing down and out of the frame horn. From there it's a matter of cutting the front of the tubing and continuing to pull it through until I can guide it up through its exit at the front of the tunnel. Once it's out both ends, trim the ends with a tubing cutter, and use metal zip ties to secure it in place in the tunnel.
Easier said than done, but that's the plan. _________________ Currently own:
Previously owned:
