Removing front beam torsion leafs
Turbopaul
Turbopaul is offline
PostPosted: Wed May 21, 2025 6:09 am    Post subject: Removing front beam torsion leafs Reply with quote
My next project while I am changing out the ball joints is to soften up the front end a little bit. What is the best and easiest way to remove leafs? When you remove torsion leafs what is the thought of which ones you remove, upper or lower or both? What do you put in it's place to take up the space? I was thinking only one spring but not sure from what position. With my kyb gas shocks it makes it pretty stiff already. I don't want to lower it any bc of tire clearance. Thanks
EVfun Premium Member
EVfun is offline
PostPosted: Wed May 21, 2025 10:28 am    Post subject: Re: Removing front beam torsion leafs Reply with quote
Typically, softening the front suspension will increase the tendency to over steer, something the Bug chassis is already inclined toward. This will be more of a concern if you also ditch the front sway bar. What size tires do you want to run? This has an impact on handling too.
Wildthings wrote:
slalombuggy
slalombuggy is offline
PostPosted: Wed May 21, 2025 2:39 pm    Post subject: Re: Removing front beam torsion leafs Reply with quote
I removed one complete set in my buggy and cut out the center holder on the tube I took them out of. I then replaced them with a 3/4" square steel bar to hold the arms in and act as a sway bar. I deleted the top springs in my link pin beams but on a balljoint I would pull them from the bottom tube.
EVfun is offline
PostPosted: Wed May 21, 2025 2:56 pm    Post subject: Re: Removing front beam torsion leafs Reply with quote
I had a thought about that…
What if instead of removing 1 torsion bar pack the center anchor on 1 beam tube was removed? With this change 1 torsion bar would be your suspension and the other would be a sway bar hidden inside the beam. Perhaps move the small torsion bars around (for the K&L beam where they add up to a square) so that the suspension bar is made of 6 wide leaves, and the sway bar is made of 2 wide leaves and 8 narrow leaves.
Wildthings wrote:
oprn
oprn is offline
PostPosted: Wed May 21, 2025 3:15 pm    Post subject: Re: Removing front beam torsion leafs Reply with quote
I think you are on to something there EVfun!
Dale M.
Dale M. is offline
PostPosted: Wed May 21, 2025 3:24 pm    Post subject: Re: Removing front beam torsion leafs Reply with quote
I put on a new beam with Avis adjusters, and when putting leaf packs in I did not install the half leaves on both tubes.... And yes the Avis adjuster still work like advertised....
EVfun is offline
PostPosted: Wed May 21, 2025 3:50 pm    Post subject: Re: Removing front beam torsion leafs Reply with quote
What kept the torsion bars from moving around in anchors? The grub screw will push the leaves out on one side and keep them in place, but the opposite side would seem to have room to twist in its locating boxes unless some type of filler was added. Also, if you don't spacer out the torsion leaves at the trailing arms it seems like it would create a big grease leak and/or water intrusion point.
Wildthings wrote:
Turbopaul
PostPosted: Wed May 21, 2025 4:35 pm    Post subject: Re: Removing front beam torsion leafs Reply with quote
To answer your question evfun, I have 31x10.5 tires on the front. That is what I always had but now I want to loosen up the suspension to give it some movement. Thanks
oprn
oprn is offline
PostPosted: Wed May 21, 2025 8:21 pm    Post subject: Re: Removing front beam torsion leafs Reply with quote
Wow! How do you steer that thing?
Q-Dog
Q-Dog is offline
PostPosted: Thu May 22, 2025 1:46 am    Post subject: Re: Removing front beam torsion leafs Reply with quote
If it is a ball joint front end you can remove all the small leaves from either spring pack without needing to add any spacers in the pack ... the normal grub screws will work just fine to hold the pack. If you remove large leaves you will need to add spacers to make it all work.
If it is an earlier front endyou need to add spacers to replace any missing leaves.
Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle
Turbopaul
PostPosted: Thu May 22, 2025 6:22 am    Post subject: Re: Removing front beam torsion leafs Reply with quote
It steers pretty good with the stock steering box and tie rods, when the ball joints aren't new and stuff (if you followed my earlier post). It's a 67 or 68 ball joint beam. Are the small leafs in only top or bottom or both? I can look but I thought I would ask also. How much does that soften it up? Thanks
Turbopaul
PostPosted: Thu May 22, 2025 6:24 am    Post subject: Re: Removing front beam torsion leafs Reply with quote
I forgot to mention the steering radius is not that good bc the tires hits the body first w/o the stops moved in.
halfassleatherworks
PostPosted: Thu May 22, 2025 7:43 am    Post subject: Re: Removing front beam torsion leafs Reply with quote
It's a ball joint front end, If you remove any torsion bars remove the bottom ones. Do not remove the top torsion bars because if you do you will load the bottom ball joints with all the weight and be pulling on the joint instead of pushing on it.
Turbopaul
PostPosted: Thu May 22, 2025 8:38 am    Post subject: Re: Removing front beam torsion leafs Reply with quote
Ok so what is a good rule of thumb as to how many to remove? And I don't need to replace with spacers the ones I removed?
halfassleatherworks
PostPosted: Thu May 22, 2025 8:59 am    Post subject: Re: Removing front beam torsion leafs Reply with quote
For my build I took out the lowers and put a thru rod in to start. have not gotten it on the road yet, will have to see maybe gas shocks, will be road car only.
Last edited by halfassleatherworks on Thu May 22, 2025 11:53 am; edited 1 time in total
Turbopaul
PostPosted: Thu May 22, 2025 10:05 am    Post subject: Re: Removing front beam torsion leafs Reply with quote
Also why is it you are saying small and large bars? My top and bottom torsion bars are all the same size. Roughly .840"wide and total thickness is .425". This is measured at the ends sticking out the beam.
EVfun is offline
PostPosted: Thu May 22, 2025 10:17 am    Post subject: Re: Removing front beam torsion leafs Reply with quote
If you clean the grease off the ends of the stack of the bars you can see that they are made up of large and small flat leaves. Here is a picture from CIP that shows some new bars (for a 2 inch narrowed beam) so you can see the detail. You can remove the single top and bottom small bar and still clamp the remaining ones in the beam without a fitting a spacer. I've been told it will lower the front about 1.5 inches, but likely less in a light buggy. It will soften the ride, perhaps by 10%.
Wildthings wrote:
Turbopaul
PostPosted: Thu May 22, 2025 1:48 pm    Post subject: Re: Removing front beam torsion leafs Reply with quote
Here are pics of the pass side top and bottom. Looks like I removed the small leafs already. If I want to go another step softer how do I go about it? Thanks
oprn
oprn is offline
PostPosted: Thu May 22, 2025 4:08 pm    Post subject: Re: Removing front beam torsion leafs Reply with quote
Is your fuel tank and battery at the back? Put them up front if you still can. Not only will it help the ride, the car will handle better too.
Turbopaul
PostPosted: Thu May 22, 2025 8:03 pm    Post subject: Re: Removing front beam torsion leafs Reply with quote
The fuel tank is located in the stock beetle location and the battery is mounted behind the pass seat.
I wonder if the kyb gas shocks are too much for the front suspension holding it up and not allowing much up/down travel?
So I guess I already did what I could with the torsion bars by removing the small leafs?
