Large m plate number
JDub113
JDub113 is offline
PostPosted: Thu May 22, 2025 11:35 am    Post subject: Large m plate number Reply with quote
Have you seen this before? 221. Anyone know what it is?
84 Wolfsburg Edition Westy
busdaddy
busdaddy is offline
PostPosted: Thu May 22, 2025 11:49 am    Post subject: Re: Large m plate number Reply with quote
M codes were rubber stamped in big print on the bare metal bodies before paint, likely to tell the welders what holes to add and where to put brackets, obviously whoever did that one ran out of room and got the plate.
Слава Україні!
JDub113
JDub113 is offline
PostPosted: Thu May 22, 2025 8:03 pm    Post subject: Re: Large m plate number Reply with quote
Awesome thanks
PostPosted: Thu May 22, 2025 9:18 pm    Post subject: Re: Large m plate number Reply with quote
This has come up a few times, usually there are numbers on the bulkhead but sometimes found on the M-code plate too.
One thread:
https://www.thesamba.com/vw/forum/viewtopic.php?t=446650
More:
https://www.thesamba.com/vw/forum/viewtopic.php?t=622971
https://www.thesamba.com/vw/forum/viewtopic.php?t=442169
https://www.thesamba.com/vw/forum/viewtopic.php?t=647797
In the middle of a thread:
https://www.thesamba.com/vw/forum/viewtopic.php?p=7939046#7939046
JDub113
JDub113 is offline
PostPosted: Fri May 23, 2025 6:56 am    Post subject: Re: Large m plate number Reply with quote
Maybe to make sure the right plate went on the right bus. Don’t want to screw that up.
