vamram  Samba Member
Posted: Tue Apr 22, 2025 9:35 am Post subject: '73 Super HL Switch ON, No RTurn Signal or Flashers - FIXED??? |
Happy Tuesday, Samba!
This problem started a few days ago. My '73 Super's RIGHT turn signal and emergency flashers stop working if I turn on the headlight switch to either of its two positions - parking lights on, or parking lights AND headlights on. The double-green arrow in the speedo lights dimly and the turn signal relay does a single click. Emergency flasher button goes red and stays red w/out flashing.
The Left turn signal works normally, headlight switch on or off. Both turn signals and the emergency flashers work normally when the headlight switch is turned fully OFF. This is an original VW headlight switch.
I'm looking for some troubleshooting ideas before I start removing the speedo or the light switch.
Failing headlight switch...? Loose wire at the speedo...at the switch? Other...?
Thanks.
 _________________ "Men are qualified for civil liberty in exact proportion to their disposition
'75 Super Le Grande...we hardly knew ye. Sold 2025 for peanuts.
Click to view image
Save the Supers!!
VW_Jimbo  Samba Member
Joined: May 22, 2016 Posts: 11508 Location: Huntington Beach, CA
Posted: Tue Apr 22, 2025 9:49 am Post subject: Re: '73 Super Headlight Switch ON = No RTurn Signal or Emer_Flashers |
Check the ground at the light and the wiring at BOTH ends. Sounds like corrosion or a poor connection. _________________ Jimbo
| TDCTDI wrote: |
| Basically, a whole bunch of fuckery to achieve a look. |
| 67rustavenger wrote: |
GFY's Xevin and VW_Jimbo!  |
vamram  Samba Member
Posted: Tue Apr 22, 2025 2:22 pm Post subject: Re: '73 Super Headlight Switch ON = No RTurn Signal or Emer_Flashers |
Jimbo the grounds at the front fender are tight and shiny copper and brass. Also, the issue seems to be intermittent. The signals worked fine on a drive today. Short drive, though, I'll take it on a longer one tomorrow. Maybe wires or connectors need to heat up some...? Spit-ballin here.
Where else should I look? _________________ "Men are qualified for civil liberty in exact proportion to their disposition
Click to view image
Save the Supers!! |
baldessariclan Samba Member
Joined: October 14, 2016 Posts: 2214 Location: Wichita, KS
Posted: Wed Apr 23, 2025 5:13 am Post subject: Re: '73 Super Headlight Switch ON = No RTurn Signal or Emer_Flashers |
Still sounds like a poor or intermittent grounding path issue to me as well — suspecting a loose connection or high resistance point somewhere. Recommend systematically checking all wiring and connections, fuses, etc. along the entire path for the circuits in question. For each, start at the hot end, and work your way to final grounding point. _________________ 1971 Standard Beetle — fairly stock / driver
baldessariclan -- often in error, never in doubt... |
vamram  Samba Member
Posted: Sat May 10, 2025 6:06 pm Post subject: Re: '73 Super Headlight Switch ON = No RTurn Signal or Emer_Flashers |
Quick update on this - looks like the issue was likely something w/the connections at the front right turn signal assembly. After unbolting it from the fender to check the connections and the replacing it, the problem hasn't returned. It's odd, because the terminals are all squeaky clean and I *thought* they were in snuggly. I pressed on all of them for the heck of it before reinstalling it. Haven't lost the right turn or emergency flashers since. _________________ "Men are qualified for civil liberty in exact proportion to their disposition
Click to view image
Save the Supers!! |
vamram  Samba Member
Posted: Wed May 21, 2025 5:37 am Post subject: Re: '73 Super Headlight Switch ON = No RTurn Signal or Emer_Flashers |
Spoke too soon. The problem was back today on the way to work. Once in the parking lot I did a quick check. Lights off, right front turn signal works but it turns out that it also cause BOTH rear tail lights to blink in synch w/the right turn signal. OY.
I had this solved. Two changes since yesterday - I installed side tar boards in the engine compartment. Perhaps I messed up a connection or the grounds. And it's raining this morning. Wont be able to look at this until late this afternoon. Just in time for this weekend's road trip to upstate NY. Ugh. _________________ "Men are qualified for civil liberty in exact proportion to their disposition
Click to view image
Save the Supers!! |
talljordan Samba Member
Joined: January 10, 2012 Posts: 1188 Location: San Francisco, CA
Posted: Wed May 21, 2025 3:49 pm Post subject: Re: '73 Super Headlight Switch ON = No RTurn Signal or Emer_Flashers |
This also reads as likely a bad ground to me. Do the park lights work when the lights are on?
Do you have a multimeter? I would measure the resistance between the ground wire in the housing.
Also remove the lens, turn on the lights and flashers, and measure the voltage at the contact with the bulb removed and ground the meter to a good SOLID spot (not the metal housing). Does it go to 12V as the flasher clicks?
The last thing is that power for the headlights does flow through the emergency flasher switch and the dimmer relay. if one or both of these are bad, this could cause the issue. _________________ 1972 Super Beetle, Parked until adequate restoration funding is acquired in restoration!
Wanted: Male computer diagnostic plug end |
vamram  Samba Member
Posted: Thu May 22, 2025 6:33 am Post subject: Re: '73 Super Headlight Switch ON = No RTurn Signal or Emer_Flashers |
Jordan, I'm going to do the 2 easiest things today - clean the ground strap and tailight grounds in the engine compartment, test, failing that, replace the flasher relay w/a new E-flasher LED-compatible relay. Front connections are clean, I went through those previously. I'll report back. _________________ "Men are qualified for civil liberty in exact proportion to their disposition
Click to view image
Save the Supers!! |
vamram  Samba Member
Posted: Thu May 22, 2025 2:20 pm Post subject: Re: '73 Super Headlight Switch ON = No RTurn Signal or Emer_Flashers |
Ground strap is good, clean and tight. I replaced the relay - the one in there was already EP35. Anyway, now the emergency flashers work with the lights on. But:
- rear taillights flash along with the emergency flashers - both sides
- speedo indicator doesn't flash with the flashers.
- right turn only signal doesn't flash with lights on
- right turn signal flashes with the headlights off - and so do both taillights.
- left turn signal flashes normally, no taillights
Next...check rear right taillight wiring? _________________ "Men are qualified for civil liberty in exact proportion to their disposition
Click to view image
Save the Supers!! |
Buggeee  Samba Member
Joined: December 22, 2016 Posts: 5055 Location: Stuck in Ohio
vamram  Samba Member
Posted: Thu May 22, 2025 3:39 pm Post subject: Re: '73 Super Headlight Switch ON = No RTurn Signal or Emer_Flashers |
Buggee, here's hoping.
I decided since both filaments of the right front turn signal bulb at on when I turn on the lights that I should check it first. Here you go.
Front right turn signal wires all disconnected, turn on flashers or right turn signal - rear taillights both blink AND the left front turn signal blinks!!
This is how the assembly is wired.
Grey wire the trunk-side connector. Fat black in the middle. Long skinny black to the side marker bulb, ground on the outside spade that's part of the blinker assembly body. I find it odd that this assembly is so rusted out in front.
Click to view image
Save the Supers!! |
Posted: Thu May 22, 2025 3:40 pm Post subject: Re: '73 Super Headlight Switch ON = No RTurn Signal or Emer_Flashers |
It is time to start poking at things with a multimeter and checking where voltage is and when.
Remove the bulbs, check every single contact for voltage and ensure they are only receiving voltage when they should.
This is wired directly into the relay, is it receiving voltage? Are you sure you have the right relay?
All of this still sounds to me like either very incorrect wiring, or a bad emergency flasher switch.
Another useful debugging strategy is to disconnect wires in the trunk, and apply 12V to them and ensure only the lights you expect to light up: light up. _________________ 1972 Super Beetle, Parked until adequate restoration funding is acquired in restoration!
Posted: Thu May 22, 2025 3:44 pm Post subject: Re: '73 Super Headlight Switch ON = No RTurn Signal or Emer_Flashers |
The first photo you posted also looks suspicious. There should only be 2 ground connections. Headlight and turn signal/parking light.
What is the third red spade connector wired to? _________________ 1972 Super Beetle, Parked until adequate restoration funding is acquired in restoration!
ashman40 Samba Member
Joined: February 16, 2007 Posts: 16800 Location: North Florida, USA
Posted: Thu May 22, 2025 3:56 pm Post subject: Re: '73 Super Headlight Switch ON = No RTurn Signal or Emer_Flashers |
| vamram wrote: |
Spoke too soon. The problem was back today on the way to work. Once in the parking lot I did a quick check. Lights off, right front turn signal works but it turns out that it also cause BOTH rear tail lights to blink in synch w/the right turn signal. OY. |
Grounding problem. Likely at the front right turn signal assembly.
Here is why... when the headlight switch is OFF current from the turn signal switch is running to the front right dual-filament (1157?) bulb. This bulb has two inputs (parking and turn) and a single ground. When the ground path is weak the current passing thru the turn signal filament is "looking" for the lowest resistance path to ground. Normally this should be the ground wire coming off the light assembly to the body. But when this path has high resistance the current looks elsewhere. The non-powered parking light is a path! Current enters this circuit and works its way backwards thru the grey parking light wiring to the fuse box. Here is can branch off down the different parking light and even dash light paths. The current is distributed over all paths. There is only 25W passing thru the turn signal filament and this is further restricted by the 5W filament in the front right bulb. This power is split up proportionately over the different paths depending on the resistance. This is why your rear parking lights are flashing. They are now in the circuit path for the front right turn signal bulb.
When you repeat this test with the parking/headlights ON, there is now current flowing thru the parking light wires, This prevents current from the parking light bulb from reaching ground (the current from the turn signal is trying to flow "upstream" of current flowing thru the parking light circuit.
Test: Remove the lens from the front right turn signal assembly. Don't touch anything else. Using a jumper wire (preferably with alligator clips) ground the metal body of the right front turn signal assembly to a known good ground point on the body or better yet the chassis. Test your right turn signal again. This ensures a good ground for the light assembly. Remove the wire and see if the problem returns.
You may need to repeat the same for the other parking light assemblies but I'm guessing the problem is with the front turn signal assembly.
If you confirm the problem is with the ground path... disconnect the brown ground wire at the light assembly. Place an ohm meter between the loose end of the wire and a known good ground and measure the resistance in this wire path. If it is anything above 1.0ohm you have excessive resistance. The wire itself should read near zero resistance. You could try cleaning all the wire connections and test again. Or, you may need to replace the ground wire entirely. Or maybe clip off the female ends of the wire and crimp on new terminals.
You should also double check the wiring at the light assembly. Make sure the black turn signal wire powers the brighter filament of the dual-filament bulb and the grey parking light wire powers the dimmer filament. _________________ AshMan40
Posted: Thu May 22, 2025 4:20 pm Post subject: Re: '73 Super Headlight Switch ON = No RTurn Signal or Emer_Flashers |
Sand the metal body of the turn signal before hooking the alligator clip to it! They tarnish easily, and the tarnish prevents a good contact. _________________ 1972 Super Beetle, Parked until adequate restoration funding is acquired in restoration!
vamram  Samba Member
Posted: Thu May 22, 2025 5:44 pm Post subject: Re: '73 Super Headlight Switch ON = No RTurn Signal or Emer_Flashers |
Jordan - there are 3 ground wires in that picture: from the headlight, from the turn signal harness (the one that looks reddish in the picture) and from the electric window washer pump. The only thing I found on the right wiring are was this - the spade for the washer pump's ground wire had broken and it *may* have been making contact w/the hot wire, but I'm unable to confirm that. I haven't blown any fuses w/this issue.
I did disconnect and clean the ground connections and sanded the mounting point some just to clear out 5 years of accumulated crud. This had one effect - when I turn on the lights, only the parking light filament lights. Everything else stayed the same.
The last thing I did try before calling it a day was to disconnect all 4 wires from the turn signal housing (3 power and 1 ground) and tried the turn signals - same result. The 3 connected corners and taillights all flash when turning RIGHT. No change when I reconnected everything after fixing the busted washer pump ground.
Ashman, I hadn't seen these latest replies until a few minutes ago and now it's almost dark and drizzly so I'll have to perform your tests tomorrow. Your explanation makes sense. But...wouldn't the flashing problem stop if the front turn signal is completely disconnected...? Could this suggest that the problem is elsewhere? Perhaps in the passenger-side rear? And would pulling the fuse for say the right turn signal and retesting help isolate the problem? _________________ "Men are qualified for civil liberty in exact proportion to their disposition
Click to view image
Save the Supers!! |
vamram  Samba Member
Posted: Thu May 22, 2025 6:24 pm Post subject: Re: '73 Super Headlight Switch ON = No RTurn Signal or Emer_Flashers |
Couldn't resist, I put on my head lamp to test what happens w/the fuses. Per the '73 manual, #1-2 are the left and right parking lights and signals (note typo in the text for 1 & 2).
Here's what happened when I started pulling fuses:
A) #1 OUT, Flasher switch ON: all four corners flash as well as the driver side taillight; passenger side taillight is OFF.
B) #2 OUT, 1 IN, Flasher ON: same exact result as test A
C) #1 & 2 fuses both removed, Flasher ON: headlights and parking lights don't work; right front turn signal, rear turn signals and left taillight flash; driver front turn signal does *not* flash when engaging the right turn signal; right taillight does *not* come on.
D) Only #3 removed: per the manual
E) Only #4 removed: per the manual
Is anyone else as confused as I am? That's a lot of bleeding between circuits. Mind you, this is a car that has passed safety inspection 5 years in a row, so none of this was an issue until recently. _________________ "Men are qualified for civil liberty in exact proportion to their disposition
Click to view image
Save the Supers!! |
vamram  Samba Member
Posted: Fri May 23, 2025 9:59 am Post subject: Re: '73 Super Headlight Switch ON = No RTurn Signal or Emer_Flashers |
| ashman40 wrote: |
Ashman, I did the test w/the right turn signal. I connected the long wire from the turn signal's base to different points on the body - bumper bracket, fender mounting bolt end, trunk hood edge, horn bracket, no difference. Here's a video showing the rear taillights blinking along w/the flashers (sorry for the heavy breathing).
For kicks and grins I disconnected the headlight and turn signal ground wires, no effect - all 3 turn signal assembly bulbs and filaments light up, and w/the flashers all four corners + taillights flash. I checked my wire connections in back - which haven't been messed w/in years. Here's what they look like. Ground wires are firmly connected to the tabs and clean.
Next test? Should I try swapping out the emergency flasher switch....? _________________ "Men are qualified for civil liberty in exact proportion to their disposition
Click to view image
Save the Supers!! |
Posted: Fri May 23, 2025 10:41 am Post subject: Re: '73 Super Headlight Switch ON = No RTurn Signal or Emer_Flashers |
This is with just the right turn signal on? The headlights off?
It is illuminating the parking lights. The small bulb on the front should NOT be illuminated when the blinkers are on.
The issue is that it is activating the whole park light circuit. Thus it is lighting up all four corners! If you look at your wiring diagram, you can see the park lights are all wired together. M 2,4,5,7, 11. (note there are 2 M5s and M7s, I am referring to the one on the left side of the image)
My new guess is that you have some contact between the turn signal circuit, and the parking light circuit. This would cause the voltage to flow from the turn signal, through the "short" and since all 4 corners of the parking circuit are connected, they all light up. This also would explain why removing fuse 1 and fuse 2 made no real change.
There are a couple ways to trace where this is happening, it could be caused at the bulb, at the housing, in the internal wiring, or near the fuse box. First, remove EVERY turn signal bulb (all 4 corners), but not the parking light bulbs, then activate the turn signal. Do the parking lights still flash? If so, it is not a bulb issue.
Then remove all 4 housings and make sure that the hot contacts do not touch together.
You can also check for this by removing a single large front signal bulb, and check how much resistance is between the two contacts. It should be infinite. _________________ 1972 Super Beetle, Parked until adequate restoration funding is acquired in restoration!
vamram  Samba Member
Posted: Fri May 23, 2025 10:55 am Post subject: Re: '73 Super Headlight Switch ON = No RTurn Signal or Emer_Flashers |
I'll try your test. Note - the front parking light and turn signals are a encased in a single dual filament bulb so removing it gets rid of the turn signal bulb as well (except for the small side marker bulb).... _________________ "Men are qualified for civil liberty in exact proportion to their disposition
Click to view image
Save the Supers!! |
