Werksberg Panels Installed 1962 bus
blargon_7 Premium Member
blargon_7 is offline
PostPosted: Tue May 13, 2025 10:54 pm    Post subject: Werksberg Panels Installed 1962 bus Reply with quote
Hey all. I recently purchased some Werksberg panels off of the add on here. These are great quality and value for the money. I got the door panels, kick panels and headliner in grey. For fasteners I just went to lowes and bought some 1/2" long phillips head, self-tapping screws that have a flat washer fixed to the head, probably around 3/8" wide.
The predrilled holes for the door handles were spot on, headlight holes perfect, and I didn't have to do any trimming. I'll update the post when I get my headliner installed.
TweedDeluxe
TweedDeluxe is offline
PostPosted: Thu May 15, 2025 2:24 pm    Post subject: Re: Werksberg Panels Installed 1962 bus Reply with quote
Nice! I just got a bunch of those panels for my 67. I haven't tackled the headliner yet. My Bus had a cloth headliner so I am not really sure how these panels will fit for me. Look forward to seeing how yours turns out.
1967 - Deluxe Bus - Pearl White/Velvet Green
Malokin Martin
Malokin Martin is offline
PostPosted: Thu May 15, 2025 7:18 pm    Post subject: Re: Werksberg Panels Installed 1962 bus Reply with quote
They come with screws/washers. They’re just hidden really well in the packing.
PostPosted: Fri May 16, 2025 10:00 pm    Post subject: Re: Werksberg Panels Installed 1962 bus Reply with quote
Yep you're totally right. I missed them in all of the news paper.
Oh well, I have an abundance now.
PostPosted: Fri May 16, 2025 10:02 pm    Post subject: Re: Werksberg Panels Installed 1962 bus Reply with quote
Ill post fitment and pictures of the headliner and report back once its in!
PostPosted: Mon May 26, 2025 6:36 pm    Post subject: Re: Werksberg Panels Installed 1962 bus Reply with quote
I found a bench seat frame and had my buddy do some nice vinyl upholstery on it. The white is gonna be hard to take care of but man it looks sweet.
Im really liking the vibe.
PostPosted: Mon May 26, 2025 6:41 pm    Post subject: Re: Werksberg Panels Installed 1962 bus Reply with quote
So I got my headliner in finally and everything fits pretty well.
Its kind of cumbersome to get everything in straight and lined up.
Here's a picture for reference.
Im happy with how it turned out
BarryL Premium Member
BarryL is offline
PostPosted: Tue May 27, 2025 6:16 pm    Post subject: Re: Werksberg Panels Installed 1962 bus Reply with quote
blargon_7 wrote:
...my buddy do some nice vinyl upholstery on it.
Your Buddy its good.
PostPosted: Tue May 27, 2025 9:44 pm    Post subject: Re: Werksberg Panels Installed 1962 bus Reply with quote
Thank you!
PostPosted: Thu May 29, 2025 8:13 pm    Post subject: Re: Werksberg Panels Installed 1962 bus Reply with quote
Another angle of the bench seat.
Also, I am slowly moving the gauges from that wooden panel by the fresh air box to the dash. I already have the fuel gauge in the stock location and used an ISP stock looking gauge.
I bought a tachometer and a voltmeter that match, and will install them in a gauge mount from Shorty's, under the dash, to the right of the speedo.
The other two gauges up there are oil pressure and temp, and I plan on getting matching ones eventually, but Shorty's doesn't have a double mount for the left of the speedo in stock right now.
Ill keep the wiring for future install on those.
I have a stock metal block off plate that takes the place of the wooden panel up there that I plan on painting. I bought two cans of L31 paint that I got paint matched to my dash from my local PPG.
THEN, im thinking about getting a silver beige steering wheel to set it all off. Not sure yet. Let me know what you think
BarryL is offline
PostPosted: Sat May 31, 2025 6:07 pm    Post subject: Re: Werksberg Panels Installed 1962 bus Reply with quote
Will you paint your steering column, e-brake and shifter?
PostPosted: Sat May 31, 2025 8:06 pm    Post subject: Re: Werksberg Panels Installed 1962 bus Reply with quote
You know i probably won't go that far to paint those and that's why I was hesitant on the wheel because it would probably look out of place on a black steering column
BarryL is offline
PostPosted: Sun Jun 01, 2025 6:11 pm    Post subject: Re: Werksberg Panels Installed 1962 bus Reply with quote
It might look intentional and good with the shifter knob.
Buggeee
Buggeee is offline
PostPosted: Sun Jun 01, 2025 6:25 pm    Post subject: Re: Werksberg Panels Installed 1962 bus Reply with quote
I love what you're doing with this interior. It looks great!
Big Time 1988 Vanagon Westy
Dr. Kompressor 72 Super Duper
61 Turkis Pile (adopted out)
70bus Premium Member
70bus is offline
PostPosted: Mon Jun 02, 2025 12:45 pm    Post subject: Re: Werksberg Panels Installed 1962 bus Reply with quote
I did what you are doing with gauges - some tips:
before install, bend the mount from 90 degrees so it tilts upwards a bit. And since you don't want to bend it too far, consider determining what is the limit for each gauge, and mark the outside of the bezel w/ a spot of paint. At that height, the gauges are hard to see without taking eyes off road; with a dab of paint you can see the body of the needle in relation to the dab at a glance.
Also, those ISP-style tachs HATE electrical noise in your system. The needle will dance, or jump up a few hundred RPMs if they get interference.
Craig K
70 Neunsitzer
65 Pritschenwagen
Raoul the 65 singlecab
Karl the 70 nine-seater
PostPosted: Mon Jun 02, 2025 5:18 pm    Post subject: Re: Werksberg Panels Installed 1962 bus Reply with quote
Hey thank you for those tips, I appreciate it!
PostPosted: Mon Jun 02, 2025 5:19 pm    Post subject: Re: Werksberg Panels Installed 1962 bus Reply with quote
Thank you!
I almost went with black panels but decided grey was the way to do it. I am happy with it
TweedDeluxe
PostPosted: Wed Jun 04, 2025 2:10 pm    Post subject: Re: Werksberg Panels Installed 1962 bus Reply with quote
Looks great!
PostPosted: Wed Jun 04, 2025 3:39 pm    Post subject: Re: Werksberg Panels Installed 1962 bus Reply with quote
TweedDeluxe wrote:
Looks great!
I really expected the interior to sound hollow, like plastic banging around on metal but it really isnt that bad. I still need some type of sound deadening amd insulation though. I should have taken care of that before putting up the panels, but oh well
