My 71 squareback...fixing up a classic vw
Page: Previous  1, 2, 3, 4
Bobnotch
Bobnotch is offline
PostPosted: Mon Mar 17, 2025 2:45 pm    Post subject: Re: My 71 squareback...fixing up a classic vw Reply with quote
Looks good. Cool Keep getting after it a little at a time. Progress is progress. Wink
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
No_name4aday
No_name4aday is offline
PostPosted: Wed Apr 02, 2025 1:17 pm    Post subject: Re: My 71 squareback...fixing up a classic vw Reply with quote
My garage door was up and didn't want to go down. Both rollers unwound, took everything apart to get the door down tried to reset the tension rolled it up and lost it again. Has me lost ordered a fender stand and got all my flower gardens ready for summer. Back to sanding soon
squaretobehip
squaretobehip is offline
PostPosted: Wed Apr 02, 2025 4:44 pm    Post subject: Re: My 71 squareback...fixing up a classic vw Reply with quote
No_name4aday wrote:
I would suggest hanging your dash by the clock hole, vertically. That way you don't deform the speedo pod. I have a pipe and fitting from Home Depot with pool noodle around it and have a couple dashes hanging on it. It's the only way I've found to store them that avoids damaging or deforming them.
1963 Notchback - Ruby Red
1963 Squareback - Pearl White
1965 Squareback - Baltic Blue
Follow ISP West on:
No_name4aday
PostPosted: Thu Apr 03, 2025 5:41 am    Post subject: Re: My 71 squareback...fixing up a classic vw Reply with quote
I actually have the speedometer in it tried to prop it up flat with the glove box. I didn't want it flexed or warped, that spray on dye did better on old bits, the area around the speedometer needs touch up after I put it in, it already sat 9 months was quite snug. That is a soild tip thanks been keeping new bits inside the house for climate control gets pretty cold or hot in the shop
No_name4aday
PostPosted: Mon Apr 14, 2025 6:15 pm    Post subject: Re: My 71 squareback...fixing up a classic vw Reply with quote
Hand Sanding the curves and tight spots definitely not my favorite part so it's slow ha hahaha
Bobnotch
Bobnotch is offline
PostPosted: Tue Apr 15, 2025 11:10 am    Post subject: Re: My 71 squareback...fixing up a classic vw Reply with quote
Wait until you get to the louvers on the rear fenders, or the front fresh air vents. Those are a real PIA to do. Ask my wife, she hated doing them. Wink
Tram wrote:
Tram wrote:
No_name4aday
PostPosted: Tue Apr 15, 2025 7:30 pm    Post subject: Re: My 71 squareback...fixing up a classic vw Reply with quote
I'm not married Crying or Very sad Shocked
Bobnotch
Bobnotch is offline
PostPosted: Wed Apr 16, 2025 12:40 pm    Post subject: Re: My 71 squareback...fixing up a classic vw Reply with quote
So much for "cheap labor". Wink My wife does it so we can spend some time together. For the dash vents (cowl section) wrap some sand paper around a paint stick. That works for me. Then you can roll the used sand paper for the curved corners (kind of the easy part of doing them). The rear fender vents are just a PIA to do, so I use my 90*angle grinder with some of those 3M roloc discs on them to strip the paint off (not true sanding pads, but rather stripping discs). They also work on the cowl vent, but then you have to blend the bare metal out, which can almost result in stripping the entire section.
Tram wrote:
Tram wrote:
No_name4aday
PostPosted: Fri Apr 18, 2025 4:33 am    Post subject: Re: My 71 squareback...fixing up a classic vw Reply with quote
I'm plugging away at it try to get at least a couple hours a day. I got a big yard and all the spring setup has been the priority. That is almost done after the first weekend in May ill be free to hit it hard. Never sanded a car before but by the end part of a front I learned what it will be. I have some round foam tube, it's like the core they cut out of bike pads, in various sizes was thinking it may work on the vents. Paint stick sounds easier. So far it was 1x paint so I'm not sanding 10x layers. I just wanna do a wheelie Rolling Eyes still sanding
No_name4aday
PostPosted: Mon May 12, 2025 6:27 pm    Post subject: Re: My 71 squareback...fixing up a classic vw Reply with quote
I sprayed the front fender with rust encapsulater plus from east wood then filled the holes with metal epoxy and sanded that. I will spray the whole fenders with that. Not much filler required. The inside has a globby coating that will need chipped away in some places most looks solid. The fenders are in good shape for what it is overall. Got one ready about to coat on the outside. Figured out what blocks to use in the corners ect. So should be ready to flow on progrees again. I am not sure wtf I'm doing but this seems like a logical way to go and this be what it will be Rolling Eyes eventually primer and paint.
No_name4aday
PostPosted: Thu May 29, 2025 6:57 pm    Post subject: Re: My 71 squareback...fixing up a classic vw Reply with quote
Still sanding fenders this may take awhile not fond of this part haha woosh woosh woosh
Bobnotch
Bobnotch is offline
PostPosted: Fri May 30, 2025 12:34 pm    Post subject: Re: My 71 squareback...fixing up a classic vw Reply with quote
More than likely the inside portion of the front fenders is coated in "rock guard" to keep stone chips from breaking thru the paint causing rust. A heat gun and a scraper will remove that stuff easier than trying to sand it.
Tram wrote:
Tram wrote:
No_name4aday
PostPosted: Sun Oct 05, 2025 1:38 pm    Post subject: Re: My 71 squareback...fixing up a classic vw Reply with quote
Been awhile since I work on it. It's about the season for getting busy.
Page 4 of 4
