1965 sunroof 1200 named Mushu
Page: Previous  1, 2, 3 ... , 9, 10, 11  Next
tzepesh
tzepesh is offline
PostPosted: Sat May 17, 2025 10:49 pm    Post subject: Re: 1965 sunroof 1200 named Mushu Reply with quote
I repaired a bit a carburetor from a friend (bushed the throttle plate shaft, choke lever), and installed it. It responds to the tuning of both screws, mixture is ~4 turs out, air 1.5 turns in, steady idle at 900rpm. So I will have to get a better 34PICT 3 and rebuild for my own.
I received the metal tubes for sunroof cables and installed them. Sunroof works smooth, until I install the headliner part. That moves very hard all by itself, and makes the sunroof work very hard. Any ideas here: I checked the upholstery not to be overlapped, so to have thicker areas. I need to pull it off again. Also waiting for the metal reinforcement plate.
Yesterday we participated in an oldtimer cars event, "Photo finish". We drove around town and then parked in the city center in front of some musums, as it was also "night of the museums". We caught some rain, too. A few pics now, more will come.
Fid the bugs! Hint: we formed a semaphore. The yellow one is a good friends, who helped me a lot and for whom we worked the whole week up till late in the night to get running.
Flower stolen from the park Very Happy
Then, many artsy pics:
'74 1303S, L98B Viperngrun (extra glitter), German Look
'64 1200, Korosi red (extra glitter)
tzepesh
tzepesh is offline
PostPosted: Sun May 18, 2025 6:35 am    Post subject: Re: 1965 sunroof 1200 named Mushu Reply with quote
Another issue I have is the shifter, especially first gear. I also installed a quick shifter, because my wife is not so tall. But I can not get it to shift well no matter how much I tried to adjust the plate position. I checked 3 times that the plate has the correct orientation. Also, it gets to reverse whithout pushing down. It was working better without quick shift, at least the reverse. I found this thread to explain the best.
https://www.thesamba.com/vw/forum/viewtopic.php?p=4789422
tzepesh
tzepesh is offline
PostPosted: Mon May 19, 2025 11:25 pm    Post subject: Re: 1965 sunroof 1200 named Mushu Reply with quote
I bought a 67 transmission only because I wanted the long drive shafts. The wheels look funny so deep under fenders. Now, to see when I can pick it up, because it is 400kms away. Anyway I will not change anything till end of the year, to give some time to my wife to have fun with the car. Already she was complaining it "yells at her" at higher speeds (read that 70km/h Smile). So hopefully it is a medium ratio gearbox, otherwise I will just buy a 3.88 R&P and swap it. I avoided for years to work on gearboxes, but I have enough parts to make the fork alignment jig out of another case, and to somehow make the pinion nut tool. I'm only afraid of the pinion and ring setting.
tzepesh
tzepesh is offline
PostPosted: Tue May 27, 2025 12:26 pm    Post subject: Re: 1965 sunroof 1200 named Mushu Reply with quote
Yeah, well, remember the shifter issue? Look at this pics and tell me what is wrong...
I was just reviewing in my head how I assembled it, and why the reverse does not lock and it struck me. I was always looking at the plate orientation, and never at the position related to the spacer. Yes, it had to be under it. Changed places and yes, it shifts perfect now.
Today I took her out for a ride, to help another friend turn on his bus, 20km away. Drove at the incredible speed of 95km/h. Damn, this gearbox ia short! I need to get and prepare rhe other one with some proper gearing (read that 3.88 R&P).
And I need to address the accelerator cable, because it does not allow the throttle to close back completely.
tzepesh
tzepesh is offline
PostPosted: Tue Jun 10, 2025 4:19 am    Post subject: Re: 1965 sunroof 1200 named Mushu Reply with quote
600km round trip this weekend, to a meeting called BusStock and American Shine. Overall, a very nice event, family time, good weather. Many campervans, not only VW, more bugs than american cars Smile. It was up on a montain, ~1400m altitude, with 100m altitude difference in ~20km, so pretty steep. It ran without any technical problems, but my wife drove pretty slow as she was getting used to the car (quite different experience to my 1303). Three issues: one whitewall came off and broke, so in the end I will remove all of them. The wheels do have a thin white bans, so it will compensate. Front wheels are rubbing the fender edges, the dropped spindles have some offset... I will try to pull a bit on the fenders. Last, we had very strong winds and my wife struggled to keep it straight at high speeds. At 60km/h it was ok, more than that and the wind would push her. Alignment was properly done before leaving.
scarabee
scarabee is offline
PostPosted: Tue Jun 10, 2025 6:14 am    Post subject: Re: 1965 sunroof 1200 named Mushu Reply with quote
It's great that you and your wife are enjoying the air-cooleds together.
tzepesh
tzepesh is offline
PostPosted: Sun Jun 15, 2025 12:35 pm    Post subject: Re: 1965 sunroof 1200 named Mushu Reply with quote
Yup, it is! Kids too.
This week we finally received the TMI seat covers, ordered since November. Man, do they make a difference!
Bobs67vwagen
Bobs67vwagen is offline
PostPosted: Sun Jun 15, 2025 3:50 pm    Post subject: Re: 1965 sunroof 1200 named Mushu Reply with quote
Nice work, it's good to see you and family enjoying the car and traveling in it-good luck bob
tzepesh
tzepesh is offline
PostPosted: Mon Jul 21, 2025 12:10 am    Post subject: Re: 1965 sunroof 1200 named Mushu Reply with quote
Weekend work. I bough some more carpet and glued it to the rear seat back. Looks good.
I tried again to install the front sway bar. I made a 19mm drill and enlarged the holes in stock rubber bushings. Well, no success, the bushings become too thin and get pinched when trying to tighten the clamps. I tried again with the provided urethan bushings. Again, no go, they are too hard and can not get the clamp so close to install the retaining clip. I think the clamps with screw would work, but they were not provided in the sway bar kit... Now waiting for a set. Also, the sway bar touches the lower arm, maybe I did not get it in the right position or is it something else?
tzepesh
tzepesh is offline
PostPosted: Mon Aug 04, 2025 7:08 am    Post subject: Re: 1965 sunroof 1200 named Mushu Reply with quote
Long weekend fun. We attended a bug and bus show in Hungary, Gyomaendrod, 200km away. We go there every year from Thursdays to Sundays. Lots of cars, spa, pools, kids games, raffle, and the most funny tradition, the parade and water battle. Everyone in the village is out with water guns, buckets, hoses etc and from the cars, who is brave enough to drive with the windows down, can fight back in the same way. Busses (especially single cabs and dokas) are most suitable for sprinkling back, having the "stage" behind Smile. I will post some movie clips once available.
We even got a prize, I guess for beauty.
I received the clamps for front stabilizer bar, so now to install it.
I also picked up the '67 transmission I bought some time ago. It's short (4.375), so I will replace the R&P to 3.875. I intend to do the swap during winter, but I might have o do it earlier. There is a growling noise during deceleration, and I read it may be one of the bearings in the gearbox. MAybe some hints, what it could be? It is not present during acceleration, coasting, or when clutch is depressed.
And I need to address that acceleration cable, it keeps sticking and throttle plate does not close enough.
VW_Jimbo Premium Member
VW_Jimbo is offline
PostPosted: Mon Aug 04, 2025 8:21 am    Post subject: Re: 1965 sunroof 1200 named Mushu Reply with quote
That transmission noise could be mainshaft bearings or the differential carrier bearings. But check the three mounts first! Those can cause noises too!
Gear oil is good and full?
Axles are in good shape? Grease is good?
If everything checks out okay, you will need to disassemble the transmission and look for the problem.
Fingers crossed for it being low oil!
Jimbo
TDCTDI wrote:
67rustavenger wrote:
tzepesh
tzepesh is offline
PostPosted: Mon Aug 04, 2025 12:50 pm    Post subject: Re: 1965 sunroof 1200 named Mushu Reply with quote
Thank you for the ideas!
Gearbox oil, check. I replaced it completely. But I will check the level.
Mounts are new, but I will inspect.
I did not check anything on axles, not even disassebled them. Just new gaskets for setting tubes play/force. Grease for what?
I highly suspect mainshaft bearings... And I will swap the trans anyway. I will do the rebuild on the "new" one. I just hope the on on the car will last some more so my wife can enjoy the car till winter.
VW_Jimbo is offline
PostPosted: Mon Aug 04, 2025 5:48 pm    Post subject: Re: 1965 sunroof 1200 named Mushu Reply with quote
Sorry man! I am absent minded at times! Too many thoughts floating around! I was thinking of a IRS transmission. Ignore the grease comment.
Jimbo
tzepesh
tzepesh is offline
PostPosted: Tue Aug 05, 2025 12:20 am    Post subject: Re: 1965 sunroof 1200 named Mushu Reply with quote
No problem, it happens. Actually you got me thinking about the main difference between IRS and Swing. Just came to my mind that some oil from gearbox does flow into the axle tubes, maybe the oil level in the gearbox gets too low? There was no spot under the car, but even more important to check oil level.
tzepesh
tzepesh is offline
PostPosted: Wed Aug 06, 2025 11:30 am    Post subject: Re: 1965 sunroof 1200 named Mushu Reply with quote
Gearbox, solved. Oil level was too low. It took about 750ml to top up. It's leaking some around the axle tube paper gaskets, but I think the issue was that some of the oil got into the tubes. Does it say in any manual to top up after first ride? I will keep it under supervision until I build the other one.
And I installed the front sway bar. Half an hour job using screw type clamps. I expected the ends would be located under the lower arms, it sits somehow below and on the side. When it's lowered on wheels, it fits better. Let's see how it sits now on the asphalt.
tzepesh
tzepesh is offline
PostPosted: Fri Aug 08, 2025 2:07 am    Post subject: Re: 1965 sunroof 1200 named Mushu Reply with quote
Movie time! Have fun, it was a very entertaining event.
You can see our cars at 5.06 and 16.11
And here at ~3.30, 12, 16 and 30.
tzepesh
tzepesh is offline
PostPosted: Sun Aug 24, 2025 11:47 am    Post subject: Re: 1965 sunroof 1200 named Mushu Reply with quote
Does anyone know how these front beam reinforcement bars are supposed to be installed?
If I install them this way, the plate sits at an awkward angle, the bolts can not be tightened properly.
If I install them this way, they hit the frame head tin. And I really do not want to cut anything there. But this seems the proper way so everything aligns.
tzepesh
tzepesh is offline
PostPosted: Thu Oct 16, 2025 3:42 am    Post subject: Re: 1965 sunroof 1200 named Mushu Reply with quote
Preparing for the "long" gearbox. I received an engine hood for 1302 from a friend. I have another 65 engine hood. So, plan is to make a "convertible" hood. I have the measurements from another topic, fingers crossed I make this right Smile.
Rome
Rome is offline
PostPosted: Thu Oct 16, 2025 4:15 am    Post subject: Re: 1965 sunroof 1200 named Mushu Reply with quote
Good that you have measurements from a ~ '65 lid. Note that the vents from the 1302 are not "straight across" along the top line of the vents; they are higher at the inner ends so that they visually follow the top edge contour of the entire lid. By contrast, the vents are straight across on the ~'65. Here you can see this on a '65 lid (VOLKSWAGNUT gallery)-
Also evident on this early '64 (philippe)-
tzepesh
tzepesh is offline
PostPosted: Thu Oct 16, 2025 10:33 pm    Post subject: Re: 1965 sunroof 1200 named Mushu Reply with quote
Hello Rome, yes, I will follow the layout for 65 hood, not the 1302 positions.
Page 10 of 11
