What Battery are you using ?
Page: Previous  1, 2, 3, 4, 5, 6, 7, 8, 9
swharris
swharris is offline
PostPosted: Tue Apr 22, 2025 10:51 am    Post subject: Re: What Battery are you using ? Reply with quote
I'm running an 8v flooded(basically a golf cart batt.) in my 6V truck from Motive Energy- in Fullerton CA. Works great (so far)and gives me a few more V's without sending the reg into freak out mode. It's an experiment, and so far I've had to return one for not holding a charge over a long down period. It was about the same size and has the correct terminal location. Works with stock strap...sans cover. So far no negative effects... but I'm sure somone will say wtf are you doing!? lol.
BarryL Premium Member
BarryL is offline
PostPosted: Wed Jun 11, 2025 2:50 pm    Post subject: Re: What Battery are you using ? Reply with quote
Antigravity Battery for my '67 Westy.
Group 24 perfect fit.
Weighs 15 pounds same as my cat Bosco.
Exact bracket match front and back for the hold down.
cdennisg
cdennisg is offline
PostPosted: Wed Jun 11, 2025 7:01 pm    Post subject: Re: What Battery are you using ? Reply with quote
Looks like $$$$$$. I'll stick with whatever battery I find laying around.
BarryL is offline
PostPosted: Thu Jun 12, 2025 6:11 pm    Post subject: Re: What Battery are you using ? Reply with quote
Waited my whole life for this invention. The LiFePO4 are the crown jewel on yachts now.
don.ville Premium Member
Samba YardMan
don.ville is offline
PostPosted: Thu Jun 12, 2025 6:19 pm    Post subject: Re: What Battery are you using ? Reply with quote
$950 Shocked
with wireless jumpstarter built in...
04 Jetta TDI Page (SOLD)
29 Ford Model A Rat Rod (SOLD)
2015 Audi A8L TDI Quattro
cdennisg
cdennisg is offline
PostPosted: Thu Jun 12, 2025 6:22 pm    Post subject: Re: What Battery are you using ? Reply with quote
don.ville wrote:
$950 Shocked
I recently bought a nice little Nissan truck for the same price. Drove it home. Battery works fine, too. Came with jumper cables.
Samba YardMan
PostPosted: Thu Jun 12, 2025 6:26 pm    Post subject: Re: What Battery are you using ? Reply with quote
cdennisg wrote:
don.ville wrote:
$950 Shocked
Laughing
pyrOman
Fire Master
pyrOman is offline
PostPosted: Fri Jun 13, 2025 7:02 am    Post subject: Re: What Battery are you using ? Reply with quote
Been having issues with the optima red top one in the Dormy. So annoying that I finally went and bought a brand spanking new Interstate one. Was told that normally batteries last about 5 years. Turns out that the red top is over 7 years old. Confused
BarryL is offline
PostPosted: Fri Jun 13, 2025 11:43 am    Post subject: Re: What Battery are you using ? Reply with quote
don.ville wrote:
cdennisg wrote:
don.ville wrote:
$950 Shocked
Laughing
Sheesh. I only bought it charge up a dead thread.
cdennisg
cdennisg is offline
PostPosted: Fri Jun 13, 2025 11:46 am    Post subject: Re: What Battery are you using ? Reply with quote
BarryL wrote:
don.ville wrote:
cdennisg wrote:
don.ville wrote:
$950 Shocked
Laughing
Seems like it worked perfectly. Try again in a year to see if the warranty is any good.
BarryL is offline
PostPosted: Sat Jun 14, 2025 6:32 pm    Post subject: Re: What Battery are you using ? Reply with quote
Things I like about the Antigravity Battery so far.
No more mysterious burns on my skin.
No more mysterious holes in my jeans or shirts.
No more gishy-gooey mung on terminals or battery cover.
No more craning to see and fill battery waters.
No more smashed finger or tweaked back.
There's probably more but for now those.
chrisflstf
chrisflstf is offline
PostPosted: Sat Jun 14, 2025 7:24 pm    Post subject: Re: What Battery are you using ? Reply with quote
You can get a group 24 lithium ion for $169 at amazon.
https://www.amazon.com/12V-100Ah-Group-24-Recharge...8&th=1
Buskraut Premium Member
Buskraut is offline
PostPosted: Sat Jun 14, 2025 9:53 pm    Post subject: Re: What Battery are you using ? Reply with quote
That's not a starter battery... nowhere near enough output current.
Erik S
'65 Type 251 / Deluxe
'03 Eurovan MVWK
chrisflstf
PostPosted: Mon Jun 16, 2025 11:32 am    Post subject: Re: What Battery are you using ? Reply with quote
Always thought Group ratings were for size and amp capacity. Apparently not the case
Alan Brase
Alan Brase is offline
PostPosted: Tue Jun 17, 2025 11:22 pm    Post subject: Re: What Battery are you using ? Reply with quote
There is long history of using 8 volt batteries on 6 volt applications.
BUT, you need to adjust the voltage regulator up. Past 9 volt or 9.2 volts maybe.Quite likely there is more discussion of 8 volt on anotherr thread.
BTW, 8 volt seems like a great idea.
Al Brase
Projects: 67 sunroof bug, 67 Porsche 912 Targa, 70 Westy
Dec 1955 Single Cab pickup WANT 15" BUS RIMS dated 8/55, thru 12/55
To New owners: 1969 doublecab, 1971 Dormobile
Vanagons:
80 P27 Westy JUL 1979, 3rd oldest known US
83 1.6TD Vanagon, 87 Wolfie Westy daily driver, swap meet home
Page 9 of 9
