70bus  Samba Member
Posted: Tue May 13, 2025 9:56 am Post subject: Re: Rusty 65 SC restoration |
"Mine just clears the bumper. I pinch my fingers every now and then."
FWIW, that is the way mine is; I didn't say anything because I assumed it's wrong, and you would provide the 'correct' answer and I'd adjust it!
I'll try to get some measurements today but here's some pics
Lid to bumper is maybe a fat finger or two smaller ones wide. From looking at these pics, I assume my brackets are tipping bumper down towards the front; I seem to rcall stacking washers above and below to get them this good! There's a local VW meetup tonight and I'll try to see what other bumper/lid gaps look like. _________________ Craig K
70 Neunsitzer
65 Pritschenwagen
Raul the 65 singlecab
Karl the 70 nine-seater |
Kb65single Samba Member
Posted: Wed May 21, 2025 9:13 am Post subject: Re: Rusty 65 SC restoration |
70bus
thanks for the pictures they helped.
Driver's side guard was a little more beat up. PO's made a mess out of it. Looks like they tried to adjust it to fit the profile of the bumper but failed. Some typical dents on the face that were easy to pound out.
Welded some small repairs on both sides of the guard and it looked and fit better.
Tried on the towel bar and it didn't fit like the passenger side. Almost seemed like it was too long.
The position of the guards was different. Engine lid opening and taillight opening weren't the same distance from each other.
Measured the difference. Marked the engine lid opening.
The stance of the guards was very different also. Driver's side was straight vertical, and the pass side was slanted in at the top. I compared the front bumper, and those guards were slanted in at the top. Some pictures from the forums show both ways, but never different on the same bumper. 70bus showed them slanted in at the top. I couldn't keep it that way because it would just look weird. (The far away bumper guard is a little difficult to see because it blends in with all the crap behind it. Sorry!)
Getting the two guards symmetrical would require a bit of effort. Choose to slant the top of the guard in first and see if that would improve the position of the towel bar. Graph some metal on both sides of that guard and ground it to match the passenger side.
Unfortunately, moving the guard toward the center of the bus required moving the bumper blade bracket and drilling a new hole in the blade and plugging the old hole. Had to undo what I did to the frame bracket to center the blade in the bus. A pain in the ass but I didn't think I had a choice. Could have shortened the towel bar but that wouldn't cure the non-symmetry. More work than I wanted but ....
After I got done, I had to move the hole slightly on the side of the bumper blade. Looking more and more like a bus from the rear. Next will be the reproduction splash pans, what could go wrong.
70bus  Samba Member
Posted: Wed May 21, 2025 9:34 am Post subject: Re: Rusty 65 SC restoration |
Sweet! I agree the slanting-back LOOKS best... no idea if it's the stock stance. Maybe all of the slanted ones are the result of tipped bumpers! I did look around at the other buses at the meetup, and without opening a strangers lid, they looked to range from 'watch yr fingers' to a narrow but pinch-less sweep. Maybe a 1/2" in variation? My bumper tips forward, and I'm sure if I massaged that out I'd have more room for flesh in the gap.
Any ideas why your sides were so different? W/out scrolling back, I can't remember if both sides were replaced; maybe if one is OG the repro was off a smidge? Or do you think the culprit was the bumper and all of its sad history of dings? _________________ Craig K
70 Neunsitzer
65 Pritschenwagen
Posted: Wed May 21, 2025 12:41 pm Post subject: Re: Rusty 65 SC restoration |
70bus wrote: |
Any ideas why your sides were so different? W/out scrolling back, I can't remember if both sides were replaced; maybe if one is OG the repro was off a smidge? Or do you think the culprit was the bumper and all of its sad history of dings? |
I have no idea why the two sides were so different. 90% original metal on the corners of the bus. I'm guessing that my blade is a repro but hard to verify. No VW's stamped on the blade or brackets. The driver's side guard was just hacked on. so that is easy to explain. None of the rear bumper components are original to the bus. A true mutt bumper. Life would be so much easier with an original paint bus but then there would be nothing to do  |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 25912 Location: Olympia Wash Rinse & Repeat
Posted: Fri Jun 13, 2025 11:57 am Post subject: Re: Rusty 65 SC restoration |
FYI when taking off the front emblem, it is best to push against the posts with a piece of hardwood dowel. That will slide the speed nut clips right off.
Black set of rear bumper brackets are for 1968-71 bus.
Are you going to setup a drain system for the gas door like the bus models do in the engine compartment? Rain always get around that door to rust out the floors inside the trucks. _________________ In Stereo, Where Available! |
70bus  Samba Member
Posted: Fri Jun 13, 2025 12:26 pm Post subject: Re: Rusty 65 SC restoration |
E&B make a good suggestion - especially for someone with such welding skill.
I used JBWeld. Misses a few drips, but gets most of the dribbles.
70 Neunsitzer
65 Pritschenwagen
Posted: Fri Jun 13, 2025 1:52 pm Post subject: Re: Rusty 65 SC restoration |
Eric&Barb wrote: |
Are you going to setup a drain system for the gas door like the bus models do in the engine compartment? Rain always get around that door to rust out the floors inside the trucks. |
Barb&Eric
I'm glad you are paying attention to my build thread, chime in if you know I'm f-ing up because I know you know more than me about slit buses.( 25000+ posts and counting.) That information about the speed nut clips would have helped me 4 years ago but I'm glad I know that now. I'm not trying to be dick and I will remember that till I die because it was so frustrating. Unfortunately, I was by myself and had no help. Historically I usually learn best the hard way and that will never change. 68 years and counting.
Wish I knew about the black rear bumper brackets too. Having never restored a spilt bus before shows. Experience is worth its price in gold.
Now that you mentioned a drain system for the gas door. That is the last thing on my list that I have posted in my workspace. Picture to prove it and I love lists. Just haven't found a solution for it.
Posted: Fri Jun 13, 2025 4:00 pm Post subject: Re: Rusty 65 SC restoration |
No worries. Just figured to pass on the emblem info, you just never know if you might come across an old bus nose up in some attic and need that to remove the VW sign. The 1963-67 workshop manual also has that info in the body section.
Ages ago in the 1990s we came across a barn door single cab that this old fellow in very dry eastern Oregon had the local wrecking yard back in the 1970s torch the cab off so he could keep it in his back yard just for the glass in it for spare for his 1958ish bus. Torched off just below the rear window and just below the doors lower hinge across the nose. Of course the local kids back in the day were nice enough to go over to his place to throw racks thru most of the glass.......
Sold all of that to a guy down in south California, who drove a Toyota (?) sedan all the way up to Seattle area where we were at the time and back to that sunny climate. Have always wondered what happened to those parts. Did it complete a single project (pun intended) or many??
Anyway, wish we had seen your project earlier, not at all sure how we missed it. Love the work you are doing!!
The only thing we would warn you is that the green primer from what we have heard over the years is only good for shipping purpose, and should not be used for long term. Have even heard from some folks that surface rust has been found under the primer. Maybe remove green primer that you can reach now already in the truck and remove all on any piece going into it from now on. Then apply a decent primer. _________________ In Stereo, Where Available! |
Posted: Fri Jun 13, 2025 4:27 pm Post subject: Re: Rusty 65 SC restoration |
As for the gas door water intrusion situation, have yet to do anything with our runner single cab, but it has for the most part been kept under cover and not driven in the rain for many years now. Been thinking of making a "U" shaped gutter (with a bit of a "V" bottom to encourage water and dirt to slide on downward) about 1" tall, and wide enough that someone can run a finger into it to pull out and debris that might get into it.
Thinking of going pretty much the front to rear length of that panel with a 30 to 45 degree slope for the gutter going downward to the rear. Front end of the gutter would not need to be closed off with that steep of incline, and the rear end to funnel into at least a 13mm (1/2") pipe to drop down just in front of the rear wheel well. Weld the gutter to several points of the panel and use a drip rail or body panel seam sealer coating to keep water from getting past the gutter. Probably would need to make the panel side of the gutter higher to allow easy welding and visual of the coating/sealing.
Have also thought about a cover panel that would connect to the gutter and cover as much upward of the whole gas filler area to catch as much of the water spray that gets into there, but be easily removable with 4 to 6 machine screws. First would be to do the gutter and go from there. _________________ In Stereo, Where Available! |
70bus  Samba Member
Posted: Fri Jun 13, 2025 7:26 pm Post subject: Re: Rusty 65 SC restoration |
What year truck, E&B? Does it not already have a gutter like the one in my pic, above? On my truck, it was just a folded U in the neck support, and it looks like VW intended for gas and water to spill over those side openings and into t/c. I drilled a hole, added the copper drain pipe, and made little dams at each end of the U trough to encourage liquids to exit via the pipe. I've only had it in rain twice, so I can't say how well it works for that, but the gas that spills seems to exit properly through tube.
I bet Kb65single could zap that up in an hour and improve upon it. I think just welding tabs covering the U ends and properly welding in a drain tube would resemble the bay setup and be faster.
Kb, it looks like you are almost ready to install running gear and start work on kitting the cab? I mean, you've done nose-to-tail; what other metalwork is left? _________________ Craig K
70 Neunsitzer
65 Pritschenwagen
Posted: Fri Jun 13, 2025 8:03 pm Post subject: Re: Rusty 65 SC restoration |
70bus wrote: |
What year truck, E&B? Does it not already have a gutter like the one in my pic, above? On my truck, it was just a folded U in the neck support, and it looks like VW intended for gas and water to spill over those side openings and into t/c. I drilled a hole, added the copper drain pipe, and made little dams at each end of the U trough to encourage liquids to exit via the pipe. I've only had it in rain twice, so I can't say how well it works for that, but the gas that spills seems to exit properly through tube. |
Both the driver DEC62 and the spare MAR1963 SCs have the same gutter like you do, we just are not satisfied with the front to rear length of the stock gutter. Not only because the gas door is wider, but how any wind blowing around the door will affect the spread of moisture. Just figuring on getting as much of the water that gets into there out thru a drain, before it can pond up on the floor. _________________ In Stereo, Where Available! |
70bus  Samba Member
Posted: Fri Jun 13, 2025 8:13 pm Post subject: Re: Rusty 65 SC restoration |
Understood. VW was not worried about water as much as saving $5 on that bit.
Kb, while you are making a to-do list before paint... while laying in my t/c replacing the gas sender, I once again boggled at the amount of wasted space back there. I was thinkg a good welder could make a removable panel to protect the tank, yet still allow for installation of some storage containers back there. I saw a steel Army shell case that looked the right size to bolt it to the firewall and put in emergency supplies... cosmoline-dipped crank, rods, p/cs, hell a whole case! Pop off the main divider panel and haul out the spares. I can see you fabbing something with doors and roll-out shelves. :) _________________ Craig K
70 Neunsitzer
65 Pritschenwagen
Posted: Sat Jun 14, 2025 6:11 am Post subject: Re: Rusty 65 SC restoration |
[quote="70bus"]Understood. VW was not worried about water as much as saving $5 on that bit.
70bus
Yes, Hans und Franz did a real bad job of designing that part. The original floor in that section had multiple holes drilled in it to drain the water out on both sides. I am assuming that the treasure chest doors don't seal that well and the gas tank door and its surrounding metal is what it is.
I'm leaning toward drilling holes to let the water out and making a foam seal on the gas door to hopefully slow water from entering. Probably a metal pipe like you did. The VW gods will hopefully look kindly down at me for making a decent effort. The bus might get wet, but it won't be a daily driver.
Yes, getting ready to paint underneath and treasure chest area. Then load bed and bulkhead metal is all that's left. Forgot the gates damn! Those will keep me busy for a while. |
