Rebuilt Transmission popping out of 3rd under load
Gratsoy
Gratsoy is offline
PostPosted: Sun Jul 06, 2025 2:26 pm    Post subject: Rebuilt Transmission popping out of 3rd under load Reply with quote
Have been having a hell of a time with my tansmission.
When I had the engine out I had my, then working, transmission rebuild by a local shop as a "might as well" decision. At the time it was running well but I thought it should get resealed and new synchros.
Reinstalled it and it had zero 4th gear - would not engage at all. Removed it again and had them rebuild again. Apperently the 4th gear assembly was bad and needed to be replaced. No idea how they managed to mess that up.
Took the car out after re-installing again and now it shifts nicely but once you get into 3rd and start to accelerate it pops out. It does seem to shift into 3rd and if I hold the shifter gently it doesn't seem to complain. But, I cannot drive hands free of the shifter in 3rd. (At least I have 4th now....).
Is it possible that this could be anything other than an internal transmission issue? All mounts, linkages, even reverse lock out plate are brand new. Shifter moves nicely into gear (though it needs clutch to hit 4th when testing) - I've played with that a little and it doesn't seem to make any difference.
67rustavenger
67rustavenger is offline
PostPosted: Sun Jul 06, 2025 2:36 pm    Post subject: Re: Rebuilt Transmission popping out of 3rd under load Reply with quote
The shop that built the trans should make it right, period!
When my trans was rebuilt by a local guy here. It popped out of first gear under any load.
I called the builder and he said bring it to me.
I asked him if he meant the trans or the car. Bring the car to me, he stated.
Since I paid to have it rebuilt and it wasn't working as it should have, the shop did the r&r of the engine and trans. Rebuilt it correctly this time around and reinstalled the engine.
Three days later the shop called and said, come pick up your car.
I hired a Lyft and drove the car home with no issues.
Your shop should do the deed as my guy did if, they are a stand up kind of shop.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
Cusser
Cusser is offline
PostPosted: Sun Jul 06, 2025 5:13 pm    Post subject: Re: Rebuilt Transmission popping out of 3rd under load Reply with quote
I bought a rebuilt transmission for my 1970 from MoFoCo back in 2018; it's been fine.
zerotofifty
zerotofifty is offline
PostPosted: Sun Jul 06, 2025 5:29 pm    Post subject: Re: Rebuilt Transmission popping out of 3rd under load Reply with quote
I rebuilt my own, 47 years ago with my dad, still good, near 180k miles later The factory build only lasted 155K miles! It was popping out of first when I rebuilt.
Id be asking for my money refunded at this point, and find another shop to do it right.
What's that saying about insanity and doing the same thing over and over, expecting different results?
Good luck
Sorry About That Chief.
Give Peace a Chance.
Words to live by.
67rustavenger
PostPosted: Sun Jul 06, 2025 5:48 pm    Post subject: Re: Rebuilt Transmission popping out of 3rd under load Reply with quote
That would be the last place I'd look for a quality and timely transmission rebuild!
If, this is any indication of the quality of the workmanship that company does. I'd pass!
Reach out to German Transmission of America for a quality transmission build.
https://www.germantransaxle.com/
Buy Once, Cry Once!
zerotofifty
PostPosted: Sun Jul 06, 2025 7:04 pm    Post subject: Re: Rebuilt Transmission popping out of 3rd under load Reply with quote
what was wrong with the deep sump you show in the trash?
Words to live by.
Q-Dog
Q-Dog is offline
PostPosted: Mon Jul 07, 2025 3:47 am    Post subject: Re: Rebuilt Transmission popping out of 3rd under load Reply with quote
That doesn't look like a transaxle.
Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle
sodbuster
sodbuster is offline
PostPosted: Thu Jul 10, 2025 9:50 pm    Post subject: Re: Rebuilt Transmission popping out of 3rd under load Reply with quote
Pretty simple. The transaxle was rebuilt. (possibly unnecessarily?) There was a problem with 4th gear and taken back to be made right. It was taken apart again supposedly fixed only to discover it now pops out of 3rd.
The way I read it you are installing it yourself. if so Make the shop aware that there is still a problem with the transaxle and see if they want to see the whole car and check it over themselves. That's a start anyway. If they don't care to make it right once they have had a look ask for your money back.
Bruce
Bruce is offline
PostPosted: Sat Jul 12, 2025 2:26 am    Post subject: Re: Rebuilt Transmission popping out of 3rd under load Reply with quote
Gratsoy wrote:
... it was running well but I thought it should get resealed and new synchros.
There are two main reasons it will pop out of gear. One is the parts are worn out. The other is the 3-4 fork wasn't setup correctly. Since it was working fine, it is likely the latter.
Does this shop have a Beetle transmission shift fork jig?
How much wear is in the bore for the 3-4 shift rod in the gear carrier casting?
Bruce
Bruce is offline
PostPosted: Sat Jul 12, 2025 2:34 am    Post subject: Re: Rebuilt Transmission popping out of 3rd under load Reply with quote
You got lucky, because that's not the way the auto repair industry usually works. If you paid them to do the re & re, then that's on them when the trans doesn't work. However, if you carry the trans in for a rebuild, the re & re is on you.
esde
esde is offline
PostPosted: Sat Jul 12, 2025 4:35 am    Post subject: Re: Rebuilt Transmission popping out of 3rd under load Reply with quote
Generally:
trouble going in is a synchro issue
trouble staying in is a worn hub or slider, or incorrectly set shift fork.
3rd and 4th gear use the same shift fork and slider, it just moves to the front of the car to engage 4th, or rearward for neutral, and one more click rearward engages 3rd.
This is the second issue with this trans and specifically this group of parts inside the transmission. Ask specific questions. Ask exactly what was changed the first time it went back. What was replaced during the first rebuild. Post the answers here even if you don't fully understand them.
It could be something that's hidden or being difficult. But the second time it goes back I start to wonder about the shops abilities.
SD
modok wrote:
Bruce
Bruce is offline
PostPosted: Sun Jul 13, 2025 4:48 pm    Post subject: Re: Rebuilt Transmission popping out of 3rd under load Reply with quote
esde wrote:
Generally:
Also, worn fork or a worn bore in gear carrier for the shift rod.
