Engine lid foam
maco70
maco70 is offline
PostPosted: Sat Jul 12, 2025 4:11 pm    Post subject: Engine lid foam Reply with quote
Hi to all,
Is some of you have ideas for replacing the foam (full of dust and oil) under the engine lid ?
Martin from Montréal
1986 Vanagon GL full camper westfalia
(brown/tan interior)
Vanagonsgoslow
Vanagonsgoslow is offline
PostPosted: Sat Jul 12, 2025 4:13 pm    Post subject: Re: Engine lid foam Reply with quote
I would remove the foam and replace it with Dynamite adhesive backed sound deadener and heat insulation.
Red Ryder
Red Ryder is offline
PostPosted: Sat Jul 12, 2025 4:32 pm    Post subject: Re: Engine lid foam Reply with quote
Try the search feature for “engine cover insulation”. As always, others have attempted this project before you!
“Most everyone’s mad here. You may have noticed I am not quite all there myself.” — Cheshire Cat, Adventures of Alice in Wonderland
“Scarlett” — 1990 Vanagon Carat Wolfsburg Edition (Tornado Red)
“Nigel” — 1999 Jaguar XK8 convertible (Alpine Green Metallic)
maco70
maco70 is offline
PostPosted: Sat Jul 12, 2025 5:15 pm    Post subject: Re: Engine lid foam Reply with quote
Very kind reply, thanks my friends !
Martin
do.dah
do.dah is offline
PostPosted: Sat Jul 12, 2025 5:28 pm    Post subject: Re: Engine lid foam Reply with quote
You could also use a good dishwashing soap, I am a believer in JOY, do a really good cleaning on the underside of that lid. Rinse really really well. DO NOT USE A PRESSUREWASHER. Then let dry really really well.
Then, use a rubber spray, or a brush-on rubber under-coating.
Made my original stuff look new.
67rustavenger
67rustavenger is online now
PostPosted: Sat Jul 12, 2025 5:57 pm    Post subject: Re: Engine lid foam Reply with quote
Isn't Dawn Dish washing liquid soap the choice of animal rescue teams when there is an off shore oil spill?
If it's safe for cleaning oil off of Ducklings, it should be safe enough for cleaning that engine cover foam. Wink
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
do.dah
do.dah is offline
PostPosted: Sat Jul 12, 2025 6:40 pm    Post subject: Re: Engine lid foam Reply with quote
Ahh, the power of advertising...
"Dawn" tends to donate for the publicity and goodwill.
And while I do use Dawn, if I really wanna degrease something, JOY is what I turn to.
I use to be involved in the maritime industry. Both engine crew and deck crew demanded JOY. Fine,,, but if they're wanting many cases of the stuff,, questions were raised about crew hiding sloppy practices in violation of US maritime laws..
Ducklings are traumatized, fragile living things. Engine deck lids,,, not so much...
dhaavers
dhaavers is offline
PostPosted: Sat Jul 12, 2025 8:12 pm    Post subject: Re: Engine lid foam Reply with quote
Vanagonsgoslow wrote:
I would remove the foam and replace it with Dynamite DYNAMAT adhesive backed sound deadener and heat insulation.
Just to be clear. Semantics, semantics… Shocked
I’ve considered doing this for years but haven’t “pulled the trigger” yet.
BE CAREFUL OUT THERE, KIDS! Laughing Wink
- Dave
"The WonderVan"
Red Ryder
PostPosted: Sun Jul 13, 2025 7:46 am    Post subject: Re: Engine lid foam Reply with quote
- Dave
I knew the spelling police would see that! Laughing Laughing
Icebox500
Icebox500 is offline
PostPosted: Mon Jul 14, 2025 4:35 pm    Post subject: Re: Engine lid foam Reply with quote
I’m confident he meant “Dyno-mite!”
- Dave
87 Westy 2WD “Van Geaux”
2.2 Rebuilt WB
AZ Transaxle + Peloquin Manual Transmission
GW lift springs, solar, Burley front disc, etc...
New Orleans, LA (previously CO, WA, and CA)
Past
87, 90 Westys
64, 65 splittys + various air cooled
Kdj
Kdj is offline
PostPosted: Mon Jul 14, 2025 4:58 pm    Post subject: Re: Engine lid foam Reply with quote
Just did this on my engine swap. Mine was just falling into crumbs. If you are going for removal, know that there is a kind of chicken wire embedded in the foam. You will have to cut some of it. I used a flapper sanding disc on an angle grinder. It was a super dirty job wear eye and lung protection. I was amazed how thick it was. Used adhesive sound deadening pad to go back together.
pbrown
pbrown is offline
PostPosted: Mon Jul 14, 2025 6:04 pm    Post subject: Re: Engine lid foam Reply with quote
Dynamat does have a product that would work well. It's on my project list.
https://store.dynamat.com/products/the-hoodliner
The issue with the old stuff is that it's old. It starts to break down and sheds small foam bits all over the engine.
Patrick Brown
1986 Westy Syncro EJ25
Flickr --> https://flic.kr/s/aHsmQNUXEF
dabaron
dabaron is offline
PostPosted: Tue Jul 15, 2025 4:45 am    Post subject: Re: Engine lid foam Reply with quote
i used a few cans of plasticoat and it works well. it absorbs into the existing foam and becomes a dense mass and deadens the engine noise considerably.
1991 Vanagon GL Camper
dhaavers
dhaavers is offline
PostPosted: Tue Jul 15, 2025 8:52 am    Post subject: Re: Engine lid foam Reply with quote
I’ve thought about this, but no action yet. Glad to hear it can work! …after a good cleaning, I’m sure.
- Dave
"The WonderVan"
GreggK
GreggK is offline
PostPosted: Tue Jul 15, 2025 2:07 pm    Post subject: Re: Engine lid foam Reply with quote
Check out this thread...
https://www.thesamba.com/vw/forum/viewtopic.php?t=678838&highlight=
'86 2wd Poptop transplant
FAS TDi engine swap. Peloquin LSD
https://www.thesamba.com/vw/forum/viewtopic.php?t=692188&highlight=slow+but+steady
maco70
maco70 is offline
PostPosted: Sat Jul 19, 2025 6:40 am    Post subject: Re: Engine lid foam Reply with quote
Very good thread shared, many thanks !
Dynamat will be my way !
khughes
khughes is offline
PostPosted: Sat Jul 19, 2025 7:36 am    Post subject: Re: Engine lid foam Reply with quote
Mine was flaky and getting dusty so I coated the whole foam insert with several coats of spray on undercoating from FLAPS. Sealed everything up nicely and looks about the same as when I put it on. That was close to 20 years ago.
'86 Westy FAS GenV Turbo (Marvin)
