Front door questions - vapour barrier, alignment and foam piece
sake
sake is offline
PostPosted: Sun Jul 20, 2025 8:54 am    Post subject: Front door questions - vapour barrier, alignment and foam piece Reply with quote
Currently rebuilding the front doors and have a few questions.
Vapour barrier installation
I'm planning to install new vapour barriers, this material is available from several suppliers. What the best method is to attach it? Adhesive or tape for example?
Door alignment
The door currently sits slightly crooked, it's tilted a bit in the frame. What is the correct way to adjust the door so that it aligns properly?
Foam piece near the lock
There is a foam piece that seems to go above the door lock area. What is this piece for, and how is it supposed to be mounted (glue)?
Klister
Klister is offline
PostPosted: Sun Jul 20, 2025 9:22 am    Post subject: Re: Front door questions - vapour barrier, alignment and foam piece Reply with quote
https://www.youtube.com/watch?v=F3tQLdpwhFk
Gnarlodious
Gnarlodious is offline
PostPosted: Mon Jul 21, 2025 8:34 am    Post subject: Re: Front door questions - vapour barrier, alignment and foam piece Reply with quote
https://www.thesamba.com/vw/classifieds/detail.php?id=2660020
zuhandenheit
zuhandenheit is offline
PostPosted: Mon Jul 21, 2025 2:26 pm    Post subject: Re: Front door questions - vapour barrier, alignment and foam piece Reply with quote
Re the door alignment, you can get a little adjustment from the bolts, but if it's visibly misaligned you'll likely need a tool. My solo technique for the bolts is to loosen all four but keep one tight enough that the door doesn't shift from weight alone, and then pull it into new position and tighten up. Much better to just get help from a second person, I am sure.
When my passenger door was recently caught by a very strong gust of wind and would no longer close without slamming, I couldn't get enough adjustment with the bolts. I used one of these:
https://www.ebay.com/itm/356446844458?itmmeta=01K0...Swmjlk3xPB
It's easy, but can take a surprising amount of force.
As for the vapor barrier, I and many others have used shower curtain liner. I'm not sure what others are using and I think I just used spray adhesive since it's what i had around - but a much better choice would be butyl rubber caulk.
vanis13
vanis13 is offline
PostPosted: Mon Jul 21, 2025 2:32 pm    Post subject: Re: Front door questions - vapour barrier, alignment and foam piece Reply with quote
pic of how that tool is used
re shower curtain liner - doesn't 16CVs sell a formed vapour barrier?
zuhandenheit
PostPosted: Mon Jul 21, 2025 3:16 pm    Post subject: Re: Front door questions - vapour barrier, alignment and foam piece Reply with quote
Apparently. Link was posted in this thread, and it is a very nice option.
Although, if I were using it I expect I'd have to remove the molded speaker sections. I don't think it would provide enough air space. I have high end speakers (old JL xr 6.5 components) and have not in many years had moisture issues. I did recently install some foam baffles behind the speakers, and between the speaker basket and door card (this is the more important part, I'll bet). I was very surprised by the extent of the improvement.
Bulli Klinik
Bulli Klinik is offline
PostPosted: Mon Jul 21, 2025 5:59 pm    Post subject: Re: Front door questions - vapour barrier, alignment and foam piece Reply with quote
Let’s see a pic of that foam wedge. It’s been a while since I removed mine and forgot where it goes.
Mike K
Bulli Klinik
Colorado Springs
wbailey2112
wbailey2112 is offline
PostPosted: Wed Jul 23, 2025 1:36 pm    Post subject: Re: Front door questions - vapour barrier, alignment and foam piece Reply with quote
Some have used plastic carpet protection film as a replacement for the vapor barrier since it has a light adhesive already on it but I have not personally tried it (I just patched up the old barrier).
'74 Thing
'83 Westfalia
sake
sake is offline
PostPosted: Thu Jul 31, 2025 1:59 pm    Post subject: Re: Front door questions - vapour barrier, alignment and foam piece Reply with quote
So i bought these vapour barriers which is a single sheet. With 3M strip calk to put them one. I’m considering adding a small inner flap at the bottom, so that any rainwater that gets inside won’t run down the plastic and out at the bottom. What do you think?
16CVs
16CVs is offline
PostPosted: Thu Jul 31, 2025 5:45 pm    Post subject: Re: Front door questions - vapour barrier, alignment and foam piece Reply with quote
There is a bit of science with a vapor barrier. They belong installed in a certain position to enable the water to drain properly. That barrier shown will just capture the water and not allow it to drain.
The Vanagon door has 2 holes in place to drain the water away when the vapor barrier is properly installed.
Watch this video, it explains how they need to be installed and why. The barrier is 2 fold, one to send the water away from the door panel to prevent warping and also to keep the moisture level when you're trying to heat your cab. As a bonus it also keeps dust and dirt at a minimum.
https://youtu.be/F3tQLdpwhFk?si=XlQrBRX3FLlurGZR
VW spends a lot of time figuring these things out, just throwing some plastic on the door may make you feel warm and fuzzy but it will not cure the water problem.
Stacy
Samba member # 14980
sake
sake is offline
PostPosted: Fri Aug 01, 2025 2:12 am    Post subject: Re: Front door questions - vapour barrier, alignment and foam piece Reply with quote
Thanks! That does look interesting. I watched the video, and I see there are actually two single sheets. I could cut my door foils into two pieces like in the video and stick them exactly the same, what do you think?
vanis13
vanis13 is offline
PostPosted: Fri Aug 01, 2025 4:43 am    Post subject: Re: Front door questions - vapour barrier, alignment and foam piece Reply with quote
I think the way to go would be to get Stacy's/16CVs vapor barrier
tdivan82 Premium Member
tdivan82 is offline
PostPosted: Fri Aug 01, 2025 7:49 am    Post subject: Re: Front door questions - vapour barrier, alignment and foam piece Reply with quote
And that's a good reminder to also clean out the drain holes at the bottom edge of the door. After a few decades of use, they're often plugged up with dirt and debris. I used a thin flat screwdriver to poke up into the holes and agitate the debris, and then a shop vac with a crevice attachment to suck it all out from inside the door cavity.
- George
'82 Westy TDI (ahu)
'96 Passat TDI
bertobarb
bertobarb is offline
PostPosted: Sat Aug 02, 2025 2:19 pm    Post subject: Re: Front door questions - vapour barrier, alignment and foam piece Reply with quote
Turns out Stacy of 16CVs lives about 2 miles from me. I met up with him today to buy a set of his vapor barriers. What a nice guy. He shared lots of useful tidbits of info with me. I look forward to running into him again soon. Thanks, Stacy!
tdivan82 is offline
PostPosted: Mon Aug 04, 2025 6:24 pm    Post subject: Re: Front door questions - vapour barrier, alignment and foam piece Reply with quote
That's awesome. I ordered a set of his vapor barriers last week and they just arrived today. A top quality product, perfect fit, and affordable price. Thumbs Up
- George
'82 Westy TDI (ahu)
'96 Passat TDI
dublife13
dublife13 is offline
PostPosted: Mon Aug 04, 2025 6:38 pm    Post subject: Re: Front door questions - vapour barrier, alignment and foam piece Reply with quote
The styrofoam piece is used to keep the window from rocking when fully rolled down. Mine needs replacing and I havent been able to find a supllier for them. It is realy annoying to hear the window clunk everytime I accelerate.
16CVs
16CVs is offline
PostPosted: Mon Aug 04, 2025 8:43 pm    Post subject: Re: Front door questions - vapour barrier, alignment and foam piece Reply with quote
I am not sure what that foam piece is for, I've always thought it was a weather guard for the lock or an anti shim for security.
The piece that stops the window from rocking is higher up and even with top of the window line on the door. If you look in the door at the back you will see a 8mm hole usually with some glue and felt residue on it. I use those self adhesive felt chair bottom glides and stickit right over the hole.
Stacy
Steve M.
Steve M. is offline
PostPosted: Yesterday 6:31 am    Post subject: Re: Front door questions - vapour barrier, alignment and foam piece Reply with quote
Vapor Barrier.
I just took a hefty big garbage bag and cut it open to size it to the backside og the door panel.
I then used 3M Contact Adhesive spray to put it directly on the backside of the door panel to keep it from getting wet.
The power window switches I just plastic bagged them.
