Stock factory engine 1965
tasb
The Distributor Distributor
tasb is offline
PostPosted: Fri Jun 27, 2025 9:12 am    Post subject: Re: Stock factory engine 1965 Reply with quote
The spark plug ends of the wires can be removed and a correct vintage end can be installed. There might be a closer color match available if you make your own cables. Trick might be finding cable with a compatible inner core.
There are vendors that have the correct brass wire connectors. There are threads buried on the site about them and the tool that secures them to the wire. You can also remove the colored insulators from the tin connectors.
Ton’s Performance is a vendor of vintage ignition and electrical that is not VW specific. I’ve bought from them before and they are a good resource.
Roads Scholar
Member# 2059
Eric&Barb
Eric&Barb is offline
PostPosted: Fri Jun 27, 2025 11:03 am    Post subject: Re: Stock factory engine 1965 Reply with quote
matthew henricks wrote:
Thank you Eric & Barb, tasb & Everett.
I have oogled that black bug since it was discovered as the bases for my 64 bug project. Did not realize the similarities.
I have my hit list now.
A few follow-up questions.
1. What options are out there today for blue spark plug wires with the correct ends and correct color. Most are darker blue with the more modern spark plug end.
2. What would be a "OEM style electrical connector" other than not having the insulation?
3. Clarification on the copper comment. Your saying the vacuum and fuel hard lines are steel plaited with copper? Are you suggesting that what the higher end shops sell is pure copper? Why can't you use copper?
Thank you.
1. Have yet to find a good color match without huge logos on of the 8mm copper core spark plug wire in bulk reel form.
2. Best to read up in this thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=338938
Also: https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
3. Correct, steel plated with copper = stock. All the new metal lines are either steel or stainless steel, without any copper plating. Copper works hardens all to easy and so cracks all too soon. Cracks as in like an old fashioned steel coat hanger, that one day it just snaps when you hang a coat on it for the umpteen millionth time. Thankfully the fuel line does not have not have a concentrated stress point like a coat hanger does, because of this have yet to see or hear of a stock steel fuel line cracking since I got into the VWs in the late 1970s and over the 400,000 miles of driving VWs between us.
On the other hand we met a young lady decades ago who we took under our wing so to speak, and Barb felt like she was like a sister. She had out of the blue bought a 1959 double door panel bus, and had no idea how to work on it or what to look mechanically for that could cause her problems. She found me by calling the now legendary Wolfsburg Warehouse in Seattle where I volunteered one day a week. Ended up teaching her (in trade for work about our place) how to tune the engine, do an oil change, grease up the front suspension, change the gear oil (which the old stuff came out looking like chocolate milk in look and thickness), and much much more. The engine itself was a marvel of missing tin, and even a big hole in the front of the fan shroud for an external oil cooler system, but was running a stock oil cooler. DPO was the model of a proverbial three left handed mental midget. Anyway, one of her visits I noticed that the metal fuel line was sitting on the left side intake manifold heat riser, not good. So reached in and tried to slightly bend the line to keep it off a hot pipe and prevent rub thru that line. Instead the line broke in two like a piece of glass would. Turned out to be a pure copper line! I crawled under the bus to plug off the fuel line at the tank. Barb got out a fire extinguisher, I got soaked in fuel, fun times!! Next time she visited, a fuel tap (as should be done to any bus IOHO) was installed so the fuel could be shut off at the driver seat.....
In Stereo, Where Available!
Lind
Lind is offline
PostPosted: Fri Jun 27, 2025 11:47 am    Post subject: Re: Stock factory engine 1965 Reply with quote
Straight copper might get brittle and break with excessive flexing, where steel can probably deal with more of that. Steel with copper plating is what the factory did, and personally I try to keep things as close to factory as possible without a good reason to do it differently, and it is cheaper to make it a certain way isn't a good reason in my book. All that said, I get copper plated steel fuel lines from my supplier, They make the early style which thread in to the fuel pump. So the stock is available, not prohibitively expensive, so that is what I use when I can't find a good original.
Wanted:
matthew henricks
matthew henricks is offline
PostPosted: Wed Jul 02, 2025 9:33 am    Post subject: Re: Stock factory engine 1965 Reply with quote
Thank you. Making progress on the missing parts.
A few more questions.
1. Regarding manifold for governor. There is no way in a bus a non-governor intake manifold will fit with the air cleaner right?
I re-read thru the thread linked below looking for clues on what manifold is right for the 30 PICT-1. I think F or G and i think i am OK but rather not pull my intake to read a letter. My carb lines up to the hole in the fan shroud decent and the air cleaner elbow fits. Tight but fits.
https://www.thesamba.com/vw/forum/viewtopic.php?t=...e+manifold
2. More info on the governor brace.
Was that for all buses? Only images i could find are linked. The image of the factory manual below (and on page 1 of this thread) is hard to tell.
https://www.thesamba.com/vw/forum/album_search.php...t_dir=DESC
3. Carburetor ID tags. When were this used? The 28 PICT-1 i removed had one.
1964 Original Owner build Thread. https://www.thesamba.com/vw/forum/viewtopic.php?t=702135&highlight=
Ambulance Fan's. https://www.thesamba.com/vw/forum/viewtopic.php?t=627707&highlight=
Parts i am looking for:
64 bug nice used front/rear Black LHD floor mat.
PostPosted: Wed Jul 02, 2025 10:02 am    Post subject: Re: Stock factory engine 1965 Reply with quote
1. If you put a governor on a normal intake manifold, I think the air cleaner elbow on top of the carb would hit the frame cross piece on the ceiling of the engine compartment
2. 36hp engine brace. 36hp engines had a brace for whatever reason so you need a shorter one if it had a shorter manifold for the governor.
3. Carb ID tag - Every carb. had it? I think they get lost over time with carb rebuilds.
BulliBill
BulliBill is offline
PostPosted: Wed Jul 02, 2025 11:27 am    Post subject: Re: Stock factory engine 1965 Reply with quote
Hi Matthew and all,
The single port manifold (for a Transporter, with a speed/limiter/governor between the carb and shorter manifold) currently on my 1967 Campmobile is VW part number 211 129 701F. When using a speed limiter on a Bus, you must use the shorter manifold whose part number starts with 211, NOT 113! A "G" version is almost the same as an "F" version but features a little more factory grinding of the heat jacket around the manifold near the generator is slightly different. An "F" manifold wasn't even listed anymore in my '67 VW Dealership Parts manual, being superceded by newer "G" manifold. I suspect that either an "F" or a "G" version of the "211" manifold would be correct on the '65 Transporter engine.
Bill Bowman
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help!
matthew henricks
PostPosted: Thu Jul 24, 2025 12:57 pm    Post subject: Re: Stock factory engine 1965 Reply with quote
Guess i could use another round of scrutiny.
Items i know are wrong and in the works:
    - Short 12V coil & 12V sticker.
    - .006" valve gap foil decal.
    - Correct washers for some of the tin screws.
    - Correct dark end pre-heat tube.
    - Smooth fan belt.
Things i want to do but have no plan.
    - Air cleaner label. IMO this is silk screened and not a sticker
    - Air flap system.
    - F or G 211 SP manifold with good risers.
    - Better fresh air tube clamps. Too shinny.
    - fuel hose clamps. Pretty sure VW had non until 66. What to do for safety...
    - Correct air cleaner screw
Things i am going to live with
    - Battery. Not the right group size
    - Battery tender cable to battery
    What else? Please be critical.
Eric&Barb
PostPosted: Thu Jul 24, 2025 3:46 pm    Post subject: Re: Stock factory engine 1965 Reply with quote
Things i want to do but have no plan.[list]
- Air flap system.
You could try soaking the fresh air hose clamps in vinegar to lessen the shine (if that is what you mean instead of shinny) over nite. Would test on one clamp first to see if desired results and how long to soak. Old sheet metal trick to paint galvanized steel so it will have enough roughness to allow primer to grab into it and not just peel off later.
Interesting word "shinny", knew the one for climbing a pole, but not the others:
https://www.merriam-webster.com/dictionary/shinny
and
https://www.collinsdictionary.com/dictionary/english/shinny
Personally would just run the hose clamps on the pressure section. Better a bit off absolute correct than a VW BBQ.
Kommercial
Kommercial is offline
PostPosted: Thu Jul 24, 2025 5:38 pm    Post subject: Re: Stock factory engine 1965 Reply with quote
Time to ditch the nylock nuts on your engine case/fuel pump/generator stand.
Funny that the generator stand is missing a nut in the owners manual pic shown in this thread.
tasb
tasb is offline
PostPosted: Fri Jul 25, 2025 5:36 pm    Post subject: Re: Stock factory engine 1965 Reply with quote
https://www.thesamba.com/vw/archives/manuals/aug64deluxebus/page70.jpg
This appears to be a 40hp engine based on the throttle spring being located on the cable rather than an arm on the carburetor. The distributor would match to a 28 PICT Solex.
Roads Scholar
Member# 2059
BarryL Premium Member
BarryL is offline
PostPosted: Fri Jul 25, 2025 6:30 pm    Post subject: Re: Stock factory engine 1965 Reply with quote
But it has 1500 style intake.
70bus Premium Member
70bus is offline
PostPosted: Fri Jul 25, 2025 10:22 pm    Post subject: Re: Stock factory engine 1965 Reply with quote
I see some people put the earlier spring setup on to reduce throttle bushing wear, and sometimes to help a twitchy Accel cable behave. So if total stock is desired on a 1500 engine, that setup thom mentioned needs to go. If a 40hp, the cleaner goes. Plus those nylocs. ;)
I’ve got a 1679cc that looks completely stock (except for the orange hoses from fan shroud) from 3 feet. Tin work at apron is what gives it away. So do you want factory stock for 65, stock plus fudges for drivability like the cable spring, or stock from 3’? Your bus looks nice enough to go dead stock with the best parts you can find; you are almost there.
As for pic, didn’t VW sometimes recycle earlier photos in these owners manuals?
Craig K
70 Neunsitzer
65 Pritschenwagen
Raul the 65 singlecab
Karl the 70 nine-seater
BarryL is offline
PostPosted: Sat Jul 26, 2025 6:13 pm    Post subject: Re: Stock factory engine 1965 Reply with quote
I didn't go to the parts list dates thing but I personally never saw the hook spring on the carb before 1967.
tasb
tasb is offline
PostPosted: Sat Jul 26, 2025 7:13 pm    Post subject: Re: Stock factory engine 1965 Reply with quote
The M620/21 Buses came with 12v and 1500 engines, correct? Not sure if they used a 30 PICT or 28 PICT carburetor. The distributor would have matched the carburetor.
Prevailing opinions state that owners manual pictures are notoriously unreliable.
Roads Scholar
Member# 2059
PostPosted: Sat Jul 26, 2025 9:58 pm    Post subject: Re: Stock factory engine 1965 Reply with quote
End of 1965 for Buses:
70bus is offline
PostPosted: Sat Jul 26, 2025 10:20 pm    Post subject: Re: Stock factory engine 1965 Reply with quote
So for 66 buses, not 65 (but you could have a 66 MY that was made those last few days of 65 w/ these changes).
So according to this a 65 should have a 28pict-1 with no spring, and a spring at the fan shroud, correct?
Edit
- Without Guesswork states buses should have a 1500 standard from Aug 64 or perhaps Jan 63?
Craig K
70 Neunsitzer
65 Pritschenwagen
PostPosted: Sun Jul 27, 2025 1:19 pm    Post subject: Re: Stock factory engine 1965 Reply with quote
I think August, 1964.
January, 1963 seems to be VERY common for USA-Delivered 15/23-Window Deluxes so maybe standard for Deluxes only?
oakman
oakman is offline
PostPosted: Sun Jul 27, 2025 4:16 pm    Post subject: Re: Stock factory engine 1965 Reply with quote
Just to confirm, I have a very original 1965 (August 64') bus with it's confirmed original 1500cc engine and it has the spring on the cable only.
Brandon
Bobs67vwagen
Bobs67vwagen is offline
PostPosted: Sun Jul 27, 2025 5:03 pm    Post subject: Re: Stock factory engine 1965 Reply with quote
I had a 64 standard bus in the 1970s that was imported from Germany. It had the early 1500(no cam bearings) but I do not recall which carb it had.
BarryL is offline
PostPosted: Sun Jul 27, 2025 6:18 pm    Post subject: Re: Stock factory engine 1965 Reply with quote
Yes you have the thing that is supposed to be there. You also have the correct intake manifold.
Page 2 of 4
