.06” end play
aquifer Premium Member
aquifer is offline
PostPosted: Fri Aug 08, 2025 12:00 pm    Post subject: .06” end play Reply with quote
I saw a 1776 engine online. I was slightly interested but it said the end play was .06”. I asked if he meant.006”. He said no if you go that tight on a new bearing it will lock up.
I’d never heard that. Is that true? I’m eventually going to rebuild a 1600 dp for my 67 and am trying to learn all I can. Thanks in advance!
Project vehicles:
1967 Beetle #1. Bought in 2024, mostly original, October 1966 build date.
1967 Beetle #2. Bought in the mid 80's, restored myself in the late 90's, June 1967 build date.
1998 Jaguar XJR. Bought in 2015, rust free AZ car, refurbished myself. Driven in nice weather.
Parts needed:
Front & rear NOS or used OEM door panels for a '67 in the original Gazelle color (dark tan/light brown).
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Fri Aug 08, 2025 12:03 pm    Post subject: Re: .06” end play Reply with quote
.003"-.005" is the factory spec.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Max Welton
Max Welton is offline
PostPosted: Fri Aug 08, 2025 12:05 pm    Post subject: Re: .06” end play Reply with quote
And .006 is the factory wear limit.
1967 Type-3 Fastback
rcooled
rcooled is offline
PostPosted: Fri Aug 08, 2025 12:20 pm    Post subject: Re: .06” end play Reply with quote
aquifer wrote:
He said no if you go that tight on a new bearing it will lock up. Is that true?
Absolutely not!
And don't even consider buying anything from this guy either Shame on you
'63 Ragtop (current)
'65 Ghia coupe (totaled)
'69.5 Ghia convertible and
aquifer is offline
PostPosted: Fri Aug 08, 2025 12:47 pm    Post subject: Re: .06” end play Reply with quote
rcooled wrote:
Absolutely not!
Supposedly it only has 3,000 miles on it and was fairly cheap, which is why I was initially interested. I thought the end play thing was a typo til he confirmed it.
Definitely not interested anymore! Thanks for the replies. I'm sure I'll have a ton of questions whenever I go down the road to rebuild my engine, but in the meantime I'm stocking up on information. Very Happy
Project vehicles:
Parts needed:
ashman40
ashman40 is offline
PostPosted: Fri Aug 08, 2025 2:53 pm    Post subject: Re: .06” end play Reply with quote
I found this page which lists common crank endplay ranges for popular engines:
https://www.enginelabs.com/engine-tech/blueprint-s...t-endplay/
You can see from the above table the largest value is 0.012" = 12-thousandths of an inch (12/1000). That's seller is suggesting 0.060" = 60-thousandths of an inch (60/1000) is acceptable end play for a relatively new engine. That is 5x the largest value on the table! Shocked
The VW spec for end play is on the low end but it is not the lowest. I found that the GM LS IV engine has a recommended crank end play of 0.0015"- 0.0078" On the tight end that is 15-ten-thousandths (15/10,000) of an inch!!!
AshMan40
scrivyscriv
Samba Electrician
scrivyscriv is offline
PostPosted: Sun Aug 10, 2025 10:14 pm    Post subject: Re: .06” end play Reply with quote
You'll hear .06" as an audible THUNK CLUNK.
Think about how much stress that puts on the rods every time the clutch is actuated...
Robert in Memphis
Engine rebuild thread
VW_Jimbo Premium Member
VW_Jimbo is offline
PostPosted: Sun Aug 10, 2025 10:52 pm    Post subject: Re: .06” end play Reply with quote
Plus how radical the timing would be. Everytime you accelerated or decelerated, the timing would change!
Man, the drivability complaint would be crazy odd sounding!
Jimbo
TDCTDI wrote:
67rustavenger wrote:
