isomeades Samba Member
Joined: February 07, 2023 Posts: 49 Location: Albany, Oregon
Posted: Fri Aug 15, 2025 8:16 pm Post subject: Crankshaft Pulley/Pulley Engine Tin Question |
Hey There,
Working on getting the new (to me) engine in my bus set up as close to properly as I can manage, fixing all the jerry rig shenanigans we had from my "side of the road" install. I knew I was going to have to face this at some point, and that time has come.
Here's the issue today - The crankshaft pulley is seized, and I mean seized, in place on the crankshaft. I've tried removing it with the classic 2 large screwdrivers, applied heat, applied ice, anything I could think of, it didn't budge. So, following the advice I saw here on the forum, I went and got a set of 2 jaw pullers, and used those on it (after heating the pulley wheel with a torch to increase my chances. No Dice. In fact, it actually started to bend the pulley around the stamped puller holes. See the photo below...
Now my dilemma is this. I don't currently have the pulley engine tin mounted on the engine. I have the piece off my old engine, which does mate up properly with the '72 type 1 conversion tin I have (it seemed to match up fine when the previous engine was installed). How am I going to install it?
My Dilemma
As I see it, the options are
A) Figure out how to get the pulley wheel off (suggestions, anyone?)
B) fins some way to install the tin without removing the pulley wheel. I can see this would almost certainly involve splitting my engine tin in two so I can even get it in place, and I can't see any way of accessing the bolt holes for it behind the pulley wheel short of cutting new holes in the pulley wheel. Has anyone ever been in this situation before? And if so, any suggestions?
Thanks, and any help or ideas are appreciated.
[/i] _________________ Seth
'72 Bay |
Posted: Fri Aug 15, 2025 8:42 pm Post subject: Re: Crankshaft Pulley/Pulley Engine Tin Question |
Drive some wooden wedges between the pulley and the engine block as close to opposite each other as you can. Now hold a socket (that will just fit through the bore of the pulley) on the end of the crankshaft and give it a good whack with a hammer. |
SGKent  Samba Member
Joined: October 30, 2007 Posts: 42773 Location: at the beach
Posted: Fri Aug 15, 2025 8:53 pm Post subject: Re: Crankshaft Pulley/Pulley Engine Tin Question |
I would use some penetrating oil like liquid wrench over night. Then try using the bolt to tighten it then loosen it then tighten it then loosen it etc., to see if I could not get a little more movement.
also, I think you want the jaws facing in, not out. _________________ "Most people don't know what they're doing, and a lot of them are really good at it." - George Carlin |
Abscate  Samba Member
Joined: October 05, 2014 Posts: 24060 Location: NYC/Upstate/ROW
Posted: Sat Aug 16, 2025 3:20 am Post subject: Re: Crankshaft Pulley/Pulley Engine Tin Question |
Heat cool oil , heat cool oil, heat cool oil, heat cool oil, heat cool oil.
Use a 50-50 mix of ATF and acetone for oil
Heat for 60 seconds on high propane blast or mapp gas.
Cool for an hour _________________ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ π π π |
richparker Samba Member
Joined: November 24, 2011 Posts: 7554 Location: Durango, CO
lil-jinx Samba Member
Joined: August 14, 2013 Posts: 1649 Location: New Brunswick,Canada
Posted: Sat Aug 16, 2025 7:31 am Post subject: Re: Crankshaft Pulley/Pulley Engine Tin Question |
try the method suggested by wild things,you can also use your puller in combination with the wood wedges,and smack the puller screw,being careful to protect the crank shaft end.it's the smack that pops it free. _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=620186
1968 Dune Buggy sold dec 2024
1974 parts bus
A smart man learns from his mistakes,a very smart man learns from other's mistakes. |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 79748 Location: Sneaking up behind you
Posted: Sat Aug 16, 2025 7:59 am Post subject: Re: Crankshaft Pulley/Pulley Engine Tin Question |
I use an air chisel with a blunt rod in the center of the bolt hole to "shock" the crank. I have a second person try to wiggle the pulley off with two large levers. Be careful not to booger up the threads. _________________ Glenn
Member #1009
#BlueSquare
Χ’Φ·Χ ΧΦ΄Χ©Φ°ΧΧ¨ΦΈΧΦ΅Χ ΧΦ·Χ |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 11225 Location: Oregon
Posted: Sat Aug 16, 2025 8:09 am Post subject: Re: Crankshaft Pulley/Pulley Engine Tin Question |
Here's a tool made to remove the pulley.
https://www.thesamba.com/vw/classifieds/detail.php?id=2445485 _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
2003 Astrovan? GFYS again, Xevin!
Don't let your bad ideas remain, ideas! |
Glenn  Mr. 010
Posted: Sat Aug 16, 2025 8:13 am Post subject: Re: Crankshaft Pulley/Pulley Engine Tin Question |
I've seen those bend the hub on a badly seized pulley. But then I guess you're not gonna reuse it anyway. _________________ Glenn
Member #1009
#BlueSquare
Bnanwel Samba Member
Joined: November 10, 2022 Posts: 310 Location: Ft Lauderdale
Posted: Sat Aug 16, 2025 8:21 am Post subject: Re: Crankshaft Pulley/Pulley Engine Tin Question |
[quote="Abscate"]Heat cool oil , heat cool oil, heat cool oil, heat cool oil, heat cool oil.
If you heat cool oil is it still considered βcool oilβ? _________________ β72 Karmann Ghia Conv.
β73 Karmann Ghia Coupe
β74 Karmann Ghia Coupe
β70 Deluxe
β72 Deluxe |
Posted: Sat Aug 16, 2025 8:59 am Post subject: Re: Crankshaft Pulley/Pulley Engine Tin Question |
Glenn wrote: |
I've seen those bend the hub on a badly seized pulley. But then I guess you're not gonna reuse it anyway. |
I typically use the two pry bar method you described above.
I was just suggesting a different tool to use in tight, hard to leverage situations. _________________ I have learned over the years.
Buy Once, Cry Once!
Posted: Sat Aug 16, 2025 9:55 am Post subject: Re: Crankshaft Pulley/Pulley Engine Tin Question |
Excellent, thank you all for the advice. I'll give these suggestions a whirl today, fingers crossed they'll work. Thanks! _________________ Seth
'72 Bay |
Posted: Sat Aug 16, 2025 5:12 pm Post subject: Re: Crankshaft Pulley/Pulley Engine Tin Question |
[quote="Bnanwel"]
Abscate wrote: |
If you heat cool oil is it still considered βcool oilβ? |
Heat it up.
Let it cool
Hit with 50/50 atf acetone
Wait
Repeat _________________ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ π π π |
Posted: Sun Aug 17, 2025 7:43 am Post subject: Re: Crankshaft Pulley/Pulley Engine Tin Question |
Just busting your balls. _________________ β72 Karmann Ghia Conv.
β70 Deluxe
β72 Deluxe |
Posted: Sun Aug 17, 2025 9:56 am Post subject: Re: Crankshaft Pulley/Pulley Engine Tin Question |
Bnanwel wrote: |
Just busting your balls. |
Enjoyed it
TomWesty Samba Member
Joined: November 23, 2007 Posts: 3539 Location: Wyoming,USA
Posted: Tue Aug 19, 2025 9:19 am Post subject: Re: Crankshaft Pulley/Pulley Engine Tin Question |
richparker wrote: |
More heat! |
This! My MAPP gas torch has become one of my most used tools. Thanks to Steve (Abscate) for suggesting it to me in a thread long ago. _________________ If you haven't bled on them, you haven't worked on them.
Visit: www.tomcoryell.com and check out my music! |
jlrftype7 Samba Member
Posted: Tue Aug 19, 2025 10:57 am Post subject: Re: Crankshaft Pulley/Pulley Engine Tin Question |
I've had really good luck with this type of Penetrating Oil/Loosener.
Seems like a Gimmick, but isn't. There are other brands out there selling the same stuff, so I guess the Formula isn't under a Patent anymore.
Word of warning ,it does smell a bit, use with good ventilation.
I consider it my Hail Mary type stuff for very rusted items, just follow the directions for the amount of time required for the spray ON.
https://www.autozone.com/greases-and-gear-oil/mult...0aa2201efd _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
β84 Tin Top - Hilga....Auto |
SGKent  Samba Member
Posted: Tue Aug 19, 2025 1:19 pm Post subject: Re: Crankshaft Pulley/Pulley Engine Tin Question |
I broke several exhaust studs on a sports car. A friend, an automotive machinist, who it went to, to drill the broken studs out, handed me a can of Liquid Wrench, and told me to put it on it, go get lunch, come back and see it the remnants would come out. They came out by hand. Many of these oils have chemicals in them that change the rust form from red to black. The black form of rust is a smaller molecule, and less binding than the red version. Kroil, PB Blaster, Liquid Wrench, and many more - they all work well. Some folks try WD-40 but is is not a lubricant. It is mostly solvent like a parts washer with some oils and things that help keep flash rust away. _________________ "Most people don't know what they're doing, and a lot of them are really good at it." - George Carlin |
