slowfiveo Samba Member
Joined: February 01, 2009 Posts: 118 Location: Elizabethtown, KY
Posted: Mon Nov 03, 2025 4:13 pm Post subject: Is it worth trying to build my type 4? |
Hey guys, I'm a stray from the Vanagon forum. You can't find a lot of type 4 knowledge on that side of theSamba.
I bought an 82 aircooled Vanagon Westy earlier this year, I'm an aircooled guy at heart, so I went this route rather than going with a watercooled example, plus the price was sooo right. The engine is loosing oil and making some concerning noises, etc. It runs OK, but I knew going in that the engine had a lot of miles on it and had seen plenty of adventures. I was lucky enough for it to drive me home from Denver to Kentucky after purchasing it. The PO had the cooling tins wired open and installed an external cooler, so I can only assume that it was overcooling most of it's life.
So, with all that being said. I'm in need of at the very least pulling my engine and doing a refresh, but I'd like more power. There's some big bore kits out there, different cams, etc. My question is....is it conceivable to add more power to this engine without sacrificing what reliability it could have? Or should I make a deal with the devil and start piecing together cooling bits for a subaru swap? At the end of the day, I know nothing about the watercooled engines, but I feel like I can figure out the aircooled engine on the side of the road. That's not to say I'm not willing to learn though.
I plan on daily driving it most days, with an occasional road trip with my family. Hoping to retain my fuel injection, but not against losing it if it makes sense. Talk me out of the swap. |
timvw7476 Samba Member
Posted: Mon Nov 03, 2025 9:09 pm Post subject: Re: Is it worth trying to build my type 4? |
advice is to measure each cylinder p.s.i. warm . 105-110+ drive it till it pukes, but put the proper air flaps thermostat on it.
If this thing made it to Kentucky then it is intact.
As far as Subaru just go buy one. I did. Not to swap. Just in case snow arrives.
I would consider re-ringing before pulling it out as well.
A Vanagon with a Type IV will never be real fast & even if it was it would be a little dangerous.
Also do the pushrod tubes O-rings & check the oil pressure switch, those love to seep oil after several years. |
richparker Samba Member
Joined: November 24, 2011 Posts: 7678 Location: Durango, CO
my59 Samba Member
Joined: August 13, 2003 Posts: 4000 Location: connecting the dots
Posted: Tue Nov 04, 2025 4:25 am Post subject: Re: Is it worth trying to build my type 4? |
I'd be doing some investigation before I drop the engine-
Valve adjustment
Compression test cold
Compression test warm
Oil pressure
Vacuum leak check.
Fuel pressure check
Maybe a cylinder leak down test.
You will want the info before you take things apart, as it will help you know where you mY need to focus on.
The FI is stupid dependable if it has not been hacked. Fi and vacuum leaks dont get along.
Hydro lifters like clean oil to stay pumped up.
You can pull the valve train, remove the pushrods and tubes (keep em in order so they go back where they came from) and look at the cam lobes to see the wear pattern and how worn the cam lobes are. _________________ my59: Well son, my grandfather died before I got to drive it, so does that answer your question?
Other:'12 Jetta, '77 Benz 300D, and a 74 MG Midget. |
vwmaniaman Samba Member
Joined: June 07, 2005 Posts: 607 Location: Grand Rivers,KY
Posted: Tue Nov 04, 2025 6:45 am Post subject: Re: Is it worth trying to build my type 4? |
I had an 83 with the air cooled that was a 7 passenger and drove it to Arizona and Back in the winter. It also was an automatic with AC and auxillary heater. I liked that air cooled motor and it did everything I wanted. Speedy it is not and 70 mph all day was not a problem. Keeping us warm was the problem as we hit an ice storm near Amarillo and they closed the interstate made us all go to a motel. Frozen doors and locks and wipers and even the gas cap hole froze over.
The motor or transmission was reliable. _________________ Working on a VW is like fun with a friend!
65 Beetle
75 Westy "Pumpkin Van"
86 Westy "Brown Betty"
87 Cabrio |
Clatter Samba Member
Joined: September 24, 2003 Posts: 7846 Location: Santa Cruz
Posted: Tue Nov 04, 2025 8:22 am Post subject: Re: Is it worth trying to build my type 4? |
I'm a big proponent of taking these apart and cleaning/inspecting everything.
Too much time to be wasted chasing your tail with things that might have been done wrong by past owners.
If it doesn't have a bunch of problems then you aren't in for a lot of parts cost,
if it does, you'll want to know before being stuck on the side of the road.
It's all about problems.
Get rid of the problems and you'll find happiness.
Don't let a tired old engine give you an idea how these things run.
In good shape a stock engine hums along just fine.
Fast enough for an old van...
Build in my sig might help.
If you're not into jumping in with both feet don't bother.
1982 was too long ago to get away with patching things up anymore.
It's already been done too many times. _________________ Bus Motor Build
It does not exist! |
SGKent  Samba Member
Joined: October 30, 2007 Posts: 42886 Location: at the beach
Posted: Tue Nov 04, 2025 8:35 am Post subject: Re: Is it worth trying to build my type 4? |
daily driver. 45 year old car with scarce and expensive type four parts. Hmmmmn, what can possibly go wrong there. Worse, as a daily driver your insurance company will only insure you to about a quarter of what it cost you to restore your vanagon. They will call all the work and parts, deferred maintenance that the other owner did not keep up.
If you study threads from some of the folks here like Steve (Clatter) and see what he puts into an engine build, including the time, you may want to rethink this, because it is likely it will be down for months while you are sourcing parts and machine shops.
Air cooled Vanagon owners ofter come here for help with their engines because of little type 4 air cooled support in the Vanagon forum. Welcome. _________________ George Carlin:
Skills@EuroCarsPlus:
"never time to do it right but always time to do it twice"  |
lil-jinx Samba Member
Joined: August 14, 2013 Posts: 1763 Location: New Brunswick,Canada
Posted: Tue Nov 04, 2025 9:00 am Post subject: Re: Is it worth trying to build my type 4? |
If the compression numbers are decent then spend some time looking over the crankcase ventilation system as PCV system that doesn't vent properly can cause an engine to use massive amounts of oil. The original style PCV valve is not available but there are work arounds than can be found here on The Samba.
There are lots of places these engines can leak oil several of which can be fixed with the engine installed in the rig.
For power, a bit more aggressive cam will help a lot even with stock heads. Read up on the Camper Special from Len Hoffman. |
SGKent  Samba Member
Posted: Tue Nov 04, 2025 3:49 pm Post subject: Re: Is it worth trying to build my type 4? |
also, the next question will be who does a good job rebuilding type IV engines. About 20 people here will standup and hold their hands up. They can detail all the work they put into getting their engine running excellent. Then the next question is how many of those 20 will do it for someone else. Then there will be crickets. There is too much time and research that goes into each one of these engines now. Bearing quality can be crappy. Getting someone to rebuild a set of heads for a transporter is non-existent. In fact the last person to say they found someone had to return the heads for a refund they were so badly done. New aftermarket heads are available but pricey when set up with quality parts. It is the lack of parts that makes it hard. One cannot just order parts on a Tuesday, get 100% quality parts on Thursday, and build it over the weekend. Tin may be missing from prior builds. Tin may be cracked etc.,, Exhaust systems may be in such bad shape that it needs replacing. Someone may spend 75 hours of their time trying to find a specific part - how do you bill someone for that time? _________________ George Carlin:
Tbob Samba Member
Joined: May 26, 2007 Posts: 445 Location: Pensacola, Fl.
Posted: Mon Nov 10, 2025 6:34 pm Post subject: Re: Is it worth trying to build my type 4? |
I bought my last parts vanagon in Elizabethtown! Small world. Not a lot of vanagons in your neck of the woods. One less after I bought the one I did!
The air cooled type 4 engine is barely adequate in areas with mountains and serious hills, but an area like yours it can work. There are some people who have done work on high performance type 4s, notably Jake Raby, who sold most of his developments to LN engineering, which I think is somewhere in Illinois. Also, European Motor Works in the LA area did high perf Type 4 stuff.
But the problem comes to just the cost of getting more performance. Theres not a lot of choices, and that means economies of scale don't work in your favor. Also, parts quality for the aftermarket stuff can be awful, and without good knowledge of what you are dealing with, it can cost a lot for very little. Thats why so many people go with swaps, carefully done you can get a lot more performance for less. Subaru, 2.0 ABA VW, among others. Theres lots of info on thesamba, here. Check the FAQS, under engine swaps.
But if you want to continue with your type 4, get Tom Wilsons "How to rebuild your VW engine" book, and look up Clatter's thread here on thesamba.com about rebuilding a Type 4 engine using used, but serviceable, parts. Both of those sources should give you some more info on your quest. _________________ 1969 Deluxe, owned since 1973
1973 Westfalia, owned since 1983
1980 Westfalia, watercooled conversion
1985 Westfalia, stock!
1986 Westfakia, Audi I-4 conversion
A couple of trucks and a couple of Jeeps |
Joined: January 01, 2007 Posts: 17913 Location: sticksville, ct.
Posted: Mon Nov 10, 2025 7:50 pm Post subject: Re: Is it worth trying to build my type 4? |
what's your end game?
A T4 was barely adequate for a bus, in a Vanagon, it's a joke at best.
If you plan on really REALLY using this just go Subaru. Everything is there to add the radiator and you don't even need to cut the aircooled nose to have it work (unless you add A/C)
There is no chance in hell I would build a T4 for a Vanagon and expect it to live for very long.
and for the same or less money you can have a Subaru in there _________________
| gprudenciop wrote: |
| Jake Raby wrote: |
| Thanks for the correction. I used to be a nice guy, then I ruined it by exposing myself to the public. |
| Brian wrote: |
| Also the fact that people are agreeing with Skills, it's a turn of events for samba history |
