Clatter Samba Member
Joined: September 24, 2003 Posts: 7846 Location: Santa Cruz
Posted: Sat Oct 25, 2025 2:57 pm Post subject: Re: T2 VW bus convert to EV |
| airschooled wrote: |
Yeah fuck people enjoying their hobbies.
Did I do it right? I am enough of an asshole? |
 _________________ Bus Motor Build
It does not exist! |
79 EV VW Samba Member
Posted: Fri Oct 31, 2025 10:02 pm Post subject: Re: T2 VW bus convert to EV |
Wow! look at all the replies. Back to the EV conversion
The missing 1/2 shaft were ordered from EBay and finally arrived. Below is a photo of the installed 1/2 shafts. This was another adventure in VW bus design and part installation.
I decided to scrap the entire shag rug interior and start over for EV conversion. This was an easy decision given that I am still waiting on China to ship batteries. I am now in the process of re-designing the entire bus interior. The EV battery layout drove the desicion to gut the the van. The batteries will be on the floor in two battey boxes. Above the battery boxes will be 2 bucket seats. One seat and supporting brackets will be removable on the sliding door side to allow transportation of a folding recombent trike. Photos below show the gutted bus and pile of old shag carpeting.
Below is a photo of the battery box and rear bucket seat layout as seen from the sliding door
lil-jinx Samba Member
Joined: August 14, 2013 Posts: 1792 Location: New Brunswick,Canada
Posted: Sat Nov 01, 2025 6:08 am Post subject: Re: T2 VW bus convert to EV |
just doing some reading on roof racks and the load limits,vw say 220 lbs on the rack suppprted by the gutters,so according to that you could put half of your batteries on the roof,lol no worries about cog ,biggest concern is the fore and aft placement of the weight. _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=620186
1968 Dune Buggy sold dec 2024
1974 parts bus
A smart man learns from his mistakes,a very smart man learns from other's mistakes. |
Posted: Sat Nov 01, 2025 8:20 am Post subject: Re: T2 VW bus convert to EV |
That is an interesting Idea to put batteries on the roof. I can think of a couple of problems with implementing this design. It could work, but the problems may not be worth the internal space that was saved.
The big problem, of course, is where I would mount my surf board?
The center of gravity would be quite high.
There are a lot of cables that have to be routed, including 2-Ought high voltage welding cable, thermister cables, and battery monitoring lines to each battery cell. On the floor this is easy: under the bus. On the roof will require holes in the roof, or run them outside the bus, Frankenstein style.
The gutter rails on my bus are about 50% rusted out. I plan to repair them with grinding and bondo. I dont think bondo will hold 200lbs.
I will stick with my design, but Keep sending ideas, new thoughts will improve the design and layout
Alan  |
Posted: Tue Nov 04, 2025 10:27 am Post subject: Re: T2 VW bus convert to EV |
I just re-read the previous posts and realized I did not respond to a question airschooled asked. "what do I plan to do with power brakes?"
My 2-proge brake approach is
A) Push harder on the brake pedal. Eliminate the power brakes, do not install a vacuum pump, but leave the brake booster and vacuum line in place in case this is a bad idea. I learned to drive on a '55 ford and know that you can stop with lots of leg on the pedal. Keep It Simple, Stupid.
B) Install a vacuum pump and canister and go with power brakes if A) does not work.
My 36 LiFePo cells are on the way to Canada. CANev is sending me a new approach where the
BMS is enclosed in the battery box. That simplifies wiring because all the cell taps and thermisters are wired at the factory. I am the first real user of this approach, CANev has only showed it at a symposium. Other suppliers have already used this method of common design to simplify the issues of battery box build, especially true with Tesla Lipoly batteries.
I now need to hurry up and finish the interior so it is ready when the kit and batteries arrive.
Yes this is a hobby, and an expensive one at that. I am not trying to save global warming, or save gas cost, or virtue signal to the WOKE crowd. I am just having some fun. |
Posted: Sat Nov 08, 2025 10:20 pm Post subject: Re: T2 VW bus convert to EV |
The next step in preperation for battery installation was repairing all the holes the PO had drilled into the sheet metal floor. There were dozens of small holes from sheet metal screws, plus an assortment of larger holes, from 1/4 inch to 3 inches
The large 3 inch hole was presumably were a pedistal table was installed. When the POs installed the shag carpet floor, they did not bother to seal this large hole, they just layed foam padding and carpet over the hole. This caused some rust damage. There were three 1.5 inch holes behind the driver seat. I guess these were for water lines for a sink. These also had water and rust damage because they were not sealed before shag carpet was installed
I patched the holes by first grinding away the rust on the edges. Then I painted the area with black Rustoleum primer to protect the holes from further rust. The last step was to plug the holes to prevent road water from coming in to attack the new floor.. Rubber plugs were used on the holes from 1/4 inch up to 1.5 inch . Sheet metal holes were plugged with silicon/latex sealant. The l large 3 inch hole was covered with an aluminum plate from the bottom, then caulked around the corragated edges. Extra caulk was added on the 1.5 inch holws because they tended to be oval shaped. The large 3 inch hole can be seen in the middle of the photo.
I would have finished the floor in one day, but I waited for the caulk to dry before laying down a 7/16 in foam padding.
I put padding down because my experience with building a class B van. Plywood directly onto a corragated sheet metal floor would cause squeakes as you drove over bumps. The thin padding would compress when screwing down plywood, and degrade over several years, but still prvent squeaks.
Next steps: install a plywood subfloor then cover the entire floor with linolium.
Alan |
Posted: Sun Nov 09, 2025 10:43 am Post subject: Re: T2 VW bus convert to EV |
i wasn,t suggesting putting the batteries on the roof ,but having the ability to load 200 lbs up there sort of negates the worries of raising the COG by placing batteries inside the bus,200 lb on the roof would be like 400 lbs a foot so above the floor. _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=620186
1974 parts bus
aeromech Samba Member
Joined: January 24, 2006 Posts: 17745 Location: San Diego, California
Posted: Sun Nov 09, 2025 10:50 am Post subject: Re: T2 VW bus convert to EV |
That flooring looks like it would trap water _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Posted: Sun Nov 09, 2025 5:32 pm Post subject: Re: T2 VW bus convert to EV |
Yes it would trap water, but at least the water would be from an internal spill, like a mongo sized orange drink being spilled.
The previous 'shag carpet' floor had numerous floor holes, Including the 3 inch pedistal hole and 3 1.5 inch plumbing holes. None of these were blocked and water sprayed in from underneath. The wood, carpet, foam padding and floor metal all had deteriorated around those areas. The wood was rotted out around the 1.5 inch holes.
The linolium is water proof. I plan to do what is done in motor homes, where spills are inevitable: use latex silicon caulk around the linoleum edges. That stops water from running down the edge and getting soaked up by the floor padding. This scheme has work well in my class B van, and is used in most home built vans.
Alan |
Posted: Sun Nov 09, 2025 5:38 pm Post subject: Re: T2 VW bus convert to EV |
Oh! Now I understand your comment about roof weight. If the the roof can hold 200 lbs. then the bus should not have a CG problem with 400lbs of batteries on the floor. good point.
Alan |
Abscate Samba Member
Joined: October 05, 2014 Posts: 24413 Location: NYC/Upstate/ROW
Posted: Sun Nov 09, 2025 11:27 pm Post subject: Re: T2 VW bus convert to EV |
| lil-jinx wrote: |
| i wasn,t suggesting putting the batteries on the roof ,but having the ability to load 200 lbs up there sort of negates the worries of raising the COG by placing batteries inside the bus,200 lb on the roof would be like 400 lbs a foot so above the floor. |
200 lb on the roof is like 1000 pounds on the floor! _________________ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ π π π |
Posted: Mon Nov 10, 2025 9:54 am Post subject: Re: T2 VW bus convert to EV |
400 lbs in front seats, 600lbs. in rear seats is probably what VW anticipated and you could still put 200 lbs on the roof. The CG would be high and the handling would suffer, but the bus would (supposedly) handle it.
In my design I have 400lbs of battery on the floor, and 2 bucket seats over the batteries. If you had 2x 200lbs passengers you would have 800lbs in the rear and nothing on the roof. That is still totaled to 800lbs. in the rear, but the CG is lower than a roof load.
In my opinion there is not a problem here, especially when you take into account the electric motor is much lighter than internal combustion engine and gas tank, all which are behind the rear suspension. |
Shonandb  Samba Member
Joined: January 12, 2019 Posts: 2264 Location: Vancouver, BC
Posted: Mon Nov 10, 2025 10:08 am Post subject: Re: T2 VW bus convert to EV |
Met a guy yesterday who used a Tesla 3 for his swap into a Spit Bus. He used the 58KW battery pack and built an aluminum carrier that fit nicely underneath between the frame rails. He installed the steering rack and steering column too so the Bus handles very well with the LCG. He also extended the heat and A/C lines and mounted most of the sensors and cameras. Said he gets about 250km -300 km on a full charge and he said that he has converted several Bugs, a Thing, this Bus, and a few Buggies to electric.
I passed him and a few others on the hwy doing 120kms and he accelerated to pull up beside me within a few seconds - scary quick acceleration! _________________ *******************************
Previous 1973 Panel Bus:
Click to view image
Posted: Fri Nov 14, 2025 12:20 pm Post subject: Re: T2 VW bus convert to EV |
I continue to make progress renewing the bus interior. The floor is now complete, and I have started on covering the walls
The new bus floor was a four layer process. First I plugged all the floor holes with caulk, then I laid down a layer of foam padding to stop squeaks. Next came the custom fitted plywood sub-floor, and finally a layer of linoleum. Debra approved the installation, so I was happy as a lobster that didnβt go into the trap.
The photo shows the plywood subfloor. The white areas are caulking to cover the seams and sunken screw heads.
This photo shows the floor completed. I learned to hate vinyl floor adhesive, as it sticks to everything it touches
Next step: cover the walls. I am using thin 0.1inch plywood. The thin wood is flexible to cover the curvature of the bus side and wheel wells. I tried straight walls, and it did not look good, so I went back to curvature.
Alan |
Posted: Mon Nov 24, 2025 12:20 am Post subject: Re: T2 VW bus convert to EV |
The batteries are still on their way from China, so I continue work on the interior. Where I left off was a completed floor.
Thin 0.1 inch plywood was cut to shape and installed on the bus walls. The thin plywood allowed the wood to conform to the rounded bus sides Sheet metal screws attach the wood to the bus sides. The transition from bus side to ceiling is also shown. Note the rear dome light. The first photo below shows the first panels after installation.
The final installation of plywood siding looked like this
Painting the ceiling was next. The first effort was a failure due to me being frugal. I tried to use old paint, thinned with water. Coverage on the dark venier ceiling was piss poor. I decided that using old paint on a $25K project was maybe a mistake
New paint gave better results. Still to work out is the front dome light. I spent 2 days fixing the wiring of the PO. Then I fixed the corroded switches in the door to get the lights to come on when the door opened
After I get the dome light installed I will move onto making and installing door panels, and final painting and touch-up of the interior.
My motto is "Better is the enemy of good enought" |
Posted: Mon Nov 24, 2025 4:15 am Post subject: Re: T2 VW bus convert to EV |
Looking good. Yeah, Iβve travelled the road of trying old paint, usually with bad results. _________________ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ π π π |
Posted: Mon Dec 08, 2025 12:00 am Post subject: Re: T2 VW bus convert to EV |
Sorry for the long delay in posting, There is still no delivery date for the EV conversion parts. To get an exclusion from tariffs the entire order must be shipped together as a 'EV kit'. The batteries are the long pole in the tent.
Thanksgiving and relatives got in the way of my hobby. Last post showed progress on converting the interior from shag carpet to minimulist transport. As a step back, 10 days ago thin wood side panels were ready for paint and the new rear ceiling was complete and painted.
Still to be completed are the door panels: sliding, passenger and driver. I bought the bus without any panels. When I saw the price of original equipment door panels I almost sh*t a brick. I decided that 'minimulist' included painted door panels. This was aided by the fact that I am frugal (some say cheap) so I traded OEM vs my time to make door panels. Cheap won out in the trade. I made templates for the panels from taped-together thick paper by tracing the door outline.
I used the interior 0.1 inch plywood to cut out the panel. Too bad for me, I cut the plywood blank 1 inch too short for the passenger and driver door shape. Yet another trip to home Depot. The photo above shows the problem at the bottom of the door panel. Below is a photo of the plywood passenger and driver panels after cutting them out from a 4x8 sheet. Yes they are mirror images. VW is no fool for production costs.
I used the same method for making a sliding door panel. I did not spend the time to look at how the OEM parts delt with the protuding door latches front and rear. Instead I ask myself "what is easist solution?" So I cut out around the door latch mechanisms Below is a photo of the resultant door panel, painted and ready to install. The light tan color will be used on the rest of the interior.
The door panels are going to be installed using 4mm screws and rivnuts in the door upolster holes. Rivnuts are similar to the plastic wall inserts used to hang pictures, but are rivited unto the door sheet metal. A Rivnut was installed in everyother hole, and on each corner. The revnut insertion tool is shown below.
The passenger door frame is seen below. Look carefully and you can see the 13 rivnut installed into the door. The passenger door panel was then test-fitted into the door. Two 4mm screws at the top hold the panel in place. This locates the panel so the other screw hole can be located and drilled.
That is all the progress this 2 weeks. I think next week will be more productive as I finish panel painting and installation
Stay safe
Alan |
richparker Samba Member
Joined: November 24, 2011 Posts: 7748 Location: Durango, CO
Posted: Mon Dec 08, 2025 4:52 am Post subject: Re: T2 VW bus convert to EV |
Iβm a fan of rivnuts, but itβs gonna be a real pain for the next person to get those out. I usually self tapping screws with finishing washers to attach wood panels.
Smear some clear polyurethane on those panels ant they are gonna look nice. _________________ __________
β71 Westy build
Adventure thread
β65 Deluxe Build
β71 Double Cab |
Posted: Tue Dec 09, 2025 10:07 pm Post subject: Re: T2 VW bus convert to EV |
Good news!! progress is being made at CanEV on the battery boxes and battery shipment. My previous build of an EV classic jeep I built and wired the battery boxes myself. The jeep used 3 battery boxes, one in the gas tank well, one in the back behind the seats, and one under the hood. This crammed boxes into each space but used semi custom boxes. The gas tank battery box was custom sized and built from plywood to fit the limited space between frame rails.
This VW EV conversion is going to use the latest design from CanEV. This is a semi-custom battery box that is pre-wired for both high amperage drive current and BMS cell monitoring. Having the BMS unit inside the water proof box both simplies wiring and protects the BMS ( not water proof) from the elements. This also allows simple cable conections between the battery boxes and the motor controller. The photo below shows the new battery box under fabrication. The white area is foam padding for the batteries, the front portion is for BMS and high current contactors. I expect delivery as a Christmas present.
Good progress is being made on finishing the upgrade to the bus interior. The sliding door panel has been finished, installed and looks good. of course I am not biased just because I did the work myself. The photo below shows the installed sliding door panel. The panel was painted before installation with the light tan paint I picked for contrast with the brown VW sheet metal. The paint choice was slightly influenced by the fact that I had a 1/2 gallon of paint on hand. Still to be done is touch-up the paint over the M4 mounting screws.
The fitting of the passenger and driver door panels is under way. After fitting 2 mounting screws to locate the panels, I used playbough to find the location of the remaining 11 Rivnut locations
This did not go as well as I planned. The playdough stuck to the metal door frame instead of staying on the wood panel. About 5/11 locations were marked, the rest of the playdough were still on the door.
The photo below shows a good playdough location indication. Even with good location marks the screw alignment was not perfect. The slight curvature of the door frame gave some mis location, ususally about 2mm or less.
I tried a film of grease to keep the playdough from sticking to the door. That did not work. Then I went to celephane packing tape and that seemed to work better. Below is a photo of the passenger door panel after test fit and slight modification of the vent hole size.
Still to be completed is the final installation and fitting of the driver door panel, painting of the panels, and final painting of the interior panels to match the sliding door |
