Buggeee  Samba Member
Joined: December 22, 2016 Posts: 5061 Location: Stuck in Ohio
Posted: Thu Nov 13, 2025 7:33 pm Post subject: Buggeee's Boogie Bus 1971 Panel |
I have never seen a Bay panel in real life. When I was a kid I didn't know they existed and my Bays were all window busses. Window busses are not ideal boogie vans, but they are Volkswagens and I could fit my YZ 125 in there, so thats what I did. The cool kid next street over drove a Chevy boogie van with Crager chrome wheels, white letter tires, side pipes and a girl inside. I drove a Bay window bus with a gutted interior and a dirt bike inside. We were both very happy in our respective worlds. But honestly, I was jealous of how cool the privacy of a solid wall van seemed to be.
Its a lifetime later now, and I am working on a splitty panel that, God willing, will be a very cool early bus. But unless you go Jersey look, I dont really get a boogie vibe from a splitty, even a panel splitty. It tickles a different part of the brain altogether. For me, a utilitarian part of the brain.
But a Bay panel, now that has some disco potential. This one had popped up briefly on the FB Marketplace as a running bus for meaningful money a little while back, but I don't like to spend meaningful money on a Volkswagen, it was almost five hours away, and the ad disappeared before the addiction overcame what little good sense I have left.
Then something very inconvenient happened. It popped back up recently as a blown motor roller for cheap. My diseased mind took it as a message from my Maker that He loves me. I stopped at Tractor Supply for some fresh tires for my trailer, and headed out to bring this sloppy girl home.
I decided to take the bunny off the rear window before I rolled her off the trailer, because I have a girlfriend now and she also happens to be my wife, and, well, I don't want this to have a creeper vibe for her at all. Just disco, no creeper.
_________________ Big Time 1988 Vanagon Westy
Dr. Kompressor 72 Super Duper
61 Turkis Pile (adopted out) |
Joined: August 31, 2013 Posts: 13366 Location: North Carolina
Posted: Thu Nov 13, 2025 7:46 pm Post subject: Re: Buggeee's Boogie Bus 1971 Panel |
So jealous. I want an early panel. Especially if it’s a double door. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Shonandb  Samba Member
Joined: January 12, 2019 Posts: 2339 Location: Vancouver, BC
Posted: Thu Nov 13, 2025 7:50 pm Post subject: Re: Buggeee's Boogie Bus 1971 Panel |
Excellent!
Panels are out there.
_________________ *******************************
Previous 1973 Panel Bus:
Click to view image
richparker Samba Member
Joined: November 24, 2011 Posts: 7833 Location: Durango, CO
tolstoy Samba Member
Posted: Thu Nov 20, 2025 9:49 pm Post subject: Re: Buggeee's Boogie Bus 1971 Panel |
Wow, that did a spectacular job of striping off the paint.
Tolstoy _________________ The sun is the same in a relative way, but you're older. Shorter of breath and one day closer to death.
'70 Westy |
TomWesty Samba Member
Joined: November 23, 2007 Posts: 3565 Location: Wyoming,USA
Posted: Sun Nov 23, 2025 5:31 pm Post subject: Re: Buggeee's Boogie Bus 1971 Panel |
That HF strip tool looks to be damn handy. _________________ If you haven't bled on them, you haven't worked on them.
Visit: www.tomcoryell.com and check out my music! |
Posted: Mon Nov 24, 2025 1:48 pm Post subject: Re: Buggeee's Boogie Bus 1971 Panel |
Ya, it really is the cat's meow. and it leaves a nice finish ready for the primer to bite. It's not smooth like the wire cup leaves it, but its not tore up like a grinder does. It's called a metal conditioning tool, and that's what it does. It plows through filler just as easily as a few coats of paint, creating a real dust storm as it leaves clean metal in its wake. The consumable disc I am using is labeled 40 grit, and it tears through the coatings like a 40 grit, but it leaves a finish on the metal like an 80 grit. And, best of all, its a one step process, whereas the chemical striper needs all the secondary clean up. I consumed two discs at $40 each, so $80 to strip the bus. I had spent $50 on the citrus just to do the roof panel with chemical, so its a better deal too. _________________ Big Time 1988 Vanagon Westy
alaskadan Samba Member
Joined: January 09, 2013 Posts: 1973 Location: anchor pt. alaska
Posted: Tue Nov 25, 2025 11:33 am Post subject: Re: Buggeee's Boogie Bus 1971 Panel |
| Awesome, yeah that's pretty quick for stripping a bus that well. I just bought an eastwood sct for other work I'm doing. I look forward to trying it on body work. Did you check to see if you were creating much heat? |
Posted: Wed Nov 26, 2025 8:43 am Post subject: Re: Buggeee's Boogie Bus 1971 Panel |
| alaskadan wrote: |
My hands were gloved but I did check a couple times and heat did not seem to be an issue at all. At times, pressing it would push the flat metal in as I went along and it would pop back out behind as I passed through, and it seemed that was due to my pressing on a large flat sheet area rather than heat. Afterwards, everything is as flat as when I started. I feel like removing the old coatings with the wire cup on the angle grinder makes it warmer than this did. I really did not monitor that issue closely though. _________________ Big Time 1988 Vanagon Westy
