T2 VW bus convert to EV
Page: Previous  1, 2, 3
Clatter
Clatter is offline
PostPosted: Sat Oct 25, 2025 2:57 pm    Post subject: Re: T2 VW bus convert to EV Reply with quote
airschooled wrote:
Yeah fuck people enjoying their hobbies.
Did I do it right? I am enough of an asshole?
Razz Razz Razz Razz
Bus Motor Build
It does not exist!
79 EV VW
79 EV VW is online now
PostPosted: Fri Oct 31, 2025 10:02 pm    Post subject: Re: T2 VW bus convert to EV Reply with quote
Wow! look at all the replies. Back to the EV conversion
The missing 1/2 shaft were ordered from EBay and finally arrived. Below is a photo of the installed 1/2 shafts. This was another adventure in VW bus design and part installation.
I decided to scrap the entire shag rug interior and start over for EV conversion. This was an easy decision given that I am still waiting on China to ship batteries. I am now in the process of re-designing the entire bus interior. The EV battery layout drove the desicion to gut the the van. The batteries will be on the floor in two battey boxes. Above the battery boxes will be 2 bucket seats. One seat and supporting brackets will be removable on the sliding door side to allow transportation of a folding recombent trike. Photos below show the gutted bus and pile of old shag carpeting.
Below is a photo of the battery box and rear bucket seat layout as seen from the sliding door
lil-jinx
lil-jinx is offline
PostPosted: Sat Nov 01, 2025 6:08 am    Post subject: Re: T2 VW bus convert to EV Reply with quote
just doing some reading on roof racks and the load limits,vw say 220 lbs on the rack suppprted by the gutters,so according to that you could put half of your batteries on the roof,lol no worries about cog ,biggest concern is the fore and aft placement of the weight.
1968 Dune Buggy sold dec 2024
1974 parts bus
79 EV VW
PostPosted: Sat Nov 01, 2025 8:20 am    Post subject: Re: T2 VW bus convert to EV Reply with quote
That is an interesting Idea to put batteries on the roof. I can think of a couple of problems with implementing this design. It could work, but the problems may not be worth the internal space that was saved.
The big problem, of course, is where I would mount my surf board?
The center of gravity would be quite high.
There are a lot of cables that have to be routed, including 2-Ought high voltage welding cable, thermister cables, and battery monitoring lines to each battery cell. On the floor this is easy: under the bus. On the roof will require holes in the roof, or run them outside the bus, Frankenstein style.
The gutter rails on my bus are about 50% rusted out. I plan to repair them with grinding and bondo. I dont think bondo will hold 200lbs.
I will stick with my design, but Keep sending ideas, new thoughts will improve the design and layout
Alan Idea
79 EV VW
PostPosted: Tue Nov 04, 2025 10:27 am    Post subject: Re: T2 VW bus convert to EV Reply with quote
I just re-read the previous posts and realized I did not respond to a question airschooled asked. "what do I plan to do with power brakes?"
My 2-proge brake approach is
A) Push harder on the brake pedal. Eliminate the power brakes, do not install a vacuum pump, but leave the brake booster and vacuum line in place in case this is a bad idea. I learned to drive on a '55 ford and know that you can stop with lots of leg on the pedal. Keep It Simple, Stupid.
B) Install a vacuum pump and canister and go with power brakes if A) does not work.
My 36 LiFePo cells are on the way to Canada. CANev is sending me a new approach where the
BMS is enclosed in the battery box. That simplifies wiring because all the cell taps and thermisters are wired at the factory. I am the first real user of this approach, CANev has only showed it at a symposium. Other suppliers have already used this method of common design to simplify the issues of battery box build, especially true with Tesla Lipoly batteries.
I now need to hurry up and finish the interior so it is ready when the kit and batteries arrive.
Yes this is a hobby, and an expensive one at that. I am not trying to save global warming, or save gas cost, or virtue signal to the WOKE crowd. I am just having some fun.
79 EV VW
PostPosted: Sat Nov 08, 2025 10:20 pm    Post subject: Re: T2 VW bus convert to EV Reply with quote
The next step in preperation for battery installation was repairing all the holes the PO had drilled into the sheet metal floor. There were dozens of small holes from sheet metal screws, plus an assortment of larger holes, from 1/4 inch to 3 inches
The large 3 inch hole was presumably were a pedistal table was installed. When the POs installed the shag carpet floor, they did not bother to seal this large hole, they just layed foam padding and carpet over the hole. This caused some rust damage. There were three 1.5 inch holes behind the driver seat. I guess these were for water lines for a sink. These also had water and rust damage because they were not sealed before shag carpet was installed
I patched the holes by first grinding away the rust on the edges. Then I painted the area with black Rustoleum primer to protect the holes from further rust. The last step was to plug the holes to prevent road water from coming in to attack the new floor.. Rubber plugs were used on the holes from 1/4 inch up to 1.5 inch . Sheet metal holes were plugged with silicon/latex sealant. The l large 3 inch hole was covered with an aluminum plate from the bottom, then caulked around the corragated edges. Extra caulk was added on the 1.5 inch holws because they tended to be oval shaped. The large 3 inch hole can be seen in the middle of the photo.
I would have finished the floor in one day, but I waited for the caulk to dry before laying down a 7/16 in foam padding.
I put padding down because my experience with building a class B van. Plywood directly onto a corragated sheet metal floor would cause squeakes as you drove over bumps. The thin padding would compress when screwing down plywood, and degrade over several years, but still prvent squeaks.
Next steps: install a plywood subfloor then cover the entire floor with linolium.
Alan
lil-jinx
lil-jinx is offline
PostPosted: Sun Nov 09, 2025 10:43 am    Post subject: Re: T2 VW bus convert to EV Reply with quote
i wasn,t suggesting putting the batteries on the roof ,but having the ability to load 200 lbs up there sort of negates the worries of raising the COG by placing batteries inside the bus,200 lb on the roof would be like 400 lbs a foot so above the floor.
1974 parts bus
aeromech
aeromech is offline
PostPosted: Sun Nov 09, 2025 10:50 am    Post subject: Re: T2 VW bus convert to EV Reply with quote
That flooring looks like it would trap water
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
79 EV VW
PostPosted: Sun Nov 09, 2025 5:32 pm    Post subject: Re: T2 VW bus convert to EV Reply with quote
Yes it would trap water, but at least the water would be from an internal spill, like a mongo sized orange drink being spilled.
The previous 'shag carpet' floor had numerous floor holes, Including the 3 inch pedistal hole and 3 1.5 inch plumbing holes. None of these were blocked and water sprayed in from underneath. The wood, carpet, foam padding and floor metal all had deteriorated around those areas. The wood was rotted out around the 1.5 inch holes.
The linolium is water proof. I plan to do what is done in motor homes, where spills are inevitable: use latex silicon caulk around the linoleum edges. That stops water from running down the edge and getting soaked up by the floor padding. This scheme has work well in my class B van, and is used in most home built vans.
Alan
79 EV VW
PostPosted: Sun Nov 09, 2025 5:38 pm    Post subject: Re: T2 VW bus convert to EV Reply with quote
Oh! Now I understand your comment about roof weight. If the the roof can hold 200 lbs. then the bus should not have a CG problem with 400lbs of batteries on the floor. good point.
Alan
Abscate
Abscate is offline
PostPosted: Sun Nov 09, 2025 11:27 pm    Post subject: Re: T2 VW bus convert to EV Reply with quote
200 lb on the roof is like 1000 pounds on the floor!
lil-jinx
lil-jinx is offline
PostPosted: Mon Nov 10, 2025 9:36 am    Post subject: Re: T2 VW bus convert to EV Reply with quote
where does the cog fall when there is 400 lb of humans in the front seats,and another 600 lbs in the rear seats,
1974 parts bus
79 EV VW
PostPosted: Mon Nov 10, 2025 9:54 am    Post subject: Re: T2 VW bus convert to EV Reply with quote
400 lbs in front seats, 600lbs. in rear seats is probably what VW anticipated and you could still put 200 lbs on the roof. The CG would be high and the handling would suffer, but the bus would (supposedly) handle it.
In my design I have 400lbs of battery on the floor, and 2 bucket seats over the batteries. If you had 2x 200lbs passengers you would have 800lbs in the rear and nothing on the roof. That is still totaled to 800lbs. in the rear, but the CG is lower than a roof load.
In my opinion there is not a problem here, especially when you take into account the electric motor is much lighter than internal combustion engine and gas tank, all which are behind the rear suspension.
Shonandb Premium Member
Shonandb is offline
PostPosted: Mon Nov 10, 2025 10:08 am    Post subject: Re: T2 VW bus convert to EV Reply with quote
Met a guy yesterday who used a Tesla 3 for his swap into a Spit Bus. He used the 58KW battery pack and built an aluminum carrier that fit nicely underneath between the frame rails. He installed the steering rack and steering column too so the Bus handles very well with the LCG. He also extended the heat and A/C lines and mounted most of the sensors and cameras. Said he gets about 250km -300 km on a full charge and he said that he has converted several Bugs, a Thing, this Bus, and a few Buggies to electric.
I passed him and a few others on the hwy doing 120kms and he accelerated to pull up beside me within a few seconds - scary quick acceleration!
Previous 1973 Panel Bus:
Click to view image
79 EV VW
PostPosted: Fri Nov 14, 2025 12:20 pm    Post subject: Re: T2 VW bus convert to EV Reply with quote
I continue to make progress renewing the bus interior. The floor is now complete, and I have started on covering the walls
The new bus floor was a four layer process. First I plugged all the floor holes with caulk, then I laid down a layer of foam padding to stop squeaks. Next came the custom fitted plywood sub-floor, and finally a layer of linoleum. Debra approved the installation, so I was happy as a lobster that didn’t go into the trap.
The photo shows the plywood subfloor. The white areas are caulking to cover the seams and sunken screw heads.
This photo shows the floor completed. I learned to hate vinyl floor adhesive, as it sticks to everything it touches
Next step: cover the walls. I am using thin 0.1inch plywood. The thin wood is flexible to cover the curvature of the bus side and wheel wells. I tried straight walls, and it did not look good, so I went back to curvature.
Alan
79 EV VW
PostPosted: Mon Nov 24, 2025 12:20 am    Post subject: Re: T2 VW bus convert to EV Reply with quote
The batteries are still on their way from China, so I continue work on the interior. Where I left off was a completed floor.
Thin 0.1 inch plywood was cut to shape and installed on the bus walls. The thin plywood allowed the wood to conform to the rounded bus sides Sheet metal screws attach the wood to the bus sides. The transition from bus side to ceiling is also shown. Note the rear dome light. The first photo below shows the first panels after installation.
The final installation of plywood siding looked like this
Painting the ceiling was next. The first effort was a failure due to me being frugal. I tried to use old paint, thinned with water. Coverage on the dark venier ceiling was piss poor. I decided that using old paint on a $25K project was maybe a mistake
New paint gave better results. Still to work out is the front dome light. I spent 2 days fixing the wiring of the PO. Then I fixed the corroded switches in the door to get the lights to come on when the door opened
After I get the dome light installed I will move onto making and installing door panels, and final painting and touch-up of the interior.
My motto is "Better is the enemy of good enought"
Abscate
Abscate is offline
PostPosted: Mon Nov 24, 2025 4:15 am    Post subject: Re: T2 VW bus convert to EV Reply with quote
Looking good. Yeah, I’ve travelled the road of trying old paint, usually with bad results.
79 EV VW
PostPosted: Yesterday 12:00 am    Post subject: Re: T2 VW bus convert to EV Reply with quote
Sorry for the long delay in posting, There is still no delivery date for the EV conversion parts. To get an exclusion from tariffs the entire order must be shipped together as a 'EV kit'. The batteries are the long pole in the tent.
Thanksgiving and relatives got in the way of my hobby. Last post showed progress on converting the interior from shag carpet to minimulist transport. As a step back, 10 days ago thin wood side panels were ready for paint and the new rear ceiling was complete and painted.
Still to be completed are the door panels: sliding, passenger and driver. I bought the bus without any panels. When I saw the price of original equipment door panels I almost sh*t a brick. I decided that 'minimulist' included painted door panels. This was aided by the fact that I am frugal (some say cheap) so I traded OEM vs my time to make door panels. Cheap won out in the trade. I made templates for the panels from taped-together thick paper by tracing the door outline.
I used the interior 0.1 inch plywood to cut out the panel. Too bad for me, I cut the plywood blank 1 inch too short for the passenger and driver door shape. Yet another trip to home Depot. The photo above shows the problem at the bottom of the door panel. Below is a photo of the plywood passenger and driver panels after cutting them out from a 4x8 sheet. Yes they are mirror images. VW is no fool for production costs.
I used the same method for making a sliding door panel. I did not spend the time to look at how the OEM parts delt with the protuding door latches front and rear. Instead I ask myself "what is easist solution?" So I cut out around the door latch mechanisms Below is a photo of the resultant door panel, painted and ready to install. The light tan color will be used on the rest of the interior.
The door panels are going to be installed using 4mm screws and rivnuts in the door upolster holes. Rivnuts are similar to the plastic wall inserts used to hang pictures, but are rivited unto the door sheet metal. A Rivnut was installed in everyother hole, and on each corner. The revnut insertion tool is shown below.
The passenger door frame is seen below. Look carefully and you can see the 13 rivnut installed into the door. The passenger door panel was then test-fitted into the door. Two 4mm screws at the top hold the panel in place. This locates the panel so the other screw hole can be located and drilled.
That is all the progress this 2 weeks. I think next week will be more productive as I finish panel painting and installation
Stay safe
Alan
richparker
richparker is offline
PostPosted: Yesterday 4:52 am    Post subject: Re: T2 VW bus convert to EV Reply with quote
I’m a fan of rivnuts, but it’s gonna be a real pain for the next person to get those out. I usually self tapping screws with finishing washers to attach wood panels.
Smear some clear polyurethane on those panels ant they are gonna look nice.
__________
’71 Westy build
Adventure thread
’65 Deluxe Build
’71 Double Cab
Page 3 of 3
