Swing axle to IRS conversion
tiertender
tiertender is offline
PostPosted: Tue Dec 27, 2005 5:43 pm    Post subject: Swing axle to IRS conversion Reply with quote
Here is my conversion from swing axle to IRS using the CB Performance weld on brackets. The easiest way that I found without the need to weld in hangers on the body. You use your same swing axle with the transmission support already in place all you will need is to purchase the IRS components.
http://www.cbperformance.com/catalog.asp?ProductID=1499
You will need to trim some metal for the brackets to fit.
the bracket tack welded in place.
This is the finished product.
surftypeman
surftypeman is offline
PostPosted: Wed Dec 28, 2005 7:23 am    Post subject: cool Reply with quote
your work looks good-
how did you assure that the angle of the brackets welded were accurate?
did you have a template for removing material from the trailing arm?
also, are you using a bentley or other manual for assembling the parts?
tiertender
PostPosted: Wed Dec 28, 2005 3:19 pm    Post subject: Re: cool Reply with quote
The brackets already come cut at the proper angle. I did not have a template that shows how much metal to cut. I had to cut a little at a time, until the the bracket would clear. After the bracket would clear, I assembled the trailing arm to the spring plate with the bracket attached. I aligned the wheels then tacked the brackets in place. I then disassembled everything and welded the brackets in place. Then I welded any openings shut to avoid water from settling in the assembly. I use a bentley which everyone swears by, however I sometimes find it incomplete or vague at times.
DMNCLNR
Sir Camp'alot
DMNCLNR is offline
PostPosted: Wed Dec 28, 2005 3:24 pm    Post subject: Reply with quote
Nice work, but why would anyone do such a thing?
To his their own PBJ
Pl@y@ #1
tiertender
PostPosted: Wed Dec 28, 2005 3:28 pm    Post subject: Reply with quote
This allows you to have an IRS suspension without the need to figure out where to weld in rear engine hangers. By doing it this way you have the engine hanger mounted already you simply use your own swing axle but weld on the brackets. I tried it both ways, much easier this way + I don't have a hanging bracket at the back of my engine. Razz
DMNCLNR
Sir Camp'alot
DMNCLNR is offline
PostPosted: Wed Dec 28, 2005 3:30 pm    Post subject: Reply with quote
I know, looks like you did an excellent job, im just not a fan of IRS so i was givin you some crap
Pl@y@ #1
tiertender
PostPosted: Wed Dec 28, 2005 3:36 pm    Post subject: Reply with quote
Purist - point taken
I feel the same way about classic Broncos. I feel your pain, however I prefer a better ride rather than keeping it 100% original.
One other note this is a commonly asked question and I thought I would show one of the alternatives since there are many and I find this one to be easiest for the novice.
Notched
Notched is offline
PostPosted: Wed Dec 28, 2005 3:49 pm    Post subject: Reply with quote
I can think of two reasons: No camber problem and easier to switch out transaxles. Maybe three, better suspension...
Nice work!! I'd like to try that someday!
Oh, the purists have such weak stomachs... Laughing
Take a tums!!
Phillip Bradfield
Current stock: '57 Panel Bus, '63 Rat Notch, '64 Baja, '66 Variant, '67 Convertible Ghia, '68 Squareback, '69 Squareback, '69 Fastback
Southern Oregon VW Club -- http://www.sovw.org
Oregon VW Forum -- http://www.oregonvw.org
73notch
73notch is offline
PostPosted: Mon Jan 02, 2006 1:40 pm    Post subject: Reply with quote
i had to do it too Cool
SubyNotch.com is back up!
moose130
moose130 is offline
PostPosted: Tue Jan 03, 2006 3:33 am    Post subject: Reply with quote
I did the same conversion on a T1 using T3 parts.
Only difference is I made a jig to hold the brackets in the right spot.
Probably do the same again when i get my '65 rhd Notch (Porsche suspension and brakes on that one!)
bobskulll
bobskulll is offline
PostPosted: Tue Jan 03, 2006 10:05 am    Post subject: Reply with quote
I'm in the process of doing this too. I got the irs tranny mount in straight, but now I have to pull my subframe and do the tricky part of getting everything aligned before I weld the arms in place. Looks good! What are your plans for the mount?
ddb member #9
GjMan
GjMan is offline
PostPosted: Tue Jan 03, 2006 10:09 am    Post subject: Reply with quote
All you purists, relax. You can always return the car to its original configuration by removing that awful, bastardized IRS subframe and installing a SA subframe. No harm done. And when you do it this way, you don't have to alter the car body by welding in the IRS rear engine mounts.
I once did this conversion, but I did not cut metal out of the frame horns to make the IRS brackets clear. Rather, I kept heating the horn metal with a torch and carefully pounding it in with a large-face hammer until I had enough room. No holes to weld up afterward.
jimmybo1313
jimmybo1313 is offline
PostPosted: Mon Aug 25, 2008 12:20 pm    Post subject: Reply with quote
What IRS components did you have to purchase? Do the IRS spring plates bolt right up to the swing axle sub-frame? Are the torsion bars interchangable on the swing axle and IRS? (Can you use either one or is there a difference and what would it be?) How did you aline the rear wheels? Thanks
Bobnotch
Bobnotch is offline
PostPosted: Mon Aug 25, 2008 2:58 pm    Post subject: Reply with quote
Maybe so, but if you weld the body mounts in, then you can use AT sometime down the road. With it set up on the subframe, you can't. Just my take on it.
That being said, it looks good. Very Happy
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
ozinbc
ozinbc is offline
PostPosted: Mon Aug 25, 2008 7:05 pm    Post subject: IRS - frame horns/drive shaft clearance Reply with quote
Good to see - will be doing the same but have heard you need to pound the frame horns a little for the drive shafts to clear? have you fitted the gearbox/drive shafts as a trial?
regards, Steve
the invisible and the non existent look very much alike
9mmPKR
9mmPKR is offline
PostPosted: Mon Sep 17, 2012 12:11 pm    Post subject: Reply with quote
Does everything mount/fit properly with this IRS Swap?
Please update this post.. BTT please.
Max Welton
Max Welton is offline
PostPosted: Mon Sep 17, 2012 12:35 pm    Post subject: Reply with quote
Not to put the flyswatter to Tinker-Bell, but those horns look seriously weekened by the cut out sections.
Max
1967 Type-3 Fastback
Brent
Brent is offline
PostPosted: Tue Sep 18, 2012 2:21 am    Post subject: Reply with quote
Max
I did mine like that too, but welded in a plate behind the bracket. A little heavy on the welding, but it all turned out fine.
http://www.thesamba.com/vw/forum/viewtopic.php?t=4...p;start=20
69 Fastback Build
Berg5 Build
vlad01
vlad01 is offline
PostPosted: Tue Sep 18, 2012 2:34 am    Post subject: Reply with quote
this modification coupled with kafer bars is ultimately the strongest setup you can get on a type 3. either stock setups by them selves are piss weak.
vlad01
vlad01 is offline
PostPosted: Tue Sep 18, 2012 2:40 am    Post subject: Reply with quote
Max
thats why;
a. use irs pivots of an irs sub frame and weld all the way around, just like factory setup on a irs bug.
b. weld in addition plates and weld all the way around like Brent did.
c + a or b. add kafer bars and go nuts on turbo t4 or suby to your hearts desire.
