Cleaning gas tank
paule
paule is offline
PostPosted: Thu Feb 02, 2006 10:34 pm    Post subject: Cleaning gas tank Reply with quote
what is the best way to recondition a gas tank?
there is rusty sediment in mine and i would like to clean it out and put a new fuel sender in.. im sick of running out of gas and changing fuel filters.
any suggestions or are there businesses that do this sort of thing?
thx
p
krusher
krusher is offline
PostPosted: Thu Feb 02, 2006 10:48 pm    Post subject: Reply with quote
This is what I used.
http://www.prp-porstore.com/page/por15/PROD/TankSealers/FTRK
Very Happy
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Fri Feb 03, 2006 4:15 am    Post subject: Reply with quote
Here's how I did the tank in my Beetle.
http://www.glenn-ring.com/tech/gas_tank_resto.htm
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
bbugman74
bbugman74 is offline
PostPosted: Fri Feb 03, 2006 8:25 am    Post subject: Reply with quote
empty the tank totally. Gather up a bunch of nuts and bolts, small lengths of chain, or even clean rocks. Drop them in the tank with all the "holes" plugged pour in the tank cleaner of your choice and shake the hell out of it. The small objects you dropped in the tank will act as an abrasive to help loosen all the gum, and junk stuck to the inside of the tank. repeat until clean. Then use a good quality tank sealer on it and you should be golden Cool
65 Notch (project)
74 Standard Beetle
01 Jetta VR6
"That beer I had for breakfast, wasn't bad, so I had one more... for dessert"-Johnny Cash
Russ Wolfe
Russ Wolfe is offline
PostPosted: Fri Feb 03, 2006 6:16 pm    Post subject: Reply with quote
Don't use tank sealers on T-3 tanks. They have some very fine orfices that might get plugged. There is a "well" in the bottom that is to keep the engine from starving on corners, with a close to empty tank.
http://classicvw.org/gallery/main.php?g2_view=core.ShowItem&g2_itemId=288
Just clean it and then leave it, of treat it with some anti-rust treatment.
Gary: OK. Ima poop.
Bobnotch
Bobnotch is offline
PostPosted: Fri Feb 03, 2006 7:34 pm    Post subject: Reply with quote
Russ, in the big blue Bentley, they mention using a "derusting phosphate agent Antax Extra M" mixed 1:10 with water to remove rust. Where would you find that? I know where to get some soluble oil. But the other stuff, I'm lost. Shocked
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
Russ Wolfe
PostPosted: Fri Feb 03, 2006 7:44 pm    Post subject: Reply with quote
I am not a chemist, but I am thinking something like Muratic acid woould work.
Gary: OK. Ima poop.
Esteddom
Esteddom is offline
PostPosted: Sun Aug 26, 2012 2:58 pm    Post subject: Reply with quote
This might be a dumb question but what did you guys use to plug the tank holes with before you filled with acid? I've got the tank off and don't see much rust but have a lot off tar like substance. Car has been sitting since 81 so it's to be expected. Any help would be greatly appreciated!
Esteddom
Esteddom is offline
PostPosted: Sun Aug 26, 2012 3:41 pm    Post subject: Reply with quote
Also do you remove the sending unit? Ni pulled it and it's got tar lie substance all over it too. Leave it for at acid bath or remove and clean up outside the tank?
Bobnotch
Bobnotch is offline
PostPosted: Sun Aug 26, 2012 7:36 pm    Post subject: Reply with quote
Pull it, as there's some small fine wires inside. Yonce out, you can take the "can" off, and clean the sludge out of it. Just be careful of the wires (ask neena), as you can break them easily. IF you break the wires, the sending unit is broken. Jim Adney ([email protected]) rebuilds them for 30 bucks.
Tram wrote:
Tram wrote:
chaosisme
chaosisme is offline
PostPosted: Sun Aug 26, 2012 11:37 pm    Post subject: Reply with quote
What about a cork?
'65 1500 S [quareback]
'68 FI Sunroof Squareback
'70 Westy
OCT3 - Orange County Type 3's
Brent
Brent is offline
PostPosted: Mon Aug 27, 2012 12:55 am    Post subject: Reply with quote
Gorilla Tape worked for me.
69 Fastback Build
Berg5 Build
vlad01
vlad01 is offline
PostPosted: Mon Aug 27, 2012 4:58 am    Post subject: Reply with quote
Hot water with sodium hydroxide Cool it will clean all the gum and deposited out but wont touch rust. but luckily I haven't had to deal with rust in most of my tanks so far.
sub-hatchtim
sub-hatchtim is offline
PostPosted: Mon Aug 27, 2012 10:33 pm    Post subject: Reply with quote
muriatic acid works very well but I would advise you to take it to a radiator shop they will get it 100% clean and sometimes all that sludge and crap is blocking tiny rust holes
I just had my bus tank done it cost me 80 bucks
58' pg/sg silo fridge westy
58 Dove blue singlecab
76 911S
micahmonster
micahmonster is offline
PostPosted: Tue Oct 11, 2016 6:37 pm    Post subject: Re: Cleaning gas tank Reply with quote
Thought I would share some nightmarish shots of how my tank cleaning is going:
The collapsed and suction-melded to the input tube brass sock/screen:
The chunky layer of rust that happened on some previously unknown tank sealing. Assuming that either the rust wasn't first removed, or the sealant started to separate and rust set in behind it:
71 Ghia - First car
72 Ghia
71 Square
68 Square
74 T4 Square
73 Ghia
And now I've got that 68 Squareback.. back!
I may have a habit.
KTPhil Premium Member
KTPhil is offline
PostPosted: Tue Oct 11, 2016 8:09 pm    Post subject: Re: Cleaning gas tank Reply with quote
Shocked Shocked Shocked Shocked Shocked
micahmonster
PostPosted: Thu Oct 13, 2016 8:59 pm    Post subject: Re: Cleaning gas tank Reply with quote
That tank actually cleaned up fairly well, considering. Took some 5 hours of work to get all the loose old coating out of it, but the acid cleaned the rust out nicely. I put in a new screen, gasket, and did some fun hose routing (that is for another post regarding fuel pumps) Now the gas flows clean and freely, no more cavitation, Happy car. Smile
71 Ghia - First car
72 Ghia
71 Square
68 Square
74 T4 Square
73 Ghia
I may have a habit.
