1954 & 1955 engines whats not correct!
Page: 1, 2, 3 ... 31, 32, 33  Next
vdubinit
vdubinit is offline
PostPosted: Fri Jun 23, 2006 6:31 pm    Post subject: 1954 & 1955 engines whats not correct! Reply with quote
I tought I would start a thread discussing the the correctness of 1954 and 1955 engines please be specific as possible thanks
Nice summary of a lot of parts from another member:
laneven28 wrote:
Correct BR3T distributor for a February car
3-hole Engine tin - breastplate, cylinder tin & heater boxes. Note the cylinder tin also has side caps that are welded on - they were stamped in on later versions (not sure when exactly)
54 heater boxes are similar to split window (also 3 hole), but are missing the flap for the X plate. You can see the difference here - split on the left, 54 on the right
Correct coil should be a Bosch TE6A3 - note the small date stamp just above the coil # - 4L (April '55)
Correct Bosch generator & regulator, note date code on each 3K (March 54)
Correct weld nuts on fan shroud (inside at bottom of both ends), throttle ring (pictured), backside of wire tube clamps, and bottom side of cylinder tin
**WANTED** ONE 4 1/2 EARLY FUCH
steven wood
steven wood is offline
PostPosted: Fri Jun 23, 2006 7:07 pm    Post subject: Reply with quote
what engine?
vdubinit
vdubinit is offline
PostPosted: Fri Jun 23, 2006 7:13 pm    Post subject: Reply with quote
steven wood wrote:
what engine?
Embarassed OOPS I MEANT THIS ONE Embarassed
http://www.thesamba.com/vw/classifieds/detail.php?id=319515
steven wood
PostPosted: Fri Jun 23, 2006 7:17 pm    Post subject: Reply with quote
Well it has the single strap air cleaner and the round top regulator. I believe that both of these were used in '54 and '55. Have you talked to Todd about shipping it?
RareAir
RareAir is offline
PostPosted: Fri Jun 23, 2006 7:24 pm    Post subject: Reply with quote
Lower crank pulley & fuel pump are 1956-later style. The crank pulley should have no rolled lip on the outside edge. The fuel pump should have a domed top, not a removeable Brass fitting as shown.
1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241
vdubinit
vdubinit is offline
PostPosted: Fri Jun 23, 2006 7:35 pm    Post subject: Reply with quote
WHAT ABOUT THE TIN WARE LIKE THE SHROUD AND ESPECIALLY THE GENERATOR
SO FAR THANKS STEVEN AND GLENN FOR THE REPLY
RareAir
RareAir is offline
PostPosted: Fri Jun 23, 2006 7:48 pm    Post subject: Reply with quote
Generator & fan shroud look correct. The fan housing (1953-55) should NOT have a square dimple behind the aircleaner, and I don't see one on that particular motor.
The generator should be a thin slot generator. In the pics, the generator has the louvered cover so it's not visible.
1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241
53 0val
Samba Professor
53 0val is offline
PostPosted: Fri Jun 23, 2006 10:13 pm    Post subject: Reply with quote
Carburetor stand should have a rounded edge and not two flat sides.
vdubinit
vdubinit is offline
PostPosted: Fri Jun 23, 2006 11:22 pm    Post subject: Reply with quote
so is the intake manifold wrong also ???
53 0val
Samba Professor
53 0val is offline
PostPosted: Sat Jun 24, 2006 7:19 am    Post subject: Reply with quote
The "stand" I'm referring to is the little piece of metal that supports the carb from the front. Not the whole manifold. Confused
Rich's 50
Rich's 50 is offline
PostPosted: Sat Jun 24, 2006 8:20 am    Post subject: Reply with quote
God damn Glen and Bob Shocked You guys really do know some shit about this little cars......Good job guys Very Happy
vdubinit
vdubinit is offline
PostPosted: Sat Jun 24, 2006 9:48 am    Post subject: Reply with quote
these two guys are aces at this stuff thanks both of you for the help i think its time to call forward air and set up a delivery time
thanks for the help Very Happy
vdubinit
vdubinit is offline
PostPosted: Sat Jun 24, 2006 9:50 am    Post subject: Reply with quote
yes i have for a few days now just haven't recieved any emails back from him in the past day or so Question
i want it for sure
PostPosted: Sat Jun 24, 2006 9:52 am    Post subject: Reply with quote
The 54-55 fuel pump has a wavy top.
Sort of a poor photo:
PostPosted: Sat Jun 24, 2006 9:53 am    Post subject: Reply with quote
I think it should have the thin outer upper generator pulley too.
And of course the fuel line from the fuel pump to the carburetor is totally messed up.
vdubinit
vdubinit is offline
PostPosted: Sat Jun 24, 2006 3:24 pm    Post subject: Reply with quote
i was just wondering is this engine even a 1954 engine or is it a early 55 engine
from the samba vins oval info thread
i got these numbers for decenber of 1954 meaning the last few 1954 engines ended with 945 526 and only 6 total numbers
now the engine in the ad with serial number 1-0921258 wouldn't it be a may of 1955 engine and not a ""1954"" engine
this is just info i collected from the samba http://www.thesamba.com/vw/archives/info/bugchassisdating.php
correct me if Im wrong I just don't want to spend the money if its not right for mt 54 vert thanks guys
RareAir
RareAir is offline
PostPosted: Sat Jun 24, 2006 4:16 pm    Post subject: Reply with quote
1-0921258 is a Dec 1954. 1-0921247 through 1-0945526 were all made in Dec of 1954
1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241
vdubinit
vdubinit is offline
PostPosted: Sat Jun 24, 2006 4:19 pm    Post subject: Reply with quote
Thanks for correcting me
oldoval
oldoval is offline
PostPosted: Fri Jul 07, 2006 9:49 am    Post subject: Reply with quote
Just a little question, The add says that the engine for sale LOOKS like this one. The photos are not of the one for sale. Get some of the one for sale before you buy it, It may be even more incorrect. Just my 2 cents OLDOVAL
1957 Oval Rag
steven wood
PostPosted: Fri Jul 07, 2006 5:24 pm    Post subject: Reply with quote
The pics that are on Todd's ad is of the '54 engine. The engine that is for sale now is a '55. He's using the '54 pics to sell the '55 engine.
Page 1 of 33
