vdubinit Samba Member
Joined: July 11, 2005 Posts: 1870 Location: central coast
Posted: Fri Jun 23, 2006 6:31 pm Post subject: 1954 & 1955 engines whats not correct! |
I tought I would start a thread discussing the the correctness of 1954 and 1955 engines please be specific as possible thanks
Nice summary of a lot of parts from another member:
| laneven28 wrote: |
Correct BR3T distributor for a February car
3-hole Engine tin - breastplate, cylinder tin & heater boxes. Note the cylinder tin also has side caps that are welded on - they were stamped in on later versions (not sure when exactly)
54 heater boxes are similar to split window (also 3 hole), but are missing the flap for the X plate. You can see the difference here - split on the left, 54 on the right
Correct coil should be a Bosch TE6A3 - note the small date stamp just above the coil # - 4L (April '55)
Correct Bosch generator & regulator, note date code on each 3K (March 54)
Correct weld nuts on fan shroud (inside at bottom of both ends), throttle ring (pictured), backside of wire tube clamps, and bottom side of cylinder tin
_________________ **WANTED** ONE 4 1/2 EARLY FUCH
steven wood Samba Member
Joined: March 14, 2004 Posts: 1647 Location: Virginia, NOT West Virginia!
Posted: Fri Jun 23, 2006 7:07 pm Post subject: |
| what engine? |
Posted: Fri Jun 23, 2006 7:17 pm Post subject: |
| Well it has the single strap air cleaner and the round top regulator. I believe that both of these were used in '54 and '55. Have you talked to Todd about shipping it? |
RareAir Samba Member
Joined: May 11, 2002 Posts: 14577 Location: 18 miles North of the border
Posted: Fri Jun 23, 2006 7:24 pm Post subject: |
Lower crank pulley & fuel pump are 1956-later style. The crank pulley should have no rolled lip on the outside edge. The fuel pump should have a domed top, not a removeable Brass fitting as shown. _________________ 1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241 |
Posted: Fri Jun 23, 2006 7:35 pm Post subject: |
WHAT ABOUT THE TIN WARE LIKE THE SHROUD AND ESPECIALLY THE GENERATOR
SO FAR THANKS STEVEN AND GLENN FOR THE REPLY _________________ **WANTED** ONE 4 1/2 EARLY FUCH |
Posted: Fri Jun 23, 2006 7:48 pm Post subject: |
| vdubinit wrote: |
| WHAT ABOUT THE TIN WARE LIKE THE SHROUD AND ESPECIALLY THE GENERATOR |
Generator & fan shroud look correct. The fan housing (1953-55) should NOT have a square dimple behind the aircleaner, and I don't see one on that particular motor.
The generator should be a thin slot generator. In the pics, the generator has the louvered cover so it's not visible. _________________ 1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241 |
53 0val Samba Professor
Joined: July 03, 2003 Posts: 11396 Location: Irvine, CA
Posted: Fri Jun 23, 2006 10:13 pm Post subject: |
Carburetor stand should have a rounded edge and not two flat sides. _________________ "What a fool believes he sees, no wise man has the power to reason away." Dobee, Dobee, Do |
Posted: Fri Jun 23, 2006 11:22 pm Post subject: |
| 53 0val wrote: |
| Carburetor stand should have a rounded edge and not two flat sides. |
so is the intake manifold wrong also ??? _________________ **WANTED** ONE 4 1/2 EARLY FUCH |
Posted: Sat Jun 24, 2006 7:19 am Post subject: |
| vdubinit wrote: |
| 53 0val wrote: |
so is the intake manifold wrong also ??? |
The "stand" I'm referring to is the little piece of metal that supports the carb from the front. Not the whole manifold.  _________________ "What a fool believes he sees, no wise man has the power to reason away." Dobee, Dobee, Do |
Rich's 50 Samba Member
Joined: February 18, 2004 Posts: 10794 Location: San Diego, CA
Posted: Sat Jun 24, 2006 8:20 am Post subject: |
God damn Glen and Bob You guys really do know some shit about this little cars......Good job guys  |
Posted: Sat Jun 24, 2006 9:48 am Post subject: |
| Rich's 50 wrote: |
these two guys are aces at this stuff thanks both of you for the help i think its time to call forward air and set up a delivery time
thanks for the help  _________________ **WANTED** ONE 4 1/2 EARLY FUCH |
Posted: Sat Jun 24, 2006 9:50 am Post subject: |
| steven wood wrote: |
yes i have for a few days now just haven't recieved any emails back from him in the past day or so
i want it for sure _________________ **WANTED** ONE 4 1/2 EARLY FUCH |
EverettB  Administrator
Joined: April 11, 2000 Posts: 71865 Location: Phoenix 602
Posted: Sat Jun 24, 2006 3:24 pm Post subject: |
i was just wondering is this engine even a 1954 engine or is it a early 55 engine
from the samba vins oval info thread
i got these numbers for decenber of 1954 meaning the last few 1954 engines ended with 945 526 and only 6 total numbers
now the engine in the ad with serial number 1-0921258 wouldn't it be a may of 1955 engine and not a ""1954"" engine
this is just info i collected from the samba http://www.thesamba.com/vw/archives/info/bugchassisdating.php
correct me if Im wrong I just don't want to spend the money if its not right for mt 54 vert thanks guys _________________ **WANTED** ONE 4 1/2 EARLY FUCH |
Posted: Sat Jun 24, 2006 4:19 pm Post subject: |
Thanks for correcting me _________________ **WANTED** ONE 4 1/2 EARLY FUCH |
oldoval Samba Member
Posted: Fri Jul 07, 2006 9:49 am Post subject: |
Just a little question, The add says that the engine for sale LOOKS like this one. The photos are not of the one for sale. Get some of the one for sale before you buy it, It may be even more incorrect. Just my 2 cents OLDOVAL _________________ 1957 Oval Rag |
Posted: Fri Jul 07, 2006 5:24 pm Post subject: |
| The pics that are on Todd's ad is of the '54 engine. The engine that is for sale now is a '55. He's using the '54 pics to sell the '55 engine. |
