Remote oil cooler
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Thu Apr 19, 2007 2:39 pm    Post subject: Remote oil cooler Reply with quote
I might need to add a remote cooler so i'm looking for ideas.
I was thinking of using a sandwich thermostat that sits between the oil filter and base which opens at 180º. Then use a cooler like the Setrab and a fan switch that turns the fan on when it gets 230º. Most of it is a no brainer, but should I go with the single or the dual fan setup?
I'm open to suggestions and other options.
Thermostat
http://aircooled.net/new-bin/viewproductdetail.php?keyword2=ECO0028&cartid=
Fan switch
http://aircooled.net/new-bin/viewproductdetail.php?keyword2=ECO0025&cartid=
Cooler
http://aircooled.net/new-bin/viewproductdetail.php?keyword2=ECO0039&cartid=
Thanks as always.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
alindeman1989
alindeman1989 is offline
PostPosted: Thu Apr 19, 2007 2:58 pm    Post subject: Reply with quote
i have a 2180cc as well and live in sunny cali. i have a external mesa 72 plate cooler with one big fan a a electronic thing that kicks th fan on when it hits 175 degree and never goes past 180. im very happy with it. sit in stop and go all day with it never going past 180 or so. Very Happy
2180 powered 1974 super( sleeping since 2011)
1967 beetle(new project)
Mr. 010
Glenn is offline
PostPosted: Thu Apr 19, 2007 3:02 pm    Post subject: Reply with quote
Where do you have it mounted?
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
alindeman1989
PostPosted: Thu Apr 19, 2007 3:07 pm    Post subject: Reply with quote
above the tranny. nice and out of the way. if you go under the car above the tranny is the luggage area and i monted it on the luggauge area. Very Happy never had a problem. what are your temps right now?
Street Bug 29
Street Bug 29 is offline
PostPosted: Thu Apr 19, 2007 3:33 pm    Post subject: Reply with quote
the cooler bypass thermostat is nice to, helps at start ups,and wont use the cooler when you dont need it
alindeman1989
PostPosted: Thu Apr 19, 2007 3:38 pm    Post subject: Reply with quote
i have one of those. Very Happy
HBRag
HBRag is offline
I've run up to a 2110 in a sedan and never needed a fan on the external oil cooler. I've just mounted a cooler on the bottom side of the package tray with some rubber standoffs (like they use on the FI fuel pumps). The oil temp runs consistently between 180 and 200 degree. On very hot days on long runs (400 miles) it climbs to 210 degrees.
The bigger problem I had aws getting the engine to warm up with oil flowing through the cooler. I ended up mounting a four inlet/outlet mount on a Bugpack bump mount bracket.
http://store.summitracing.com/partdetail.asp?autof...toview=sku
I plugged the out let hole on the back side of the mount and used a short brass nipple to screw the following oil flow thermostat on the forward output.
I then connect the two fittings facing forward on the thermostat to the cooler, and the one remaining (top rear) is the return back to the engine.
With this setup the oil doesn't flow through the cooler until it reached 180 degrees. The optional fan will help control the top temperature (which I do on buses).
vwracerdave
vwracerdave is offline
PostPosted: Thu Apr 19, 2007 4:17 pm    Post subject: Reply with quote
Another option would be a DTM from Jake
grimace007
grimace007 is offline
PostPosted: Thu Apr 19, 2007 4:20 pm    Post subject: Reply with quote
thats the route im goin... ( rabys dtm) but im only building a 1915...
Brian
68 sedan
Dallas Air Coolers
perrib wrote:
Hey It is The Samba where well thought out rational answers can take a while and getting side tracked is normal. I was just lucky this time. Smile
cr@M wrote:
No one has any personal responsibility these days. This country is sue happy. Intelligence is no longer a requirement, just an accessory.
Mr. 010
Glenn is offline
PostPosted: Thu Apr 19, 2007 4:23 pm    Post subject: Reply with quote
I've got my reasons for staying with the OEM shroud.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
jammer729
jammer729 is offline
PostPosted: Thu Apr 19, 2007 6:00 pm    Post subject: Reply with quote
Hey Glenn, What kind of compression are you running? I'm building a similar combo to yours and was just wondering?
Mr. 010
Glenn is offline
PostPosted: Thu Apr 19, 2007 6:29 pm    Post subject: Reply with quote
9.3:1
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Mad Manx
Mad Manx is offline
PostPosted: Thu Apr 19, 2007 7:14 pm    Post subject: Reply with quote
I use one of the sandwich thermostat adaptors along with a Setbab
single fan cooler. I mounted the cooler in the area in front of the axle
and to the left of the tranny. I put the thermostat fan switch (180 deg)
on the outlet of the cooler, I figured if the oil is still over 180 when it
come out of the cooler I should have the fan running. Beware that
even the made in the USA sandwich adaptor needs to be cleaned up
because it was very restrictive. My 2332 runs nice and cool and the
fan only comes on once in a while. Here are a couple of pictures of
the sandwich adaptor before and after.
Marty Staggs
Marty Staggs is offline
PostPosted: Thu Apr 19, 2007 8:23 pm    Post subject: Reply with quote
Yeah those and even the filter adapters need "fine tuning".
Marty
Eaallred
Eaallred is offline
PostPosted: Thu Apr 19, 2007 8:41 pm    Post subject: Reply with quote
Exactly right MM.
Hey Glenn, the single is all you need. They are VERY efficient oil coolers. A single setrab cools as much as a large mesa.
Eric Allred
You have to remember something: Everybody pities the weak; Jealousy you have to earn.
John M.
John M. is offline
PostPosted: Thu Apr 19, 2007 11:22 pm    Post subject: Reply with quote
Here's an interesting site for just seeing how it can be done.
http://www.icbm.org/erkson/ttt/engine/full_flow_oil_system/full_flow.htm
Current: 1972 Beetle - 96V EV
Previous:
1966 Beetle - Sea Blue - 1300SP
1966 Beetle - Sea Blue - 1600SP
1974 Beetle - African Red - 1914CC
RIS
RIS is offline
PostPosted: Thu Apr 19, 2007 11:26 pm    Post subject: Reply with quote
Beautiful illustration of Full flow on a Type 3 = pain in the d%@#
Richard Sedoris - VW Performance & Machine - Youngstown, OH
http://rismachine.tumblr.com/
YouTube: https://m.youtube.com/channel/UCfTBCG4I61iVm_ROc8OAuOQ
Instagram: @rismachine
Banzai KG
Banzai KG is offline
PostPosted: Fri Apr 20, 2007 8:13 am    Post subject: Reply with quote
Mad Manx wrote:
I use a Setbab single fan cooler. I mounted the cooler in the area in front of the axle and to the left of the tranny.
Are you running a swingaxle? Because Glenn has IRS and the limited space of the IRS swing arms may not have the Setrab to fit and will have to have it up higher.
Here is shots of Max Welton's '67 Ghia with the Setrab installed:
I setup my Setrab, mounts, and fanswitch (from Aircooled.net) the same way as Max did on my '64;
One thing I noticed where I mounted mine, I may need to switch to the Joel Mohr mid-mount as the Berg mid-mount rubber pieces won't clear.
The little fins on the bottom are house siding vents and used a screen door mesh to prevent any debris from getting caught between the fins.
Jim Kikuchi
Sunnyvale (near San Jose), CA
1964 Karmann Ghia coupe
V.V.W.C.A. - Golden Gate Chapter: http://www.ggcvvwca.org/
B.L.T.N. (Better Late Than Never) late model VW Club (San Jose/Santa Clara, CA): https://www.facebook.com/groups/bltnvw/
NorCal Aircooled Group (NAG) Facebook Goup: https://www.facebook.com/groups/NAGVW/
Bajaman65
Bajaman65 is offline
PostPosted: Fri Apr 20, 2007 9:42 am    Post subject: Reply with quote
Yea mine is a swing axle and is setup almost exactly the same as the
pictures. ( great pictures by the way ) I forgot about the IRS and the
a-arm being in the way but I am sure Glenn can figure that out. Wink
