Bugman Jeff Samba Member
Joined: May 20, 2004 Posts: 636 Location: Evansville, WI
Posted: Sun Aug 26, 2007 2:37 pm Post subject: 101 HP 1500 SP with STOCK internals!!! |
With a SINGLE carb no less. Thats right, 101 HP without splitting the case. Whats more, it was done in 1969! The November 1969 Hot Rod Magazine features an article on it. Here's a rundown of the specs:
Stock unopened 1500 SP
4-1 header
Single center carb manifold
Zenith 32 NDIX carb
Power pully
'59-'61 Bus distributer
Ported heads w/ 1.4 rockers
Furthermore, it made 79.1 HP with STOCK SP heads. So much for single ports are junk and single carbs don't work... Who were the perpetrators of this build for Hot Rod for Hot Rod? None other than Dean and Ken Lowrey, and Gene Berg. Vintage speed indeed.
_________________ Restorer of Porsche Speedster 80486  |
sbnova Samba Member
Joined: January 27, 2005 Posts: 741 Location: Lakeland,FL
Posted: Sun Aug 26, 2007 3:38 pm Post subject: |
If you right click and save as, you can zoom in with Windows Picture Viewer. _________________ Restorer of Porsche Speedster 80486  |
buggpower Samba Member
Towel Rail Horizontally Opposed
Joined: April 15, 2005 Posts: 4622 Location: SE CR IA US NA PE
Posted: Sun Aug 26, 2007 5:32 pm Post subject: |
The ideas (bigger carb, extractor exhaust, 1.4 rockers, porting the heads) aren't anything new, and can be done with any engine, but that's a cool article nonetheless.  _________________ 1974 Thing -- under the knife
1967 Beetle -- spring/summer/fall driver
1996 Subaru OBW (EJ22, 5-speed, AWD) -- winter car, 3-seasons "don't feel like biking today" car
049 > 070 > 053 > 009 |
millerje78 Samba Amishman
Joined: October 16, 2005 Posts: 2445 Location: Holmes County, Ohio
Posted: Sun Aug 26, 2007 6:01 pm Post subject: |
must have been a seriously talented head porter on staff to make numbers like that! that is very cool. _________________ always seeking a better way
my 73 standard project
do your research, consult with experts, and buy quality parts. you won't be sorry |
vwdmc16 Samba Member
Joined: January 12, 2006 Posts: 1734 Location: sacramento, CA
Posted: Sun Aug 26, 2007 6:07 pm Post subject: |
i see peak power is at 5.5K, just how many times can you run up there and back before the crank says no? i didnt think the stock cam would build any more power above 4400.
this would a great "Myth" to bust. not that im saying they were lying but could it be done today, i wonder what the compression was, and if todays pump gas would cope with it. _________________ "Fiberglass is for boats and race cars-Steel is real-fix it right the first time"-Wolff
'72 Ghia: http://i111.photobucket.com/albums/n146/vwdmc17/100_1964.jpg
'72 Honda Z600
'81 Delorean
www.EVILGENIUSRACING.com |
clearsurf2001 Samba Vaccinator
Joined: February 26, 2004 Posts: 1671 Location: Dave-AKA-fortyeye-Oceanside, Ca
Posted: Sun Aug 26, 2007 6:17 pm Post subject: |
9.2-1, (Glenn will love this) 010 dizzy @ 33deg total advance, and the best part ... $337 total. Amazing!! _________________ Get ready for the injection
| EverettB wrote: |
| Make sure it is coherent. Rodney |
| mharney wrote: |
I think Glenn has an EMPI crank in his engine. |
Randy in Maine Samba Member
Posted: Sun Aug 26, 2007 6:22 pm Post subject: |
That was of course measured as "SAE gross horsepower" was back then using the SAE standard of J245 and J1995.
Doesn't really mean much. |
Posted: Sun Aug 26, 2007 7:46 pm Post subject: |
| Randy in Maine wrote: |
I was about to post that, but I feel like I'm beating a dead horse sometimes!
That, and the horsepower at the wheels will of course be lower... _________________ 1974 Thing -- under the knife
Posted: Mon Aug 27, 2007 12:29 am Post subject: |
It's hard to say. There isn't some kind of ratio between the two, but it would be less. FWIW, the 1600 DP was 60 HP SAE gross, 48 HP SAE net. _________________ 1974 Thing -- under the knife
krusher Samba Member
Joined: September 24, 2002 Posts: 7661 Location: europe
Posted: Mon Aug 27, 2007 12:36 am Post subject: |
hmmm, just put a single zenith/intake, header and 1.4's on a 1500 and you get just short of 80hp, i dont think so, good bit of number fudging going on there.
Bruce Samba Member
Joined: May 16, 2003 Posts: 17639 Location: Left coast, Canada
Posted: Mon Aug 27, 2007 2:20 am Post subject: |
| vwdmc16 wrote: |
| , i wonder what the compression was, and if todays pump gas would cope with it. |
9.2:1. You are right, today's pump gas will not support that CR with a stock cam. No matter what rockers it has. |
67jason Samba Member
Joined: August 28, 2005 Posts: 4741 Location: behind my back feet - Pittsburg CA
Posted: Mon Aug 27, 2007 2:44 am Post subject: |
| krusher wrote: |
yeah i agree the numbers are skewed.
i built a mild 1600, fully balanced, ported and polished heads, dual kads, stock rockers, header, mild cam etc...and it only came out to 75HP 85ftlbs at the flywheel.
and regarding the engine in the article, it was revved to 5500 to achieve max HP, if thats the case it will not last very long. a stock non CW crank will not stand up very well to anything much higher then about 4800 or so.
the vw guys referenced in the article were pioneers in the early VW scene and applied many innovative ideas to increase the performance of the humble aircooled engine, but i think the editors of the mag possibly took some very liberal licenses when it came to the numbers.
even today, one can put all the traditional bolt on goodies on an other wise stock 1600 DP engine, things like 1.25, dual kads or ICTs or whatever, header etc and might get 60-70 HP or so out of thier engines. of course i do understand the differences in measuring HP numbers from back then vs today, but even by todays standards that claim of 101 hp would be around 75-80, not impossible on a 1600cc engine, just not very likely on one that has had nothing done to the internals of the crank case. _________________ 67 bug x3
67 ghia
64 bug |
Jake Raby Samba Member
Joined: August 23, 2003 Posts: 7433 Location: Aircooled Heaven USA
Posted: Mon Aug 27, 2007 6:12 am Post subject: |
How about 181HP from a 1500??
I did it last week!
It's all in the combo of intake, exhaust and etc- _________________ Jake Raby
Raby Engine Development
www.rabyenginedevelopment.com
"I've never given anyone Hell, I just told them the truth and they thought it was Hell" |
Posted: Mon Aug 27, 2007 6:20 am Post subject: |
| Jake Raby wrote: |
I did it last week!
It's all in the combo of intake, exhaust and etc- |
impressive. was that with bone stock from the factory case internals? stock cam, non CW crank?
in your experience, how feesible is it to get 80+ HP out of a 1500 using the stock cam and non CW crank? and would it be a good engine for daily driving or would the heads melt due to insanly high CR? _________________ 67 bug x3
67 ghia
64 bug |
Posted: Mon Aug 27, 2007 6:56 am Post subject: |
No, it was a full race engine- 1493cc.
Yes, I feel that a 1500 with just a cam change could make 80 HP... 9.3:1 should get it there and some head work would help..
BTW- The stopck ratings are a joke- they are Din HP as well, not SAE _________________ Jake Raby
vwairheads Samba Member
Joined: March 26, 2007 Posts: 675 Location: chula vista
Posted: Mon Aug 27, 2007 7:23 am Post subject: |
| Jake Raby wrote: |
I did it last week!
not surprising if you have turbo or super charger. |
RIS Samba Member
Joined: December 18, 2003 Posts: 3044 Location: Youngstown, Ohio
Posted: Mon Aug 27, 2007 7:26 am Post subject: |
| millerje78 wrote: |
| must have been a seriously talented head porter on staff to make numbers like that! that is very cool. |
Hard to top this crew Jesse!
| Quote: |
| Who were the perpetrators of this build for Hot Rod for Hot Rod? None other than Dean and Ken Lowrey, and Gene Berg. |
_________________ Richard Sedoris - VW Performance & Machine - Youngstown, OH
http://rismachine.tumblr.com/
YouTube: https://m.youtube.com/channel/UCfTBCG4I61iVm_ROc8OAuOQ
Instagram: @rismachine |
