Motor rebuild
Deluxe Lowlight Ghia
Deluxe Lowlight Ghia is offline
PostPosted: Fri May 29, 2009 10:44 pm    Post subject: Motor rebuild Reply with quote
The time has come for my motor rebuild in my lowlight and in going to do a 1776cc. I have some questions
1. Where do I get a DTM fan shroud?
2. Should i full flow the case?
3. Will dual 36 dells be enough carb?
4. Will the A1 sidewinder work with the DTM shroud?
I am going to drive the car everyday and i never want to rebuild the motor again is there anything I should do to keep it from spinning a berring again?
These vws are cool but the people who own them are far more valuable. Keep friends close they can be taken away overnight.
57 ghia
“57 factory safari 11 window”
59 patina ghia
61 patina Ghia
71 bus
74 thing
75 half bug
AlteWagen
Troll
AlteWagen is offline
PostPosted: Sat May 30, 2009 12:50 am    Post subject: Re: Motor rebuild Reply with quote
Q. 1. Where do I get a DTM fan shroud?
A. www.aircooledtechnology.com
Q. 2. Should i full flow the case?
A. Yes. Use a quality filter to catch all the crap that otherwise would wear your bearings out.
Q. 3. Will dual 36 dells be enough carb?
A. Depends on your heads and cam. Mild heads and mild cam will work perfect. 36 dells (30 vent) are the same as 40 webers
Q. 4. Will the A1 sidewinder work with the D
DTM shroud?
A. I cant afford either so I cant answer the question. Remember to match your primary size to your head/valve.
If using stock heads go with something like an Engle 100 and 8:1 compression for reliable power. If you really want the engine to last forever you MUST have a shop balance ALL rotating parts (Clutch, flywheel, crank, rods, pistons, pulley) for long bearing/engine life. You will usually have to do a valve job and new valve springs around 50K miles but the bottom end will go 100K if you do the maintenance. I would also get a deep sump if your ride is not too low and gauges are a must (CHT, Oil Temp, Oio Pressure, tach is nice too). That way if there is a problem with heat or oil pressure you can see it before it does any real damage. Very Happy
Remember more revs = shorter engine life, the more you "race" it the more maintenance is required and the faster it wears out.
PostPosted: Sat May 30, 2009 12:27 pm    Post subject: Reply with quote
i hate running my motor above 3 grand.
I want to run a engle 120 cam and 8:1 compression and do alittle amount of head work.
My car is slammed 2 inner clicks in the rear.
I will get a tach, oil pressure, oil temp, and maybe a head temp.
I will get everything balanced.
I am going to dyno it 1 time just to see what power im gonna get im shooting for at leaset 90 to 100 HP.
Thanks for the help
57 ghia
59 patina ghia
61 patina Ghia
71 bus
74 thing
75 half bug
PostPosted: Sat May 30, 2009 12:30 pm    Post subject: Reply with quote
also the motor that is currently in my ghia right now has 90 compression on each piston. And it has no oil pressure could i just put pistons on and fix this? I need this motor for my vert.
57 ghia
59 patina ghia
61 patina Ghia
71 bus
74 thing
75 half bug
also the motor that is currently in my ghia right now has 90 compression on each piston. And it has no oil pressure could i just put pistons on and fix this? I need this motor for my vert. or i need 1 40 horse piston and cyclender
57 ghia
59 patina ghia
61 patina Ghia
71 bus
74 thing
75 half bug
craigman
craigman is offline
PostPosted: Sat May 30, 2009 12:40 pm    Post subject: Reply with quote
"shooting for at leaset 90 to 100 HP."
Not gonna happen with a mild 1776. Not even close. Maybe 70hp.
Your also hurting the motor by not reving above 3K. This is not a water cooled motor. It needs that fan speed to cool. Also no need to balance it if your not going to rev it more than 3K.
36's will run great on that motor.
PostPosted: Sat May 30, 2009 12:50 pm    Post subject: Reply with quote
I was just looking at the DTM site and I cant figure out how to order a DTM shroud.
57 ghia
59 patina ghia
61 patina Ghia
71 bus
74 thing
75 half bug
Max Welton
Max Welton is offline
PostPosted: Sat May 30, 2009 1:53 pm    Post subject: Reply with quote
Then you may not be qualified to own one.
Max
1967 Type-3 Fastback
AlteWagen
Troll
PostPosted: Sat May 30, 2009 3:51 pm    Post subject: Reply with quote
90 is acceptable but putting new pistons will do nothing to help oil pressure Rolling Eyes Rolling Eyes
Maybe broken oil pump gear or incorrect pump altogether or just worn out bearings. If you ran the engine with no pressure plan on replacing the bearings at least, that is if it didnt overheat which is unlikely. Consider it junk and practice on it.
For a 1776 a DTM costing $500+ is not really necessary. Ask Jake and he will probably recommend a stock dog house set up with ALL of the factory tin and not using the Type III "cool tin"
AlteWagen
Troll
PostPosted: Sat May 30, 2009 3:55 pm    Post subject: Reply with quote
a 120 needs 9:1 compression to work right and sets the power in the upper rpm range. Even with a little head work stick with the 110 and 8 or 8.5:1 compression. I run my stroker 1.7 at 3200-3500 on the freeway with no problems using a stock cooling system. Above 4000 it heats up and wastes gas!!!
You definately need the CHT gauge cause that will really tell you how hot your engine is. If you were to only get two gauges get the oil temp and CHT, your idiot light (if working) will suffice for pressure.
P.S. dont get larger than a 26mm oil pump or your engine will run hot.
DarthWeber
DarthWeber is offline
PostPosted: Sat May 30, 2009 9:26 pm    Post subject: Reply with quote
Max
Laughing Applause
PostPosted: Sat May 30, 2009 10:43 pm    Post subject: Reply with quote
i plan on running my deano oil pump
im still learning about the motor parts like what has to go together to work correctly
57 ghia
59 patina ghia
61 patina Ghia
71 bus
74 thing
75 half bug
scott s
scott s is offline
PostPosted: Sun May 31, 2009 4:43 am    Post subject: Reply with quote
Do NOT run the 120 with 8:1 CR and " a little head work". You need bigger valves, port and polish and ~8.5-9:1 to take advantage of that cam.
What size valves will you be using?
Remember, it's all in the combo. If you don't match up the parts you end up with an underpowered pig with a peaky or mushy powerband that will get crappy mileage and run hot.
You'll be surprised at what a 1776 with stock heads, a 110 cam and ~8:1 CR will do....especially if you have an engine that's in poor shape right now. And it sounds like you do. A 70-75HP engine will feel a LOT different than that worn out 37.8HP you're making now!
Nothing screams "poor workmanship" like wrinkles in the duct tape.
PostPosted: Sun May 31, 2009 2:56 pm    Post subject: Reply with quote
so just a 1776, 110 cam, 8:1 compression with stock heads and my dual dells and balance everything
57 ghia
59 patina ghia
61 patina Ghia
71 bus
74 thing
75 half bug
scott s
scott s is offline
PostPosted: Mon Jun 01, 2009 6:40 am    Post subject: Reply with quote
Yep. Great, reliable, proven combo that will run cool and last almost as long as a stocker. Feel free to clean up the heads a little...a mild "fluff and buff" port job.
This engine combo works well with heater boxes, too.
Be sure to run a sump and full flow.
PostPosted: Tue Jun 02, 2009 10:37 pm    Post subject: Reply with quote
no sump my cars slammed just the full flow
57 ghia
59 patina ghia
61 patina Ghia
71 bus
74 thing
75 half bug
azaircooled
azaircooled is offline
PostPosted: Wed Jun 03, 2009 7:35 pm    Post subject: Reply with quote
don't know if you have a shop in mind to do you balancing and machine work, but i sent all my stuff to competition engineering. bunch of great vw guys, and fast turn around time. ask for Dan.
their web site- www.cevw.com
