Welding on a fuel tank?
Hotrodvw
Hotrodvw is offline
PostPosted: Fri Oct 30, 2009 10:43 pm    Post subject: Welding on a fuel tank? Reply with quote
What can I do to make a fuel tank safe to weld on??
My plan is to fill it w/ hot water and a touch of dish soap/detergent, aggitate, drain and rinse. Do I need to fill it back up w/ water to help expel any remaining fumes?? I would think that cleaning it would do the trick. Any ideas?
'67 Sunroof
Eric
78x94 with IDA's....oober fun
Horsepower is an addiction........Addictions cost
lots of money!
Hose & Fittings
LeviMan2001
Samba Post Whore
LeviMan2001 is offline
PostPosted: Fri Oct 30, 2009 10:56 pm    Post subject: Reply with quote
I don't recomend it, but it reminds me of this:
http://www.thesamba.com/vw/forum/viewtopic.php?t=366056 - My '73 Super Build. 2332cc, 16" Fuchs
gkdorman
gkdorman is offline
PostPosted: Sat Oct 31, 2009 5:18 am    Post subject: Reply with quote
I'd just buy a new tank, personally. But if you're serious, the trick the pros use is to fill the gas tank completely, i.e. no room for vapors, as it is the vapors that ignite, not the liquid.
Oh, BUGger.
'76 111 resto/mod...
Hotrodvw
Hotrodvw is offline
PostPosted: Sat Oct 31, 2009 7:10 am    Post subject: Reply with quote
Well, this is for a '73 F-250 truck fuel tank. We're doing a Retrotek efi conversion, and I need a vent line and a return line. Filling it completely is what I was wondering....not opposed to that. I was just thinking water and electricity together might be another problem. Shocked
'67 Sunroof
Eric
lots of money!
Hose & Fittings
juki48
juki48 is offline
PostPosted: Sat Oct 31, 2009 7:14 am    Post subject: Reply with quote
I've welded tanks before. washed and cleaned with dish soap and water, then I put it on the tailpipe of a running car and let it sit there for a long time and warm up and dry out. then while still on the tailpipe I welded it. if there is only exhaust in there it can't ignite.
Hotrodvw
Hotrodvw is offline
PostPosted: Sat Oct 31, 2009 7:22 am    Post subject: Reply with quote
Right, the o2 will deplete the oxygen, correct?
'67 Sunroof
Eric
lots of money!
Hose & Fittings
Type 5 Joe
Banned
Type 5 Joe is offline
PostPosted: Sat Oct 31, 2009 7:26 am    Post subject: Reply with quote
I would use generous amounts of Dawn dishwashing soap and the hotest water source you can get.....
Hook up a hose directly to your water heater, turn it up on the hottest setting....Do not let pressure build up in the hose (unless you have a heavy duty restaurant quality hose) it will swell and burst in short order.
Douche it out over and over.... rinse it over and over again with cold water.
Use inert (argon) gas from a welding bottle and completely fill it to purge all oxygen from it... Continue to flow gas through the tank when you are welding.
Be careful.
If you would like to contact me, just email through one of my ads on here...
I don't use the P.M. service on here.
Hotrodvw
Hotrodvw is offline
PostPosted: Sat Oct 31, 2009 7:28 am    Post subject: Reply with quote
The Argon is a good idea....
'67 Sunroof
Eric
lots of money!
Hose & Fittings
Eaallred
Eaallred is offline
PostPosted: Sat Oct 31, 2009 7:29 am    Post subject: Reply with quote
The tailpipe trick is all you need to do. Put the exhaust of a 'modern' car with a catalytic converter into the tank for about 15 minutes or so. The exhaust is pretty much innert, and is hot, it will dry the tank out and remove all the fumes in short order. Works great, that's what I did when welding fittings onto my stock steel tank.
Eric Allred
You have to remember something: Everybody pities the weak; Jealousy you have to earn.
Hotrodvw
Hotrodvw is offline
PostPosted: Sat Oct 31, 2009 7:30 am    Post subject: Reply with quote
But I don't need to have the exhaust flowing while welding it, right? That would suck to be welding and gasping for oxygen! Laughing
'67 Sunroof
Eric
lots of money!
Hose & Fittings
Type 5 Joe
Banned
PostPosted: Sat Oct 31, 2009 7:37 am    Post subject: Reply with quote
It does work, but I would never recommend it as a practice to use....
Using a newer car with a cat is a good Idea, but can you be absolutely sure there is no atomized fuel in the exhaust?
Hate to see you become the victim of a flame-thrower exhaust pipe.
Had an neighbor across the street blow himself up doing this. I don't know if he didn't get the tank clean enough or what. They needed to remove the old guy from the ceiling of his shop with a putty knife. ugly.
Inert gas is the safest method, and gives the best welding results regardless what you are welding... Roll cages, exhaust systems, etc...
miniman82
Samba Swamp Donkey
miniman82 is offline
PostPosted: Sat Oct 31, 2009 8:17 am    Post subject: Reply with quote
I've always just washed them out with dish soap, and let them dry. Gonna have to do it again soon, I'm thinking about converting to an in-tank EFI pump.
Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote:
satterley_sr wrote:
I just wanted to bitch but I'm getting no sympathy.
Welcome to the Samba.
Hotrodvw
Hotrodvw is offline
PostPosted: Sat Oct 31, 2009 8:20 am    Post subject: Reply with quote
I've also considered retro-fitting an in tank pump.
'67 Sunroof
Eric
lots of money!
Hose & Fittings
sbnova
sbnova is offline
PostPosted: Sat Oct 31, 2009 8:33 am    Post subject: Reply with quote
If your doing this to a newer Ford fuel tank, you may be able to add lines at the access hole. Alot of tanks have a ~3" diameter "plate" where the sender installs, and sometimes theres room for adding lines to it.
Other than that, Ive welded plenty of used tanks. I always emptied them, washed them out and let them dry before welding. The exhaust trick sounds great- I think I'll use that myself next time as it'll dry the tank out fast.
Link to my build thread- Updated 6-6-07 http://www.thesamba.com/vw/forum/viewtopic.php?t=210613
check my sites to see my work;
http://www.cardomain.com/ride/1564293 (bug)
http://www.cardomain.com/ride/448794 (Vette,Nova,Typhoon)
Hotrodvw
Hotrodvw is offline
PostPosted: Sat Oct 31, 2009 8:34 am    Post subject: Reply with quote
I stated above, it's for a '73 F-250 tank
'67 Sunroof
Eric
lots of money!
Hose & Fittings
Eaallred
Eaallred is offline
PostPosted: Sat Oct 31, 2009 10:19 am    Post subject: Reply with quote
No, the car doesn't have to be running while you weld. Just run the car/truck until the gas tank is nice and warm.
I ran mine in the driveway, then carried the tank into the garage to weld it.
Eric Allred
Bruce
Bruce is offline
PostPosted: Sat Oct 31, 2009 11:01 pm    Post subject: Reply with quote
When I welded on my tank, I just drained it, then stuck the blowing end of the shop vac to the filler hole and let the forced air dry it out. Air doesn't burn, fuel does. With fresh air constantly blowing into it, nothing can burn.
souper
souper is offline
PostPosted: Sat Oct 31, 2009 11:50 pm    Post subject: Reply with quote
modern fuel tanks are soldered not welded. If you are trying to weld over a soldered seam you going to have leaks anyway.
6t5 Buggy
6t5 Buggy is offline
PostPosted: Sun Nov 01, 2009 5:42 am    Post subject: Air fuel mixture... Reply with quote
You are joking, right? Laughing
lostinbaja
lostinbaja is offline
PostPosted: Sun Nov 01, 2009 6:01 am    Post subject: Reply with quote
Fill it with water and weld it. If there are no fumes or places for fumes it won't ignite.
Jerry...
If it's being towed, it must be a trailer!
"Vee Grow Too Soon Oldt Und Too Late Schmardt"
RIP Morgan
My photos
http://www.manxgallery.org/gallery/album92
