vanagon91 Samba Member
Joined: December 31, 2009 Posts: 75 Location: Virginia's Blue Ridge Mountains
Posted: Tue May 18, 2010 5:05 pm Post subject: Lock Question |
| How do you change the tumblers in a icepick door handle? Thanks, Sam |
RareAir Samba Member
Joined: May 11, 2002 Posts: 14577 Location: 18 miles North of the border
Posted: Tue May 18, 2010 6:25 pm Post subject: |
First you'll need to disassemble the door handle.
Then, you'll need to remove a tiny jewelers screw that holds the key lock into the handle
Once that screw is removed, the key lock portion will easily slide out of the handle body
The Brass wafers (tumblers) can then be easily pushed out & replaced _________________ 1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241 |
Bruce Samba Member
Joined: May 16, 2003 Posts: 17636 Location: Left coast, Canada
Posted: Tue May 18, 2010 8:35 pm Post subject: |
| RareAir wrote: |
Sometimes not. _________________
| overheard at the portland Swap Meet... wrote: |
| ..... a steering wheel made from a mastadon tusk..... |
VWNate Samba Member
Joined: October 04, 2016 Posts: 443 Location: Sunny So. Cal.
Posted: Wed Dec 20, 2023 7:17 pm Post subject: Ice Pick Lock Question |
How to take the handle apart ? .
Someone must have done this and taken pictures.....
TIA, _________________ -Nate
One last Beetle : 1959 #113 DeLuxe survivor ~ 36HP & full synchro tranny, 6 volts etc. |
EverettB  Administrator
Joined: April 11, 2000 Posts: 71759 Location: Phoenix 602
Posted: Wed Dec 20, 2023 9:06 pm Post subject: Re: Lock Question |
You double-posted this so I pasted in your text below with my answer:
| Quote: |
I don't see a thread for how to take the '56 ~ '59 door handles apart, I need to replace the spring and re key it to match my original SG ignition .
Any links would be highly appreciated, I've been searching 'door key', 're key', door handle key', on and on.....
Once you've done it a few times re keying isn't difficult, it's just one more fiddly detail oriented job best done over a white or light colored towel as small parts tend to fall, bounce or PING off into God alone knows what other universe .
TIA, I'm sure someone has done this before .
Bus handle spring replacement thread below, I think they are the same?
https://www.thesamba.com/vw/forum/viewtopic.php?t=146325
Lock cylinder removal, there's a tiny screw once it's apart:
https://www.thesamba.com/vw/forum/viewtopic.php?t=335745
and
https://www.thesamba.com/vw/forum/viewtopic.php?t=313084 _________________ How to Post Photos
VWNate Samba Member
Posted: Thu Dec 21, 2023 7:53 am Post subject: Pre '60 Door Handle Disassembly |
Thanx Everett ;
What I was after was info on knocking the pin out without breaking the pot metal part . _________________ -Nate
VWNate Samba Member
Posted: Thu Dec 21, 2023 8:22 am Post subject: Re: Lock Question |
Thank you Sir .
I have a few decent old handles sans keys I want to mix & match plus re key to match the ignition and T handle . _________________ -Nate
Bugfan-MR Samba Member
Joined: November 12, 2022 Posts: 23 Location: Germany
Posted: Wed Aug 06, 2025 1:54 pm Post subject: Re: Lock Question |
Does anyone know where to get the tumbler plates to build a lock?
For SG keys, the wafer #1 #3 #5 seem to have been used.
Cannot find ANYONE who is selling a set of tumbler plates or who can pinpoint if any of these plates are re-used in other sets, so we could purchase them from elsewhere and put together the correct settings.
The only shop I've come across who offered the correct ist this one:
https://heritagestocks.com/product/111837218-set-of-tumblers-lock-cylinder/
The set is out of stock and I doubt there are any NOS sets left worldwide. But nowadays surely someone has repopped them ... ?? |
VWNate Samba Member
Posted: Wed Aug 06, 2025 6:08 pm Post subject: Re: Lock Question |
There's a guy in Southern California who has plates, I don't know if he sells them, he re keyed my old SG cylinders to match the whole car and used new plates and springs . _________________ -Nate
Bruce Samba Member
Posted: Thu Aug 07, 2025 1:47 am Post subject: Re: Lock Question |
Get wafers from other handles and locks at your local swap meets. Look for the worst handles that are too far gone to be restored.
There are two diameters of wafers, 12 and 13mm. The 12mm wafers were used through the 50s and 60s, so any 60s handle will give you wafers you can use. Passenger side door handles will have the least wear. _________________
Posted: Sat Aug 23, 2025 11:37 pm Post subject: Re: Lock Question |
Wish swap meets were that common that it would work out. I'd rather find a source that sells tumblers that are compatible with VW 50s locks.
But so far ... |
