What ignition wires / plug wires do you use and why
dirtylawnchair
dirtylawnchair is offline
PostPosted: Mon Sep 27, 2010 12:20 pm    Post subject: What ignition wires / plug wires do you use and why Reply with quote
What ignition wires / plug wires do you use and why?
Paulie
63 Standard OG paint
jfats808
jfats808 is offline
PostPosted: Mon Sep 27, 2010 12:51 pm    Post subject: Reply with quote
I use Taylor 10.4 Thunder cables. These wires are definitely not needed and doesnt do the job anybetter than the normal Bosch silicone wound or 8mm types for normally stock type ignitions ( blue coil, mechanical distributor set ups). Only difference is it dresses up my engines nicely and is just a personal choice. I would only install this type of wires on my own engines as preference or request of a customer.
Once you start going MSD and some electronic set ups, you should follow the suggested manufacturers recommendation on wires/plugs. Plugs I use Denso's currently in my big engine and am now making the switch to Bosch's. Np with the Denso's, the Bosch have become easier for me to attain.
2276 IDA's 86C 11-1 DD
Rockstar Suzuki wrote:
You might as well put 10 year build in your bullshit sig, as it will NEVER run. Also your a dick
You can always learn something new, even from a fool.
Check your oil levels routinely!
mharney
mharney is offline
PostPosted: Mon Sep 27, 2010 3:39 pm    Post subject: Reply with quote
Bosch wires, and NGK plugs, because they are a rock solid product, and they are all I need.
For higher compression engines, or for the neophyte that wants to weld the air-fuel mixture, high energy ignitions can help out, which will warrant more wirepower and a bit of increased plug gap.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Mon Sep 27, 2010 3:40 pm    Post subject: Reply with quote
Bosch 09001 7mm silicone because they're all you need unless you have a monster drag race engine
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
madmike
madmike is offline
PostPosted: Tue Sep 28, 2010 6:32 am    Post subject: Reply with quote
MSD on my Monster Drag Motor Laughing Stock type black ones on all the rest,Just stay clear of them "Purdy" colored ones=Junk,A custmer brought his own wires to me the other day and they fit good and were the stock type, he said Advance Auto had them in stock Cool
'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
"If I'm ever on Life Support,UNPLUG Me, Then Plug me back In see if that Works"
dirtylawnchair
PostPosted: Tue Sep 28, 2010 6:40 am    Post subject: Reply with quote
Interesting read:
http://www.rodandcustommagazine.com/techarticles/1006rc_ignition_wiring/index.html
Paulie
miniman82
Samba Swamp Donkey
miniman82 is offline
PostPosted: Tue Sep 28, 2010 6:54 am    Post subject: Reply with quote
Bosch wires for a Ford Escort, because I have the ignition system from that car. Laughing For plugs, I use Champion copper, I forget which heat range.
catbox
catbox is offline
PostPosted: Tue Sep 28, 2010 7:11 am    Post subject: Reply with quote
I use the MSD 8.5 super conductors, cause they go with the rest of the ignition system in the car.
The plugs are bosch.
MAYHEM
MAYHEM is offline
PostPosted: Tue Sep 28, 2010 7:24 am    Post subject: Reply with quote
Taylor 409 race wires. They look huge and are Taylor so I know the quality is there. Always used the gray Bosch before that. Never had a problem.
Greg
Model Citizen
johnnypan wrote:
I digitize myself in the privacy of my own home.
perrib
perrib is offline
PostPosted: Tue Sep 28, 2010 7:36 am    Post subject: Reply with quote
Bosch 09001 for 99.9% applications. MSD and distributor less ignition are the exceptions.
Stripped66
Stripped66 is offline
PostPosted: Tue Sep 28, 2010 8:55 am    Post subject: Reply with quote
NGK plugs. I was using 8.5mm Magnecores, but they degraded significantly after about 10K miles. Currently using a set of 8.5mm MSD wires.
66brm wrote:
Bodacious wrote:
Why not just make a custom set of wires with a Y splice in them. Then you could just run one distributor.
I don't think electrickery works that way
RockCrusher
RockCrusher is offline
PostPosted: Tue Sep 28, 2010 1:29 pm    Post subject: Reply with quote
What?.....No one is runnin those purdy wire braid covered ones with the ground wire? I hear those are the best money can buy if you don't mind throwing your money down the sewer. Laughing
[email protected] Please use email for all general inquiries.
I will be happy to speak to anyone who has a serious inquiry (meaning real potential business for RC enterprises) or a parts order. Due to machining noise causing missed calls all calls will be returned promptly.
dirtylawnchair
PostPosted: Tue Sep 28, 2010 1:33 pm    Post subject: Reply with quote
? what brand is that and why are they bad?
Paulie
Mr. 010
Glenn is offline
PostPosted: Tue Sep 28, 2010 1:42 pm    Post subject: Reply with quote
Nology? I ran them on my 16v and they were nice. But on a basic ACVW they are a waste of money.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
dirtylawnchair
PostPosted: Tue Sep 28, 2010 1:58 pm    Post subject: Reply with quote
Nology makes a good quality ignition wire. I have never used a set from them, but I know the quality is great.
Paulie
[email protected]
john@aircooled.net is offline
PostPosted: Tue Sep 28, 2010 1:59 pm    Post subject: Reply with quote
You can use a High Powered ignition and get by fine with "cheaper" wires if you keep the plug gaps ~.030". Using big gaps causes way more problems than it solves, and over-stresses the secondary ignition.
It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net
Almost Alive
Almost Alive is offline
PostPosted: Tue Sep 28, 2010 2:21 pm    Post subject: Reply with quote
Bosch wires, they have a lifetime warranty Very Happy
RockCrusher
PostPosted: Tue Sep 28, 2010 3:39 pm    Post subject: Reply with quote
Kinda depends whether it's for racing or a driver. Bigger gaps also depend on the spark plug used or the prep of the plug. In one of my pics in my link site there is a Jacobs coil in the background. I always liked their stuff (especially the coils). Unfortunately, that one has suffered a crack.....damn! I epoxied it but it still leaks a little. Never ever had a failed Jacobs wire.
RC
volkyoo
volkyoo is offline
PostPosted: Tue Sep 28, 2010 4:31 pm    Post subject: Reply with quote
msd 8.5 mm wires, superconductor. cause i have all msd ignition system .
bosch spark plugs.
Eaallred
Eaallred is offline
PostPosted: Wed Sep 29, 2010 6:15 am    Post subject: Reply with quote
I don't use plug wires anymore...... Razz
Eric Allred
You have to remember something: Everybody pities the weak; Jealousy you have to earn.
