thom Samba Member
Joined: October 12, 2000 Posts: 6286 Location: Sacramento
Posted: Sun Apr 08, 2012 3:14 pm Post subject: T34 Rockers? |
Is there a better source for T34 rocker pieces? I did some searching, and it seems that Lars Neuffer had them at one point, but his site is pretty much defunct. There's references to a type34.org, but that's dead, too.
These are "ok" but will need some work to get the lower profile correct.
_________________ -Thom
1956 Single Cab
1957 Porsche 356A Sunroof
1957 23-Window Deluxe
1963 Unimog 404
1965 E-Type |
t3kg Samba Member
Joined: June 14, 2006 Posts: 2712 Location: Los Angeles
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 23565 Location: Kimball, Mi
Lee Hedges Samba Member
Joined: November 09, 2000 Posts: 813 Location: San Diego
Posted: Sun Apr 08, 2012 8:31 pm Post subject: |
| Carsten Klein (Germany) distributes the repro rocker panel set (6 pcs) for Jurgen Magdelyns (Belgium) at the least expensive cost. He's a pro at packing/shipping as well. Jurgen's rocker panels can be seen installed on a Regatta Blue 1968 in Belgium in the #15 T34 World News magazine (www.T34World.org). It's the best source from a true T34 enthusiast. |
thom Samba Member
Posted: Tue Apr 10, 2012 6:19 am Post subject: |
Are those the same as the ones I have?
1956 Single Cab
1963 Unimog 404
1965 E-Type |
t3kg Samba Member
Posted: Tue Apr 10, 2012 9:39 am Post subject: |
| t3kg wrote: |
| thom wrote: |
I don't think the sheet metal pieces that Rudiger and Jurgen sell are the same stampings as the red primered stuff, but I don't know for sure. Lee, do you know the original source for the re primered aftermarket pieces? |
You might try asking Tom Reay, as the lower half of his "late" t-34 has them. I can't remember who he said he got them from, but they did fit pretty decent (according to his pics). _________________ Bob 65 Notch S with Sunroof
| Tram wrote: |
| "Friends are God's way of apologizing for relatives." |
| Tram wrote: |
| People keep confusing "restored" and "restroyed". |
Posted: Tue Apr 10, 2012 7:36 pm Post subject: |
| I do believe that all three sources use different parts. Lars has the red ones, Jurgen's are gray primered, and KG.de are different too. Jurgen's are the least expensive by far. US$700 SHIPPED to America from Belgium for the 6-piece rocker panel set. |
t3kg Samba Member
Posted: Tue Apr 10, 2012 9:46 pm Post subject: |
The only experience I have is with my 1965 that was fitted with Lars' rocker set produced off the original master presses at Karmann in 2004. These are no longer available.
I don't know how you'd decide which fits the best. No one would buy all three and evaluate their fit. A good bodyshop is the key to getting the right fit, obviously. Jurgen fits his own products to T34s like the Regatta Blue 1968 M345 featured in T34 World News the past few editions. That speaks volumes about his products, in my opinion anyway. |
Tram Samba Socialist
Joined: May 02, 2003 Posts: 23022 Location: Northwest of Normal
Posted: Tue Apr 10, 2012 9:54 pm Post subject: |
| Lee Hedges wrote: |
Not only that- it almost seems as if no two Type 34s are exactly identical in those areas. The patch panels may also actually fit better with the body off the pan. _________________ Немає виправдання для війни! Я з Україною.
| Bryan67 wrote: |
| Just my hands. And a little lube. No tools. |
Those who can- do.
Those who can't? Subaru. |
Posted: Wed Apr 11, 2012 5:54 am Post subject: |
[quote="Tram"]
| Lee Hedges wrote: |
| A good bodyshop is the key to getting the right fit, obviously. |
Not only that- it almost seems as if no two Type 34s are exactly identical in those areas. /quote]
Both of these comments are right on the money. A good body shop can make ill fitting panels fit good, and look good. And you have to remember, these cars were hand built. They might have used jigs during the fitting portion of the body build, but the pieces were still hand fitted to each body, and custom shaped to it. That's part of the reason doing hood, trunk lid, or door swaps seem to create new problems that didn't exist before (they were all matched to each body at the factory for fit and finish). Again, this is where a good body shop comes into play, in getting everything right.  _________________ Bob 65 Notch S with Sunroof
| Tram wrote: |
| Tram wrote: |
t3kg Samba Member
reay Samba Member
Posted: Wed Apr 11, 2012 12:23 pm Post subject: |
Here is a picture of mine getting fitted.I bought them from Ruditger.
I had them epoxy primed after I got them.
I also bought the wheel wheels and the other rocker pieces. Seemed to work just fine. _________________ Tom Reay
Nothing is standard o a Standard!
68 Karmann Ghia Sunroof / auto T345
66 Standard Microbus T221
66 1200a Standard 115 with factory ragtop |
thom Samba Member
Posted: Wed Apr 11, 2012 5:56 pm Post subject: |
Cool, thanks for the feedback! If any of you had seen the issues I had with my '57 23-window, you'd understand why I'm a bit more careful about repro meta. _________________ -Thom
1956 Single Cab
1963 Unimog 404
1965 E-Type |
