denver_74 Samba Member
Joined: May 30, 2011 Posts: 540 Location: Northern NY
Posted: Wed May 23, 2012 1:17 pm Post subject: is there a trick to get the crank pulley back on? |
i removed the old santana crankshaft pulley (engine in car - tins in place) and i started to put the new pulley on and its a tight fit!
so tight that i can only get it on approx. 1/4" (pushing, wiggling and shoving) before it sticks...no room for hammer..is there a trick?
heat?
D _________________ 1974 Standard Beetle Sunbug |
donmurray Samba Member
Joined: December 30, 2008 Posts: 841 Location: Frisco Texas
Max Welton Samba Member
Joined: May 19, 2003 Posts: 11134 Location: Black Forest, CO
Posted: Wed May 23, 2012 1:31 pm Post subject: |
thank you! my ol'lady is going to kill me! (i luv it) _________________ 1974 Standard Beetle Sunbug |
jfats808 Samba Member
Joined: December 10, 2007 Posts: 5022 Location: oahu hawaii
Posted: Wed May 23, 2012 1:57 pm Post subject: |
You can try 400 grit wet sanding and smear some grease in the ID of the pulley before dropping the engine. Soon as you can get the nut in, tighten, then loosen, then tighten, then loosen....etc. _________________ 2276 IDA's 86C 11-1 DD
| Rockstar Suzuki wrote: |
You might as well put 10 year build in your bullshit sig, as it will NEVER run. Also your a dick |
You can always learn something new, even from a fool.
Check your oil levels routinely! |
red caddy Samba Member
Posted: Wed May 23, 2012 2:00 pm Post subject: |
Many years ago I had a major screaming match with my bride, over some piston's and rods in the dishwasher and some other "non food" stuff in the oven...
To keep the peace, (piece?) I ended up with a prefectly good washer and dryer, a dishwasher and a gas stove in MY shop. Been peaceful ever since...
Paul _________________ If it turns $$$ into smoke and noise, I'm there.
My last build thread. http://www.thesamba.com/vw/forum/viewtopic.php?t=466571 |
slalombuggy Samba Member
Posted: Wed May 23, 2012 2:36 pm Post subject: |
Nothing like getting caught with a sink full of rods and timing gears warming on the stove. Then there was the time I baked a bunch of parts I painted with enamal in the oven...boy that didn't go well
brad |
mark tucker Samba Member
Joined: April 08, 2009 Posts: 23945 Location: SHALIMAR ,FLORIDA
Posted: Wed May 23, 2012 2:43 pm Post subject: |
| make sure the key hasent slid up the key way!!! it will effup the pully!!! check it before you proceed!!! |
Greezy Joe Samba Member
Joined: April 12, 2010 Posts: 1534 Location: Crawfordville, Fl
Posted: Wed May 23, 2012 5:29 pm Post subject: |
| slalombuggy wrote: |
brad |
Been there done that and have the State Go Kart Race t-shirt. I put into the oven, go kart tires mounted to rims to get stagger like I needed, that went over real well with the wife. She blew a head gasket , I finished the race  _________________ Current:74 Ghia Coupe w/ 2276
71 Ghia Vert w/ 1835
07 GMC Truck
12 Jeep Wrangler
73 Harley FLH 93 cid
89 Harley 883 Sportster (1200)
Owned before: 58, 69 Ghia Coupes, 64 Canvas Sunroof, 68, 72, 73, & 74 Bugs, 63 Single Cab, 65 Bus, 66 & 70 Camper
" Duct tape can't fix stupid, but it'll muffle the sound". |
HeidiHo Samba Member
Joined: September 26, 2010 Posts: 772 Location: Lowrys, S.C.
Posted: Wed May 23, 2012 6:55 pm Post subject: |
When I swapped my stock pulley for a degreed I threw it in the oven for a few minutes at like 200*F, had some white grease on the counter. Pulled it out of the oven, greased it, and ran out to the car with pulley in hand. Went right on!
The joys of being single  _________________ My 1970 Beetle Thread
Southern Integrity Aircoolers |
DarthWeber Samba Member
Joined: November 24, 2007 Posts: 7542 Location: Whittier,CA
Posted: Wed May 23, 2012 7:03 pm Post subject: |
| HeidiHo wrote: |
The joys of being single  |
Are you related to Tom Wilson?  _________________
| Mitey62 wrote: |
| Swapped the Compufire for a Bosch blue and some points I had sitting around, started 1st crank. Took her out for a drive, pulls harder, more RPM, and runs smoother. I think I'll be sticking with points from now on. |
| RockCrusher wrote: |
JB weld the case halves....that'll keep the fretting to a minimum.  |
VIN Samba Member
my jaycee pully is tight fit as well. how do you guys get them back off? jaw puller? its gotta go on and come off at least 3 times i would think.
once during mock-up, once during dynamic balancing, and once during final assembly.. _________________ Co-owner, 2 Brothers Guns
[email protected]
Click to view image |
Posted: Wed May 23, 2012 7:18 pm Post subject: |
| and once more when you forget to put on the pully tin. |
66brm Samba Member
Joined: January 25, 2010 Posts: 3676 Location: Perth Western Australia
Posted: Wed May 23, 2012 9:21 pm Post subject: |
| mark tucker wrote: |
Or one of those damn screws comes loose _________________ Aust. RHD 66 Type 1
Aust. RHD 57 Type 1 Oval
| modok wrote: |
| I am an expert at fitting things in holes, been doing it a long time |
Posted: Thu May 24, 2012 6:50 am Post subject: |
| loose screw?? hmm Ive had a few of those........some say I still do. |
Posted: Thu May 24, 2012 7:44 am Post subject: |
| DarthWeber wrote: |
| HeidiHo wrote: |
Are you related to Tom Wilson?  |
No but his book sure was helpful! _________________ My 1970 Beetle Thread
Posted: Thu May 24, 2012 8:16 am Post subject: |
| I thought that was wilson wilson? heidiho neibor tim !! do you know what time it is?? |
