mounting tires
Page: Previous  1, 2, 3  Next
BlastMasterMannyFresh
PostPosted: Fri Aug 31, 2012 3:48 pm    Post subject: Reply with quote
cdennisg wrote:
Lengua? ICKY!
Are you kidding me Corey? Lengua is actually a delicacy served on special occasions.
cdennisg
cdennisg is offline
PostPosted: Fri Aug 31, 2012 3:57 pm    Post subject: Reply with quote
mannys66 wrote:
cdennisg wrote:
Lengua? ICKY!
Whale snot and monkey brains are delicacies, too, but I ain't eatin' 'em.
Busryder
Samba SuperHero
Busryder is offline
PostPosted: Fri Aug 31, 2012 4:05 pm    Post subject: Reply with quote
cdennisg wrote:
mannys66 wrote:
cdennisg wrote:
Lengua? ICKY!
Laughing Laughing You need to expand your horizons... Wink
Lind wrote:
Apparently I was just the lucky asshole that showed up at the right time.
I am a Dick, hear me roar- Laughing
Me, an OVP Lifer...
cdennisg
cdennisg is offline
PostPosted: Fri Aug 31, 2012 4:08 pm    Post subject: Reply with quote
Busryder wrote:
cdennisg wrote:
mannys66 wrote:
cdennisg wrote:
Lengua? ICKY!
Very Happy
65Busstop
65Busstop is offline
PostPosted: Fri Aug 31, 2012 4:55 pm    Post subject: Reply with quote
There is always this technique. Laughing
http://www.youtube.com/watch?v=7owrxqMFSy8&feature=youtube_gdata_player
PSScoots Premium Member
PSScoots is offline
PostPosted: Fri Aug 31, 2012 6:26 pm    Post subject: Reply with quote
That's way more interesting than the video about how put your pulley belt on with the engine running.
Rebuilt to drive not decorate. -VOLKSWAGNUT
"Service the car and it will give you good service."
///Mink
///Mink is offline
PostPosted: Fri Aug 31, 2012 6:58 pm    Post subject: Reply with quote
Done that many times myself. The trick when prying it on is to force the bead down into the channel of the rim by standing on the tire for the last bit. However, most of the time with VW tires, you don't need to resort to the "fire" method. Just removing the valve core and sending a blast of air down the valve will be enough to seat it.
LAGrunthaner Premium Member
LAGrunthaner is offline
PostPosted: Sat Sep 01, 2012 1:07 pm    Post subject: Reply with quote
Done, too bad I just didn't go to my mechanic first Crying or Very sad
My mechanic did it free but I always leave him a good tip Wink
The cool thing is I learned about the tire machines with the 4 grippers and I will also use it for my other vintage car.
Thanks for all the help.
Maui Roadsters VW Logo
www.mauiroadsters.com
http://www.oacdp.org
Lind wrote:
sub-hatchtim
sub-hatchtim is offline
PostPosted: Sat Sep 01, 2012 10:19 pm    Post subject: Reply with quote
is it bad to not balance your tires?
58' pg/sg silo fridge westy
58 Dove blue singlecab
76 911S
Busryder
Samba SuperHero
Busryder is offline
PostPosted: Sat Sep 01, 2012 10:22 pm    Post subject: Reply with quote
You can 'feel' an unbalanced tire at the helm.... Confused
Me, an OVP Lifer...
cdennisg
cdennisg is offline
PostPosted: Sat Sep 01, 2012 10:37 pm    Post subject: Reply with quote
On buses, I don't bother unless I can feel something while driving. I just mounted four Cooper Discoverers and I can feel no out of balance issues all the way up to 70 MPH. This is the second set of these tires I have had on a bus with no balancing.
sub-hatchtim
PostPosted: Sat Sep 01, 2012 10:45 pm    Post subject: Reply with quote
cool I have 205 75 15 bfg's they arent balanced and I cant even tell but I have only gotten it up to 65
76 911S
Busryder
Samba SuperHero
Busryder is offline
PostPosted: Sat Sep 01, 2012 11:30 pm    Post subject: Reply with quote
Simple speculation:
I would assume that the side-wall grade would make a bit of a difference... the BFG D's on my Vanagon were balanced, but I have felt nothing while in these shoes.
(I may be interested in selling it, it's in my Gallery, but I have yet to commit... Rolling Eyes )
The BFG's:
195/75R 14" BFG's, Load Range: 'D'
What Load Rating are your tires?
Me, an OVP Lifer...
PostPosted: Sun Sep 02, 2012 7:54 am    Post subject: Reply with quote
I did not have him balance the spare and it s a used tire (for now) but when I swap it back I'll have him balance just in case I need it. Thanks guys.
Next wheel problem, this is the wheel I swapped out with the spare, I read somewhere the hubcap clips are riveted in how do I remove the old rivit without damaging the wheel and once I buy new clips I am assuming they include a rivet which I know how to apply. Thanks again, making progress everyday.
Lind wrote:
cdennisg
cdennisg is offline
PostPosted: Sun Sep 02, 2012 8:49 am    Post subject: Reply with quote
Drill the rivet out from the backside of the rim. Be careful not to make the hole too big.I use a 1/8" bit, which is smaller than the rivet, but once drilled I use a small center punch to drive the old rivet through the hole.
I also grind the back of the rivet flush with the wheel to get rid of the mushroomed part of the rivet. Sometimes that is enough to make the rivet come out without drilling. Don't overdo the grinding, just remover the rivet mushroom.
You need a special rivet tool to install the factory rivets. I don't bother with that anymore, but I built a tool for it years ago. Now, I just use a small screw and a nylock nut. Works perfect every time, it can't be seen with the hubcap on, and if a clip breaks, it's much easier to replace.
Eric&Barb
Eric&Barb is offline
PostPosted: Sun Sep 02, 2012 9:37 am    Post subject: Reply with quote
Lots easier (and no risk of drilling off center) to either use a small chisel to chop off the rivet head or use a dremil cutting disc to do this if worried about slipping with the chisel and hitting nicely painted rims.
Then pin punch out the rivet remains.
See 1963-67 Workshop Manual, section B-10, page 3.
In Stereo, Where Available!
PostPosted: Tue Sep 04, 2012 2:25 pm    Post subject: Reply with quote
Thanks nice dolly:
Lind wrote:
BarryL Premium Member
BarryL is offline
PostPosted: Fri Jul 11, 2025 6:26 pm    Post subject: Re: mounting tires Reply with quote
Anyone know if modern (or older) tire mounting machines can mount the tire onto the rim with the beauty ring installed?
BarryL is offline
PostPosted: Fri Jul 11, 2025 6:36 pm    Post subject: Re: mounting tires Reply with quote
I bought this adapter for the tire shop to balance my tires. https://www.cagero.com/en/prod/Various/Tools/Works...amp;n=323.
Does anyone know if you can use the M12x1.5 lug nuts to hold the VW wide five rims or do you have to use M14x1.5?
Eric&Barb
PostPosted: Fri Jul 11, 2025 8:17 pm    Post subject: Re: mounting tires Reply with quote
Since beetle rims can be put on a type 2 and visa versa, it does not matter which lug bolts you use in a tire adapter.
Page 2 of 3
