Any reason not to leave valve on propane tank open?
specialev
specialev is offline
PostPosted: Thu Dec 13, 2012 7:26 pm    Post subject: Any reason not to leave valve on propane tank open? Reply with quote
I've got a propex heater (only propane powered accessory) and I'm in the habit of always closing the valve on my propane tank when not using the heat. A lot of times I find myself too lazy to hop out and open it back up when want to turn on the heat to speed up the warming of the interior.
So, I'm wondering if there is any reason not to leave the valve on my propane tank open all the time?
What do you do?
joseph928
joseph928 is offline
PostPosted: Thu Dec 13, 2012 7:56 pm    Post subject: propane tank Reply with quote
Blue Bay Bus Turn it off, it's a safety hazard to many things can go wrong. If God forbid you get into a wreck , hit on the side. you want the valve off, or the copper pipe could leak! You go Boom! Shocked
1987 syncro westy tin top sun roof , GW2.3, rear locker, decoupler, Gary Lee tire rack & winch mount, lift, south african grill, big brakes , rhein alloy ,15 BFG AT, Fiamma 10 foot awning ,140 watt rear 85 watt front solar , mppt, truckfridge, automatic fire extinguishing system, tencent oil cooler, And a RMW SS exhaust! - 1971 bug convertible 1776 engine- 2010 Subaru turbo - 1993 Toyota 4x4 truck - 1999 Harley 95 CI, big bore, Andrews cams . Also 80-84- vans. Stock 65 sunroof bug.
shepherdsond
shepherdsond is offline
PostPosted: Thu Dec 13, 2012 8:27 pm    Post subject: Reply with quote
Propane on - no Boom
It did spring a leak though as there was no propane left 3 weeks later. My only reason for leaving propane on was to run the fridge. Definately safer to turn off though.
87 Syncro Hightop Camper
3 knobs + solid shaft
2.2 Phase II Subaru
Hi-Top build thread:
http://www.thesamba.com/vw/forum/viewtopic.php?t=534517
GreenMachineVW
GreenMachineVW is offline
PostPosted: Thu Dec 13, 2012 8:58 pm    Post subject: Reply with quote
I leave it on if I can. I often have the fridge going all summer while daily driving. I get about three weeks of cool per tank.
Terry Kay
Banned
Terry Kay is offline
PostPosted: Thu Dec 13, 2012 10:58 pm    Post subject: Reply with quote
Turn it off when your not using anything requiring propane.
T.K.
GWTWTLW
GWTWTLW is offline
PostPosted: Thu Dec 13, 2012 11:26 pm    Post subject: Reply with quote
When I rolled my Adventurewagen, my stove was ripped completely out leaving a ripped copper tube. If my propane had been on, I probably wouldn't be writing this. Take it for for whatever it's worth...
89 Syncro Westy - GW 2.5, now with a double knob job
@gwtwtlw
nodrenim
nodrenim is offline
PostPosted: Fri Dec 14, 2012 5:45 am    Post subject: Reply with quote
In the commonwealth of Virginia it is illegal to have your propane turned on while traveling on a public highway. There was an explosion at a truck stop, when an RV propane system blew, while re-fueling at the pump. It was not a pretty site, pieces of semi's, rv's and people everywhere. The pump island was totaled out.
Ahwahnee
Ahwahnee is offline
PostPosted: Fri Dec 14, 2012 6:33 am    Post subject: Reply with quote
You should certainly turn it off at the main if you will be parked in a confined area such as a garage.
It is my recollection (October 31, 1963) that prorpane is most dangerous when a quantity can pool in a confined area prior to ignition.
dobryan Premium Member
dobryan is offline
PostPosted: Fri Dec 14, 2012 6:43 am    Post subject: Reply with quote
I keep it off. I've seen folks fool with the burner knobs and leave them on. Kids do that too. If the propane was on you could have a tragic result. Yes it is a pain to have to turn it on each time you use it but the downside is potentially life threatening. Not to say there aren't plenty of instances when accidents did not rupture the propane line, but if it happened to you......
Dave O
Traveling after Building a bus for travel in Europe (euroBus)
The Western Syncro build
ZanaEvyPapa
ZanaEvyPapa is offline
PostPosted: Fri Dec 14, 2012 6:55 am    Post subject: Reply with quote
looks like we need an innovation. how about a remote control propane valve/solenoid? There are such things in the fireplace realm. Someone crafty could borrow the parts/tech and make it happen. Sorry, I'm just good for ideas...
82 Diesel Westy
03 Jetta TDI
Gainesville, FL
danfromsyr
danfromsyr is offline
PostPosted: Fri Dec 14, 2012 7:36 am    Post subject: Reply with quote
they have NC 12v propane valves on fleabay and likely your local HVAC supply house
http://www.ebay.com/sch/i.html?_trksid=p2047675.m5...;_from=R40
that's all I'll add in comment.
Abscate wrote:
j_dirge
j_dirge is offline
PostPosted: Fri Dec 14, 2012 8:04 am    Post subject: Reply with quote
12v solenoids to "turn on" propane delivery (like danfromsyr just linked) have been in use on yachts for a couple decades.. at least.
Check out WestMarine's site, Defender, or Jamestown Distribitors, too.
Pretty safe.. and so very easy to use. I am installing my propex and will have one in use in my system.
-89 GL Westy, SVX.. finally.
-57 pan f/g buggy with a 67 pancake Type 3 "S"
"Jimi Hendrix owned one. Richard Nixon did not"
-Grand Tour, Season 1, episodes 4 and 5
danfromsyr wrote:
those are straight line runs with light weight race cars for only 1/4mile at a time..
not pushing a loaded brick up a mountain pass with a family of 4+ inside expecting to have an event free vacation..
Jon_slider
Jon_slider is offline
PostPosted: Fri Dec 14, 2012 9:53 am    Post subject: Reply with quote
I leave my propane tank valve on ALL the time. I do not leave my stove knobs on. I have not rolled my van, and have not blown up.
otoh, the way to start a fire is to go to a propane station for a refil, and leave your fridge on while he pumps the Propane. (I know, you dont have a fridge, but imo, Van propane fires are caused by refilling the tank with the fridge pilot lit.)
And yes, those electric shutoffs look like a good option.
imo, if youre avoiding using the propex because you keep turning the valve off, dont keep turning the valve off.
You might also get Karl to weigh in on this, since he sells the Propex, Im sure he has an opinion.
My Soapboxes: Inflation; Handling; Gearing; Decoupling; Swepco
shepherdsond
PostPosted: Fri Dec 14, 2012 1:12 pm    Post subject: Reply with quote
Best of both worlds - How about combining a solenoide with an inertia cutoff switch:
http://tinyurl.com/d7sqapm
2.2 Phase II Subaru
Timwhy
Timwhy is offline
PostPosted: Fri Dec 14, 2012 2:57 pm    Post subject: Re: Any reason not to leave valve on propane tank open? Reply with quote
Get out of the Westy and turn it back on, only takes a few seconds!
'15 Audi A3 Quattro
'09 VW Tiguan (dead)
'87 VW Westy
'91 Tin Top
'90 Cabby
davevickery
davevickery is offline
PostPosted: Fri Dec 14, 2012 6:24 pm    Post subject: Re: Any reason not to leave valve on propane tank open? Reply with quote
No way I'm getting out of the van in the morning to turn the heater propane on. It's cold out there... If I'm o.k. sleeping with propane flowing and heater running, I'm o.k. with the valve being open in the driveway. Sheesh, what else can we get paranoid about. It is a RV with propane service, that is what it is made for. Not a big deal to leave the valve open. And I use the LP fridge while driving, so it doesn't get shut off then either, and if I recall correctly, it was acceptable to run the fridge on LP while driving. The valve is only closed occassionally, like when filling or taking a Ferry ride.
SteveVanB
SteveVanB is offline
PostPosted: Fri Dec 14, 2012 8:45 pm    Post subject: Reply with quote
Thats an open ended question.........
91 CARAT
msinabottle
msinabottle is offline
PostPosted: Fri Dec 14, 2012 9:41 pm    Post subject: Definitely when... Reply with quote
Turn off the valve and the fridge on propane when getting a refill. My propane people, who are VERY good, say, 'Instant Van-Be-Que.'
Shocked
No.
Best!
'Winston,' '84 1.9 WBX Westy
many ways, but never, never, never in silence."
Terry Kay
Banned
PostPosted: Fri Dec 14, 2012 9:45 pm    Post subject: Reply with quote
I am almost positive that if you take a look at the Westfalia suppliment in with, and included your owner's manual that it is not suggested to run with the reefer on propane.
The position of the stainless vent on the side of the Van will scoop up plenty of air at speed and has a real good posibility of blowing that flame out in the ice box.
I believe it is suggested that the reefer run on 12 volts while enroute, or on the roll.
I for sure wouldn't have the tank open while on the highway.
Whatever goes on in back with kids, girlfriends--whoever,you have not one iota of control--
No Thanks.
I like rolling the bones, and living a little on the wild side, but not when it comes to something I won't know anything about until the kaboom.
Nyet.
Fire & explosions are out.
T.K.
silversync
silversync is offline
PostPosted: Fri Dec 14, 2012 9:49 pm    Post subject: Reply with quote
? Any reason not to leave valve on propane tank open?
It depends....
Roland: '89 Syncro, '02 911 C4S, '10 Audi A4 Avant
