b1pig Samba Member
Joined: March 06, 2012 Posts: 297 Location: Ray City, Ga
Posted: Sat Sep 01, 2012 7:13 am Post subject: Seatbelts |
just an fyi for anyone looking...
if you need good functional seatbelts and dont need an original replacement....
the seatbelts for a HUMMV fit perfectly in a super beetle. i had to remove a small metal piece and enlarge two of the holes on the back of the reel. the reel mounts to the original angle bracket with stock hardware and the buckle assy just needs the loop widened out a tad bit... and swap bolts. i used longer bolt from the reel bracket on the buckle.
found some cheap on ebay.  |
vinbeetle Samba Member
Joined: July 13, 2012 Posts: 152 Location: crandall GA
Posted: Sat Sep 01, 2012 3:54 pm Post subject: |
wonder if they will fit a 70 standard....any idea? |
b1pig Samba Member
Posted: Sun Sep 02, 2012 4:39 am Post subject: |
if the standard seatbelts can be swapped out for super-b seatbelts... probably so.
i've got pics on my camera at the house. after i get home from job#2, i'll try to remember to upload em. that might give you and idea. |
Redvolk65 Samba Member
Joined: September 07, 2010 Posts: 290 Location: Los Angeles,CA
Posted: Sun Sep 02, 2012 10:07 am Post subject: |
got any pictures need to replace mine? |
b1pig Samba Member
Posted: Sun Sep 02, 2012 7:51 pm Post subject: |
here are the pics...
The stuff i got was a complete rear seatbelt conversion kit, for the M998 series HUMMV.. also fits several others. the shipping was as much as the purchsae, but... they're brand new in original package.
stock reel compared to M998 reel
M998 reel with the original reel bracket...
(2 smaller holes needed to be enlarged a bit)
installed
the eyes/loop on the end of the buckle have to be widened a little to fit over the bolt with the shoulder... its longer. could use a washer over it... test fit is good.
these are probably pretty similar to most other "universal" seatbelt sets that use the steel cable for the buckle. i liked it better considering that the cable holds itself up w/o the buckle plugged up. others use a webbed strap and may have a ugly plastic sleeve to hold it up off the floor. still... with shipping, it was a bit over $30 for both sides. and i have a couple pounds of grade 8+ bolts to stock my bins with too.  |
EVfun  Samba Member
Posted: Sun Sep 02, 2012 7:57 pm Post subject: |
Any chance those will work in a Super Beetle convertible? Any chance they are a little longer than the stock seat belts? My wife is short (she's not looking at me type this) and has the seat so far forward that I can't get between the steering wheel and seat. The stock belt works for her, but she has to unbuckle to reach the ignition switch! _________________
Wildthings wrote: |
Posted: Sun Sep 02, 2012 8:47 pm Post subject: |
wow the look awesome,where did you order them,do you have a web page? |
4Doora Samba Member
Joined: November 13, 2006 Posts: 1154 Location: Hudson, NH
Posted: Sun Sep 02, 2012 8:58 pm Post subject: |
Wow, those look great! Looks like I've found a replacement for my crappy non-retractable stock belts in my '69. _________________ '69 Bug,'71 Bus,'61 Bug ,'56 Bug, '66 Panel |
b1pig Samba Member
Posted: Mon Sep 03, 2012 3:54 am Post subject: |
this is the guy i got mine from....
http://www.ebay.com/itm/221098013559?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2648
he ships the whole conversion kit complete, so thats the reason for the higher shipping cost. like i said... you end up with some (alot of) extra hardware and some formed metal. i like to cut/weld junk so it gives me some stuff to play with.
for me, the whole kit with both seatbelts was cheaper than others selling a single seatbelt.... and any that were selling both sides. |
rwcmjack Samba Member
Joined: December 16, 2010 Posts: 39 Location: Bay Area California
Posted: Sat Dec 29, 2012 9:16 am Post subject: thanks |
just stumbled upon this - great advice!! |
swelchy Samba Member
Joined: January 07, 2013 Posts: 134 Location: Douglasville, GA
Posted: Mon Jan 07, 2013 3:50 pm Post subject: |
Thanks... ordered these last week and they came in today... just waiting on some seat belt brackets and I'll get them in.. i'll post pics too.. Best deal out there for under $30 shipped to my door |
Yarkle  Samba Member
Joined: August 03, 2009 Posts: 1256 Location: the Hills of Western Maine
Posted: Tue Jan 08, 2013 4:01 pm Post subject: |
smoking deal! if you want 4 the guy cuts you a deal on shipping too. MAM has a similar 3 point set up for..wait for it....
179.99
granted, it might be shinier or something, but for repro seat belts, you cant beat this with a stick. I tried and my stick broke!
also, MAM lists that their kit fits:
Thing (1973 - 1974)
Type 3 (1962 - 1973)
Ghia (1956 - 1974)
Super Beetle (1971 - 1979)
Beetle (1950 - 1977)
so if this one fits a 70s super, it should fit everything else
AND..unfortunatley Ive had experience with quick stops in a HMMWV...the belts work! |
bartman Samba Member
Joined: February 22, 2004 Posts: 767 Location: palatka, fl
Posted: Thu Jan 10, 2013 5:27 pm Post subject: |
Just got mine today. They fit perfectly after the hole mod. The double fistful of grade 8 hardware was a bonus.
I got them from Ebay seller "defense-acquisitions" _________________ Remember, kids------> KCR Transmissions SUCKS |
mnussbau Samba Member
Joined: August 26, 2006 Posts: 4610 Location: Central Maryland
Posted: Thu Jan 10, 2013 5:55 pm Post subject: |
EVfun wrote: |
Any chance those will work in a Super Beetle convertible? Any chance they are a little longer than the stock seat belts? |
Ever get an answer on this? I'm wondering about it for my vert. _________________ Mike
‘74 bug vert
Parts... |
Yarkle  Samba Member
Posted: Thu Jan 10, 2013 5:59 pm Post subject: |
read my post about 3 or 4 up. Id guess yes. |
relicstone Samba Member
Joined: May 06, 2006 Posts: 365 Location: Smyrna Delaware
Posted: Thu Jan 10, 2013 6:07 pm Post subject: |
Very interested. What kind of after market mounting brackets are needed to mount them? _________________ 1968 VW Beetle | |
Posted: Thu Jan 10, 2013 6:26 pm Post subject: |
Yarkle wrote: |
Thanks, convertible seat belts are a little different. MAM's entry makes no sense. _________________ Mike
‘74 bug vert
Parts... |
Yarkle  Samba Member
Posted: Thu Jan 10, 2013 6:39 pm Post subject: |
dont they just have that kind of funny thing on the seat and door "pillar" for the mount?
I'd imagine the universal type belt probably has enough slack in it for either application. I havent seen a vert in person (or examined the belts anyways) in a long time, but IIRC, its roughly the same distance isnt it, sinc eyou arent goign as tall, just back farther? |
Yarkle  Samba Member
Posted: Tue Jan 15, 2013 1:46 pm Post subject: |
I just got mine today and seem to have trouble unspooling them..has anyone else had this porblem? I messaged the seller, but i thought I might get a faster reply here.]
is there a trick to it? or diid i get a defective set? i cant get them to extend any more than 6 inches. |
JimmyB68 Samba Member
Joined: October 21, 2011 Posts: 28 Location: Odebolt Iowa
Posted: Tue Jan 15, 2013 2:04 pm Post subject: |
Hold them straight up and down . They have an inertia toggle in them . pull the belt strait up . I just got a set last week they work great ! |
