scvw Samba Member
Joined: September 02, 2006 Posts: 3552 Location: South Carolina
Posted: Tue Oct 20, 2009 2:55 am Post subject: Door rubber pics and information |
I am installing new hatch, cargo door and cab door rubber on my '57 and I need to see some pics of how the door rubber butts up to each other and over laps on the cargo doors and especially around the front doors where it overlaps at the beltline so that the transition between the door and window frame seals up properly. Thanks. _________________ 58 Coral Red ragtop(Diana's car)
63 Ruby Red SC
67 Pearl White SO42
SOUTHERN INTEGRITY AIRCOOLERS |
splitpile Samba's Worst Speller
Joined: May 03, 2000 Posts: 5928 Location: back to living where hell meets the suface
Posted: Tue Oct 20, 2009 7:54 am Post subject: Re: Early door rubber pics |
scvw wrote: |
I am installing new hatch, cargo door and cab door rubber on my '57 and I need to see some pics of how the door rubber butts up to each other and over laps on the cargo doors and especially around the front doors where it overlaps at the beltline so that the transition between the door and window frame seals up properly. Thanks. |
dropgates.com has nice pics of how to do it _________________ Stocking distributor of "The Funky Green Panels"
"no more hacking my sig line" |
scvw Samba Member
Posted: Tue Oct 20, 2009 8:02 am Post subject: |
Thanks Ronnie, I will check that site out. If anybody has any pics I would still like to see how yours was installed. Original or recently replaced. _________________ 58 Coral Red ragtop(Diana's car)
63 Ruby Red SC
67 Pearl White SO42
npbusguy Samba Member
Joined: February 08, 2006 Posts: 1661 Location: Budapest, Hungary
Posted: Tue Oct 20, 2009 1:43 pm Post subject: |
Pix are of Gibbs' 57 standard which is an excellent resource when trying to restore a late 50's bus.
vwSplitty67 Samba Member
Joined: May 09, 2009 Posts: 38 Location: Lancaster, PA
Posted: Tue Oct 20, 2009 5:12 pm Post subject: |
Sweet, thanks! _________________ '67 spltty
white/green
1641 |
obus  Samba Member
Joined: March 08, 2001 Posts: 11641 Location: just off Garden State Parkway Exit 81
Blauhaus Samba Member
Joined: June 18, 2003 Posts: 140 Location: Jacksonville, FL
Posted: Thu Oct 22, 2009 6:06 am Post subject: OG door seals 1956 Kombi |
Joey,
Not sure that anyone has posted the funky shape the seal has around the hinge area on the cargo doors - I trimmed my new seals to a similar shape to lie flat. The other pics are just my OG seals and placement. Wish they were soft enough to keep, but they don't seal very well.
Hope this helps.
_________________ www.blau-haus.com
QUALITY CLOTHING. PRODUKTS. FÜR THE PEOPLE.
** WANTED **
Haines VW dealership (Sacramento) license frame |
scvw Samba Member
Posted: Thu Oct 22, 2009 12:03 pm Post subject: |
Thanks Robert. Can't wait to see that bus two weeks from today. Get-r-done  _________________ 58 Coral Red ragtop(Diana's car)
63 Ruby Red SC
67 Pearl White SO42
Posted: Thu Oct 22, 2009 12:06 pm Post subject: |
You betcha! Looking forward to it. East Coast represent! _________________ www.blau-haus.com
** WANTED **
EverettB  Administrator
Joined: April 11, 2000 Posts: 71536 Location: Phoenix 602
Posted: Thu Aug 01, 2013 9:55 am Post subject: |
In response to someone's question in another thread, I am posting here since this thread is in the Bus FAQ.
For the cargo doors, the only rubber on the body are the 2 horizontal pieces that run across the top and bottom of the cargo door opening on the body.
Top center is the cargo door set up.
Top and Bottom strips are on the body
The rectangles are on the doors. _________________ How to Post Photos
hexarobi Samba Member
Joined: February 08, 2011 Posts: 9 Location: Austin, TX
Posted: Sun Jan 19, 2014 11:31 am Post subject: |
Thanks for this thread, was helpful in redoing my rubber.
I'm using WolfsburgWest set of rubber #241841823AWWand gluing it in with 3m yellow weatherstripping adhesive.
The grey rubber that comes from WW is one solid layer, and I found it difficult to cut clean notches out of it for the door fittings to lay flat. It seemed thinner than the original stuff in the pics above so I just went with it. The doors close but of course since its brand new rubber its tough to close them right now. Hopefully in a few weeks they will take shape and close easier.
Has anyone else had success cutting notches out of the WW rubber? If so, what tools did you use and how did you do it? |
zehbeh Samba Member
Joined: February 16, 2008 Posts: 256 Location: Stuttgart
Posted: Mon Jan 20, 2014 12:18 am Post subject: |
hexarobi wrote: |
Yes. Did it on a band saw. Gives a rough surface, but as it is later not visible any more, it doesn't matter to me. |
kenshapiro2002 Samba Member
Joined: April 26, 2013 Posts: 1826 Location: Bawlmer Hon
Posted: Wed Aug 27, 2014 2:08 pm Post subject: |
With the OG front door seals, they were sliced and lap glued...over each other, where the body bulges out...just above the beltline. I'm using the new WW grey seals, and I'm guessing they should just be straight on glued in with no slicing and dicing? Like to hear from anybody who has installed the WW door seals as to whether they glued them in as a solid piece or did the factory type build up at that point. _________________ Looking for a correct 1967 rear seat
Looking for '67 Engine / Block HO 183xxx - HO 194xxx |
KombiMadness Samba Member
Joined: December 09, 2011 Posts: 388 Location: Sunshine Coast, Australia
Posted: Wed Aug 27, 2014 11:35 pm Post subject: |
kenshapiro2002 wrote: |
With the OG front door seals, they were sliced and lap glued...over each other, where the body bulges out...just above the beltline. I'm using the new WW grey seals, and I'm guessing they should just be straight on glued in with no slicing and dicing? Like to hear from anybody who has installed the WW door seals as to whether they glued them in as a solid piece or did the factory type build up at that point. |
Yes, on my 59 they were glued in as a solid piece, no slicing or dicing. Fit is good and they seal well. _________________ My brother & I on the roof of Dad's Splitty circa 1967 - I'm the half pint with the skinny legs! |
easy e Samba Member
Joined: May 28, 2008 Posts: 3939 Location: 1 hr north of Santa Barbara
Posted: Sun Nov 30, 2014 6:26 pm Post subject: |
Looking at Neil's NOS cargo body seal up above... anybody ever use one of the concaved front door seals there?
I'm asking because the square profile ones that come in the kits seem too bulky. _________________ aka: Evan
“They are about as worthless as the tits on the boars that live in the woods behind their junk yard.” -Weatherly |
easy e Samba Member
Posted: Sat Apr 01, 2017 4:03 pm Post subject: Re: Door rubber pics and information |
Just wanted to show how the upper/lower pieces of the weatherstripping for the cargo doors are.
It's tapered by about 1/8" thickness at one end.
Here's two 211 841 829 211841829
I thought the tapered area would be placed over a raised metal pressing in the base of the door weatherstripping channel.
But, what I thought was a little odd... is that it means the sharp cornered side of the seal is in the channel recess.
The sides of the cargo door opening (on the bus) have their weatherstripping placed with the rounded corners in the channel.
I guess there isn't a 'rule'... that sharp corners always in/out.
dirtyfrank Samba Member
Joined: August 03, 2008 Posts: 5 Location: Madison, WI
Posted: Sun Jul 05, 2020 12:06 pm Post subject: Re: Door rubber pics and information |
I want to add my experience to this conversation. I bought the WW cargo door seals and made the mistake of not trimming out notches around the door pin areas and the hinge areas. This made my doors not close "true" and while trying to force them closed I accidentally broke the glass on one of my Hehr pop-out windows . Definitely trim at least 2/3 of the back of the seal away around these areas, maybe even 3/4. I used a utility knife with a new blade and carefully sliced the seal to fit these areas and it worked for the most part. the doors probably will close better with removing as much material as possible, i'm hoping that keeping them closed for a few days will "train" the seals into place and the doors will close more easily. i have a 1959 double-door ez/sundial camper in (mostly) rust free condition, meaning the channels for the seals are in good condition. |
