Door rubber pics and information
scvw
scvw is offline
PostPosted: Tue Oct 20, 2009 2:55 am    Post subject: Door rubber pics and information Reply with quote
I am installing new hatch, cargo door and cab door rubber on my '57 and I need to see some pics of how the door rubber butts up to each other and over laps on the cargo doors and especially around the front doors where it overlaps at the beltline so that the transition between the door and window frame seals up properly. Thanks.
58 Coral Red ragtop(Diana's car)
63 Ruby Red SC
67 Pearl White SO42
SOUTHERN INTEGRITY AIRCOOLERS
splitpile
Samba's Worst Speller
splitpile is offline
PostPosted: Tue Oct 20, 2009 7:54 am    Post subject: Re: Early door rubber pics Reply with quote
dropgates.com has nice pics of how to do it
"no more hacking my sig line"
scvw
scvw is offline
PostPosted: Tue Oct 20, 2009 8:02 am    Post subject: Reply with quote
Thanks Ronnie, I will check that site out. If anybody has any pics I would still like to see how yours was installed. Original or recently replaced.
63 Ruby Red SC
67 Pearl White SO42
npbusguy
npbusguy is offline
PostPosted: Tue Oct 20, 2009 1:43 pm    Post subject: Reply with quote
Pix are of Gibbs' 57 standard which is an excellent resource when trying to restore a late 50's bus. Cool
vwSplitty67
vwSplitty67 is offline
PostPosted: Tue Oct 20, 2009 5:12 pm    Post subject: Reply with quote
Sweet, thanks!
'67 spltty
white/green
1641
obus Premium Member
obus is offline
PostPosted: Tue Oct 20, 2009 5:18 pm    Post subject: Reply with quote
x 2. i hope to attack those soon.
Blauhaus
Blauhaus is offline
PostPosted: Thu Oct 22, 2009 6:06 am    Post subject: OG door seals 1956 Kombi Reply with quote
Joey,
Not sure that anyone has posted the funky shape the seal has around the hinge area on the cargo doors - I trimmed my new seals to a similar shape to lie flat. The other pics are just my OG seals and placement. Wish they were soft enough to keep, but they don't seal very well.
Hope this helps.
www.blau-haus.com
QUALITY CLOTHING. PRODUKTS. FÜR THE PEOPLE.
** WANTED **
Haines VW dealership (Sacramento) license frame
scvw
scvw is offline
PostPosted: Thu Oct 22, 2009 12:03 pm    Post subject: Reply with quote
Thanks Robert. Can't wait to see that bus two weeks from today. Very Happy Get-r-done Wink
63 Ruby Red SC
67 Pearl White SO42
Blauhaus
Blauhaus is offline
PostPosted: Thu Oct 22, 2009 12:06 pm    Post subject: Reply with quote
You betcha! Looking forward to it. East Coast represent!
www.blau-haus.com
** WANTED **
PostPosted: Thu Aug 01, 2013 9:55 am    Post subject: Reply with quote
In response to someone's question in another thread, I am posting here since this thread is in the Bus FAQ.
For the cargo doors, the only rubber on the body are the 2 horizontal pieces that run across the top and bottom of the cargo door opening on the body.
Top center is the cargo door set up.
Top and Bottom strips are on the body
The rectangles are on the doors.
PostPosted: Thu Aug 01, 2013 10:14 am    Post subject: Reply with quote
Some more pics I found
Some cargo door rubber install pics from Neil's '58 Deluxe
NOS cargo door rubber, this is the horizontal piece on the body, you can see how it is shaped around the locking holes on the body
PostPosted: Thu Aug 01, 2013 10:22 am    Post subject: Reply with quote
Here's a photo of an original decklid seal as well
Note how the corners are angled and glued together and there is a separation seam near the bottom center.
hexarobi
hexarobi is offline
PostPosted: Sun Jan 19, 2014 11:31 am    Post subject: Reply with quote
Thanks for this thread, was helpful in redoing my rubber.
I'm using WolfsburgWest set of rubber #241841823AWWand gluing it in with 3m yellow weatherstripping adhesive.
The grey rubber that comes from WW is one solid layer, and I found it difficult to cut clean notches out of it for the door fittings to lay flat. It seemed thinner than the original stuff in the pics above so I just went with it. The doors close but of course since its brand new rubber its tough to close them right now. Hopefully in a few weeks they will take shape and close easier.
Has anyone else had success cutting notches out of the WW rubber? If so, what tools did you use and how did you do it?
PostPosted: Sun Jan 19, 2014 10:20 pm    Post subject: Reply with quote
Yes, although I don't always do the best job.
I use a NEW razor blade and slice it.
zehbeh
zehbeh is offline
PostPosted: Mon Jan 20, 2014 12:18 am    Post subject: Reply with quote
Yes. Did it on a band saw. Gives a rough surface, but as it is later not visible any more, it doesn't matter to me.
kenshapiro2002
kenshapiro2002 is offline
PostPosted: Wed Aug 27, 2014 2:08 pm    Post subject: Reply with quote
With the OG front door seals, they were sliced and lap glued...over each other, where the body bulges out...just above the beltline. I'm using the new WW grey seals, and I'm guessing they should just be straight on glued in with no slicing and dicing? Like to hear from anybody who has installed the WW door seals as to whether they glued them in as a solid piece or did the factory type build up at that point.
Looking for a correct 1967 rear seat
Looking for '67 Engine / Block HO 183xxx - HO 194xxx
KombiMadness
KombiMadness is offline
PostPosted: Wed Aug 27, 2014 11:35 pm    Post subject: Reply with quote
Yes, on my 59 they were glued in as a solid piece, no slicing or dicing. Fit is good and they seal well.
My brother & I on the roof of Dad's Splitty circa 1967 - I'm the half pint with the skinny legs!
easy e
easy e is offline
PostPosted: Sun Nov 30, 2014 6:26 pm    Post subject: Reply with quote
Looking at Neil's NOS cargo body seal up above... anybody ever use one of the concaved front door seals there?
I'm asking because the square profile ones that come in the kits seem too bulky.
aka: Evan
easy e
easy e is offline
PostPosted: Sat Apr 01, 2017 4:03 pm    Post subject: Re: Door rubber pics and information Reply with quote
Just wanted to show how the upper/lower pieces of the weatherstripping for the cargo doors are.
It's tapered by about 1/8" thickness at one end.
Here's two 211 841 829 211841829
I thought the tapered area would be placed over a raised metal pressing in the base of the door weatherstripping channel.
But, what I thought was a little odd... is that it means the sharp cornered side of the seal is in the channel recess.
The sides of the cargo door opening (on the bus) have their weatherstripping placed with the rounded corners in the channel.
I guess there isn't a 'rule'... that sharp corners always in/out.
aka: Evan
dirtyfrank
dirtyfrank is offline
PostPosted: Sun Jul 05, 2020 12:06 pm    Post subject: Re: Door rubber pics and information Reply with quote
I want to add my experience to this conversation. I bought the WW cargo door seals and made the mistake of not trimming out notches around the door pin areas and the hinge areas. This made my doors not close "true" and while trying to force them closed I accidentally broke the glass on one of my Hehr pop-out windows Mad . Definitely trim at least 2/3 of the back of the seal away around these areas, maybe even 3/4. I used a utility knife with a new blade and carefully sliced the seal to fit these areas and it worked for the most part. the doors probably will close better with removing as much material as possible, i'm hoping that keeping them closed for a few days will "train" the seals into place and the doors will close more easily. i have a 1959 double-door ez/sundial camper in (mostly) rust free condition, meaning the channels for the seals are in good condition.
