New To Me! What Make? Progress!!
taildrager
taildrager is offline
PostPosted: Wed Oct 02, 2013 6:29 pm    Post subject: New To Me! What Make? Progress!! Reply with quote
I picked this up a couple of weeks ago. It has a good engine but the exhaust has to go. Does any one know who made the body ? Also has any one made a fold down windshield frame ? I think the biggest problem is going to be the gas tank its integral to the body .Any thoughts Thank Donny
P.S I added photos but i dont know where they went
BL3Manx
BL3Manx is offline
PostPosted: Wed Oct 02, 2013 6:32 pm    Post subject: Reply with quote
taildrager
PostPosted: Wed Oct 02, 2013 6:38 pm    Post subject: Reply with quote
Wow magic
SBD
SBD is offline
PostPosted: Wed Oct 02, 2013 9:32 pm    Post subject: Reply with quote
Wow! Don't know what it is, but it's kinda' cool looking! I see some potential! Cool
manxdavid
Location: David Jones, Anglesey, North Wales, UK. Manxclub #678.
manxdavid is offline
PostPosted: Thu Oct 03, 2013 3:26 am    Post subject: Reply with quote
Crocky Preracer?
http://www.thesamba.com/vw/forum/viewtopic.php?t=472404
BL3Manx
BL3Manx is offline
PostPosted: Thu Oct 03, 2013 6:43 am    Post subject: Reply with quote
Yeah, knew I'd seen that on here, even had the same steering wheel
Dale M.
Dale M. is offline
PostPosted: Thu Oct 03, 2013 7:27 am    Post subject: Reply with quote
Most of these type of fiberglass bodies that had integral tanks have had problems with tanks leaking after many years.... Best thing is to pull body off and cut out old tank area and clean it up as if tank was never there... Looks as there is room to fit a standard VW (8 gallon) tank under hood area, all you have to do is make a support system to hold tank and develop a filler system to put gas in it.... Not much different from any other buggy build.... Looks as if body has some real issues (vertical cut near steering wheel) and other things.... Lots of work there, take you time and think things through....
Dale
tgodber
tgodber is offline
PostPosted: Thu Oct 03, 2013 8:11 am    Post subject: Reply with quote
Be interesting to find out more on the history of that style. Is " Crocky" an English word? Dictionary says smutty.
My wife said I never listen to her.
Or something like that!
manxdavid
PostPosted: Thu Oct 03, 2013 10:31 am    Post subject: Reply with quote
Not one I've ever heard and I'm English... Laughing
taildrager
PostPosted: Thu Oct 03, 2013 12:07 pm    Post subject: Reply with quote
That cut or seam is on both sides . It does not make any sense for them to be there but they look factory . the head light buckets look like they were just glued on to the body i am glade they are still there . I will repair the taillight holes an start over .The body seams to be solid a lot of paint though ! I would like the windshield to fold down I have a fairly complete shop so fabing one does not worry me once i find or come up with a design i like
BL3Manx
BL3Manx is offline
PostPosted: Thu Oct 03, 2013 1:44 pm    Post subject: Reply with quote
I think its probably the name of the maker, Crockey. Don't know if there's any association but here's someone from that time and general neighborhood.
Q-Dog
Q-Dog is offline
PostPosted: Thu Oct 03, 2013 3:39 pm    Post subject: Reply with quote
I think that buggy looks pretty cool. I'd roll it!
And I would run those mufflers on one of my Beetles!
Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle
taildrager
PostPosted: Thu Oct 03, 2013 9:33 pm    Post subject: Reply with quote
Brian if you can use those pipes make me an offer ? The engine was out of a Bug that was wrecked they just dont do any thing for on this body
Donny
taildrager
PostPosted: Fri Oct 11, 2013 8:16 am    Post subject: Progress !! Reply with quote
Had a little time to work on the buggy . I ground all the dead paint off with 36 grit on the DA one of the layers was kind of rubbery it was a pane !
Started on the fiberglass repair i found that a gasket hole cutter makes great disc out of mat for screw hole repair and a flapper wheel on the 4 in grinder is good for feathering old glass for repair
There are photos but i dont no where if someone in terms for a dummy"s how to put the pics here i am all ears thanks Donny
For now i figured out you can see the pics by clicking on gallery
didget69
didget69 is offline
PostPosted: Fri Oct 11, 2013 12:34 pm    Post subject: Reply with quote
Umm... it looks like the body was cut at some point, like on left side at 'dashboard' area? Like someone was looking to stretch the body to fit onto an uncut VW pan?
bnc
I never found the need to impress people with any mechanic certifications, trophies or track wins... unless it was for Mom to post on the refrigerator door.
Kevinwterry
Kevinwterry is offline
PostPosted: Fri Oct 11, 2013 2:18 pm    Post subject: Reply with quote
to post pictures in your posts, go to your gallery and to the right of your pictures you will see a small box that says "forum code". highlight all that text and copy and paste it into your posts.
it does look like the body has been cut by the dash in a couple pics. i dont see the cut in others.
taildrager
PostPosted: Fri Oct 11, 2013 4:49 pm    Post subject: Reply with quote
The cuts are odd the vertical cut under the corner of the dash goes all the way to the floor and was put back together with woven cloth . But there are no signs of the fender flares being cut ? When i get done i am going to try to erase all signs of this mystery
taildrager
PostPosted: Fri Oct 11, 2013 5:33 pm    Post subject: Reply with quote
imag
taildrager
PostPosted: Fri Oct 11, 2013 5:44 pm    Post subject: Reply with quote
[img]
https://www.thesamba.com/vw/gallery/pix/1122194.jpg[/img]
