J-B Weld vs QuikSteel for 2.1 WBX head repairs.
djkeev
djkeev is offline
PostPosted: Fri Nov 01, 2013 8:18 am    Post subject: J-B Weld vs QuikSteel for 2.1 WBX head repairs. Reply with quote
I've read many times about using J-B Weld to repair the damaged heads at the gasket area. While I know that the temperatures are fairly moderate in that area and that JB's temperature tolerance up to 550* is fully adequate I wondered what else was out there.
I stumbled across a product called QuikSteel. While the 3oz package does not say that it works on Aluminum, the 25oz product does state that it is aluminum compatible. I did call BlueMagic to verify that they are the same product only in different containers and they did verify its compatibility with Aluminum on the phone.
What is attractive is the high temperature rating of 2400*. It's not needed there but does that indicate a superior and more enduring product?
Has anyone used this product?
Any feed back?
Yes I know........don't be so cheap, buy some new heads but at $1000 ......... I'll try a fix........
The larger container stating aluminum compatibility...........
Look! It's magnetic........ It must be pulverized iron or steel in some sort of high temperature adhesive suspension..............
Dave
Ghia
Vanagon
Beetle
insyncro
Banned
insyncro is offline
PostPosted: Fri Nov 01, 2013 8:30 am    Post subject: Reply with quote
Personally I havent ever used JB or similar on pitted heads since using The Right Stuff sealant.
It fills gaps and has held up very well for me.
Hopefully others have found the same.
Wildthings
Wildthings is offline
PostPosted: Fri Nov 01, 2013 8:45 am    Post subject: Reply with quote
2x
No worse than the heads look I wouldn't use any filler.
djkeev
djkeev is offline
PostPosted: Fri Nov 01, 2013 9:15 am    Post subject: Reply with quote
Huh, I must have missed those posts! Embarassed
I can see the right stuff working filling in the crevasses and imperfections.
Do you not use the kit provided sealant at all?
Do you use the right stuff on everything, even the head nuts?
Dave
Ghia
Vanagon
Beetle
insyncro
Banned
insyncro is offline
PostPosted: Fri Nov 01, 2013 9:23 am    Post subject: Reply with quote
Dave
I have been sealing, just as Benny has posted the details, pictures and videos for many moons now.
benplace.com
don't forget to donate to his site.
a ton of valuable info is hosted there without all of the Samba peanut gallery comments from know it alls.
reach out, there is life beyond the Samba forums.
I credit been with introducing Loctite 515/518, aviation gasket maker and The Right Stuff to sealing up a waterboxer engine.
Thank you Ben Exclamation
kirsplat
kirsplat is offline
PostPosted: Fri Nov 01, 2013 9:49 am    Post subject: Reply with quote
I use The Right Stuff on everything, even my nuts.
Seriously though...The Right Stuff is great for sealing the water jacket surfaces but if there is pitting in the head gasket surface JB Weld or similar can buy you a few more miles.
I have used Marine Tex in the past with good results.
Surface prep is key using acetone or lacquer thinner.
And also use Aviation sealant to bond the head gasket to the head. (Thanks Ben)
86 Syncro|EJ253|Carat
Alaric.H
Alaric.H is offline
PostPosted: Fri Nov 01, 2013 10:01 am    Post subject: Reply with quote
If you really want to see all the pitting sand blast just the edges of the head.
Type up the head with plastic and plug the holes as sand in engine is no good.
MarkWard
MarkWard is offline
PostPosted: Fri Nov 01, 2013 11:38 am    Post subject: Reply with quote
Add this to the list of useless comments including mine.
djkeev
djkeev is offline
PostPosted: Fri Nov 01, 2013 2:49 pm    Post subject: Reply with quote
Thanks for the tips, thoughts and links!
I really appreciate the information.
Yes, I blasted my head ...... But I used baking soda. No fears of sandy grit in engine! Smile
I found that my cheapie Tractor Supply Blast Cabinet works quite well with baking soda! Smile
Dave
Ghia
Vanagon
Beetle
geo_tonz
geo_tonz is offline
PostPosted: Fri Nov 01, 2013 2:50 pm    Post subject: Reply with quote
Ben also talks about using JB weld on the gasket mating surfaces in some of his videos...
Red Vanagon "Ron Burgundy": 1991 Vanagon Multivan (Weekender) 2.1L Auto - Driver/Camper
mpabegg
mpabegg is offline
PostPosted: Fri Nov 01, 2013 3:17 pm    Post subject: Reply with quote
Detroit Diesel turned us onto this stuff. It's pricey, but well worth it. I get it at a local distributor. However, you can also buy it through grainger.
http://www.belzona.com/en/products/1000/1111.aspx
90 Syncro "Priscilla"
View user's profile Send private message Send e-mail Visit poster's website Twitter Gallery Classifieds Feedback
AtlasShrugged
AtlasShrugged is offline
PostPosted: Fri Nov 01, 2013 6:16 pm    Post subject: Reply with quote
Temperature resistance 93°C (200°F) immersed, 200°C (392°F) dry
Belzona 1111 temp range for a WBX head might be cutting it kinda close..if you use the immersed numbers.
61Scout
61Scout is offline
PostPosted: Fri Nov 01, 2013 6:37 pm    Post subject: Reply with quote
I like this product line:
http://www.alvinproducts.com/Products/Products.asp?ID=2
Kevin
1986 Westfalia Weekender Wolfsburg, RJE 2.3
1985 Tin Top, Subie 2.2 + 5MT
Floppy Mirrors no more: http://www.thesamba.com/vw/forum/viewtopic.php?t=653018&highlight=
Remove the front spindle nut with ease: https://www.thesamba.com/vw/forum/viewtopic.php?t=679567&highlight=
Remove the rear wheel bearing housing without messing with the big 46mm nut: https://www.thesamba.com/vw/forum/viewtopic.php?t=679507&highlight=
-Nec Spe, Nec Metu
djkeev
djkeev is offline
PostPosted: Sat Nov 02, 2013 9:40 am    Post subject: Reply with quote
Kevin
Until you price it............
Dave
Ghia
Vanagon
Beetle
Phishman068
Phishman068 is offline
PostPosted: Sat Nov 02, 2013 9:50 am    Post subject: Reply with quote
I have used the JB weld on several sets of heads with no problems.
I see nothing wrong with using just "The Right Stuff" though if the pitting is minor (it looks like most of your pits are).
I don't use the included gasket compound for anything but do use the yellow stuff on the head nuts.
You could probably use "The Right Stuff" here as well but it sets up really quickly. It's actually a fairly tricky product to use as it has a very short flash time.
If you do the JB weld trick, be sure to sand the head surface flat.
I like to tape Sandpaper or Emery paper to a pane of Glass to assure it's flat and grind the head along that.
http://www.thesamba.com/vw/forum/viewtopic.php?t=559766&highlight=winter+rust
http://www.thesamba.com/vw/forum/viewtopic.php?t=482402&highlight=sunroof+syncro
http://www.thesamba.com/vw/forum/viewtopic.php?t=569774
http://www.thesamba.com/vw/forum/viewtopic.php?p=6864936#6864936
"Along with the ability to go fast, one looses the desire to hurry."
61Scout
61Scout is offline
PostPosted: Sat Nov 02, 2013 11:03 am    Post subject: Reply with quote
Kevin
Dave
It certainly is more expensive, but not outrageous. Look at these two deals:
http://www.amazon.com/J-B-Weld-8265S-Compound-Epox...h+strength
vs.
http://www.ebay.com/itm/Lab-Metal-12-oz-16-oz-Lab-...19dfda01d3
Now 3.2 ounces for the JB weld, so let's say x4 which is $28. Lab metal at $43 for 12 ounces. Is it more per ounce, certainly, but it's not that much more expensive. Also, whenever you mix up the JB weld, how often do you mix too much? I know I do all the time and that extra just ends up in the garbage. With the lab metal, that can go back in the can and be used later. Don't get me wrong, it's not the product I reach for every time, but it is an excellent and proven product.
Kevin
-Nec Spe, Nec Metu
