sts9292 Samba Member
Posted: Sun Jan 26, 2014 4:27 pm Post subject: Transmission knock when turn off |
I could not find anything close to my problem on a search so he it goes ..
I have a 2276cc engine coupled with a freeway flyer transmission. The issue is that after I drive it and park it when I put it in 1st gear and turn the switch on and off again I feel a knock from the transmission like something is engaging in the tranny. If I leave it in neutral and do the same nothing as described happens. Stumped !!
mark tucker Samba Member
Joined: April 08, 2009 Posts: 23945 Location: SHALIMAR ,FLORIDA
Posted: Sun Jan 26, 2014 4:43 pm Post subject: |
| start checking for loose stuff,check gearlube for dibris. |
Posted: Sun Jan 26, 2014 4:50 pm Post subject: |
Can you be more specific? Loose stuff? On the tranny or what? Gearlube ? Are you talking about the level of fluid in the tranny?
Thanks ! |
jsturtlebuggy Samba Member
Joined: August 24, 2005 Posts: 4624 Location: Fair Oaks/Orangevale, CA
Posted: Sun Jan 26, 2014 5:13 pm Post subject: |
Swing axle or IRS trans?
Worn axle spade or fulcrum plates in swingaxle or loose or worn CV joint on IRS can be problems with making noise.
There are many other things too.
More information on what transaxle you have, mileage on it, how is it built, gearing, making any other noises while driving? _________________ Joseph
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960 |
Posted: Sun Jan 26, 2014 7:44 pm Post subject: |
| It is a IRS . No noise when driving. The trans. is in good shape. Shifting normal. I have around 500 miles on the new engine. Trans came with the car from PO. |
Daddybus Samba Member
Posted: Sun Jan 26, 2014 7:51 pm Post subject: |
| Do you have an electric fuel pump or other electric device mounted near the tranny? |
esde Samba Member
Joined: October 20, 2007 Posts: 6386 Location: central rust belt
Posted: Sun Jan 26, 2014 7:55 pm Post subject: |
| So the knock happens with the clutch pedal pushed in? But not let out in neutral right? I would guess throwout bearing or release fork.. |
Posted: Mon Jan 27, 2014 11:11 am Post subject: |
The only part I have mounted near the tranny is the electric oil cooler. It is bolted to the car, not the tranny. Electric pump mounted on the front below the tank.
The knock (and it is a physical knock) happens w/o pushing the clutch pedal. When I turn the car off, then put it in 1st. gear and turn the ignition to the "on" position and back to the "off" position it happens. If I repeat this ... no knock. If I take it for a spin and do the same, the knock happens again. !
Driving me nuts ! |
taylorb1 Samba Member
Joined: July 22, 2012 Posts: 709 Location: Canton, Georgia
Posted: Mon Jan 27, 2014 11:30 am Post subject: |
Easy fix. When you turn it off. Leave it off...... No need to fiddle with the ignition switch like your doing. Sounds like your over thinking this.  _________________ It's not dented, it's just been environmentally streamlined!
76 STD Bug-Sold
71 Transporter Converted To Camper. |
Posted: Mon Jan 27, 2014 11:50 am Post subject: |
I agree that might be the easy fix ... However it is not normal behavior, which indicates a potential problem or breakdown. I guess it is the way my engineering mind works on these things. Being proactive. |
Todd66 Samba Member
Posted: Mon Jan 27, 2014 12:16 pm Post subject: |
| Since the only possible electrical item on the trans is the backup light sw, I doubt the issue is in the trans. I am thinking you have something going on where the starter bumps when you turn the key back on, or possibly you are igniting unburned fuel in one of the cylinders which is bumping the engine. Have someone watch the crank pulley for movement while you do your key on in nuetral. Or just don't turn the key back on. |
bluebus86 Banned
Posted: Mon Jan 27, 2014 3:46 pm Post subject: |
| Todd66 wrote: |
best idea I have read, yeah maybe the motor is being bumped when you turn on the key switch to run, and if the car is in gear, the tranny is bumped by the ignition. try the test with tranny in gear but with clutch peddle depressed and see if issue goes away.
or try a repeat test and see if problem goes away after a repeat. seems to me that after you burn off any remaining fuel in your test, the second test will not have the same result. (ie all the unburnt fuel is consumed during the first cycle of this test, so the second time you test, there will be no bump _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
Posted: Mon Jan 27, 2014 5:50 pm Post subject: |
| on ,off then onagain & knock, it's firing a cylinder. dont wory about it& dont keep effing with the switch or you may be changeing it. |
